Results 1 to 14 of 14
Need a simple hand-held, high temp propane torch. Which one to get?
    xxaarraa
    Guest
    I searched and the only threads that come up seem to be related to welding equipment.
    I want to buy a simple, hand held, trigger light propane torch.
    - Want the propane cannisters to be easily available and swappable.
    - Intended use: need it to burn hot enough to loosen any frozen bolts, frozen locks, etc.
    - Need it to be small and portable that using it is not a production.
    I was doing a blind search on amazon and came across something like this:
    Amazon.com : Worthington 310184 WT3401 Pro Grade Trigger Start Propane Torch (Discontinued by Manufacturer) : Home & Kitchen
    Would that be good enough? Any other suggestions please?
    holland ma.
    Re: Need a simple hand-held, high temp propane torch. Which one to get?
    I would go with something map gas related. Propane is ok but doesnt burn hot enough imo. A nice benzomatic trigger gun can do both. Ive had mine for years and years and ive never complained.
    Jan 2007
    Rochester MA
    I got a nice map gas torch with a trigger from lowes for about $50....should fill the bill.
    Hanover, NH
    This thing on Home Depot and you're done. Don't bother with propane, it doesn't get hot enough to unstick frozen New England fasteners.
    You can save a few bucks by getting the simple torch head that requires you to light it manually with a flint, but they suck when it's windy out.
    xxaarraa
    Guest
    Thanks all for the tip on map pro versus propane, I had no idea.
    Number 9, thanks for the link. Supposedly, the TS8000 is an upgraded version of the TS4000 you linked to. Picking that up at my local home depot today, thanks!
    Access Denied
    MAP gas, little yellow bottles, only way to go, propane doesn't get very hot
    MAP gas costs more, but you use less, a bottle goes so much further, it's cheaper in the end
    I just replaced mine, left my old one out in weather $38 at HD for the torch head only, Kit is $46, so you get a $12 bottle of gas for $8
    And the MAPP Pro stuff in yellow bottles sucks compared to real MAP if you can still find it.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Yeah... You can't get MAP anymore...
    Oxy acetylene or bust. Propane wouldn't touch stubborn bolts in my experience. Only way I was able to do anything was with the oxy acetylene.
    In early 2008, true MAPP gas production ended in North America when production was discontinued at the only remaining plant in North America that still manufactured it. However, many current products labeled "MAPP" are, in fact, MAPP substitutes. These versions are composed almost entirely of propylene with minuscule impurities of propane (<0.5%).[1]
    MAPP gas - Wikipedia
    xxaarraa
    Guest
    So you guys are telling me I can't get MAP for the MAP torch I just bought?!
    Correct, what you got is MAP Pro, which is NOT the same as ye olde MAP gas in that it doesn't burn as hot as the old good stuff.
    "The effective BTU output is a measurement of the quantity of BTUs that actually go into the work piece when heated", said Paul Minter, VP / General Manager, TurboTorch."Our lab tests have revealed that MAP//PRO has approximately a 10% greater BTU output over Propane and a 14% less effective BTU output than MAPP. "
    Lifer Stromper's Avatar
    Eastern Ct
    Acetylene
    The calculus of hate
    Nov 2009
    Bristol County
    They're saying you can get something most people call 'MAP' that comes in a yellow bottle, but it isn't the real deal. However, what you bought will connect up to any common small-type propane or yellow bottle of MAPP substitute.
    I have a torch just like that, and a yellow bottle of post-2008 MAPP. It'll get the job done in most cases, especially for the occasional DIY'er. There's only one time I can think of that acetylene saved me. It was on an ancient O2 sensor with a rusted hex that I'd already started to round and looked like the body was going to break off the mounting threads even if I managed to get something to grip.
    A torch like that is handy, portable, and easy to find replacement fuel.
    nedirtriders.com
    Eastern Ct
    There is a little acetylene knee high on a hose no Oxygen that real plumbers use.
    For a time I had a little oxy-acetylene rig knee high and you good just cut stuff up
    40 years ago there were many choices for propane that no longer exist. There was a bernzomatic with about a 3/4 inch nozzle that was very good
    Now for real men BLOW TORCH BLOWLAMP BLOWPIPE 2 LITER LAMP FUEL PETROL GASOLINE + ENGLISH MANUAL | eBay
