Results 1 to 7 of 7
Roof top A/C / heat units..
    Senior Member MFChop's Avatar
    Apr 2014
    Nashville, TN
    Looking to put a roof top A/C / heat unit on the trailer. Anyone have any recommendations beyond the reviews online.. If my maths correct a 13,000 BTU unit should more than suffice.
    Re: Roof top A/C / heat units..
    Hit up local RV service centers, you may be able to score a used unit for cheap.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Apr 2014
    Nashville, TN
    Good idea I have one right down the street... new units look to be in the $700 range
    Are you planning on running off a generator at all? If so figure another $225 for a soft start kit to make the AC happy on a 2k to 3k inverter.
    Mine is 13,500 BTU. I have a 6x12 trailer.
    I would recommend insulating the roof at minimum while you're in there wiring it up.
    EX 105 : CCS Atlantic, Mid Atlantic, South East, Florida, and WERA
    Sponsors: Motul, Michelin/STS, K&N, Woodcraft, Yoshimura R&D All Balls Racing, Galfer, Sidi Boots, Vortex
    Apr 2014
    Nashville, TN
    Possibly...
    Mine is slightly larger but completely insulated and covered walls
    Then you should be good to go.
    I run a 20a fuse to the AC/heat and 15a fuse to the outlets inside
