Page 18 of 23 FirstFirst ... 891011121314151617181920212223 LastLast
Results 426 to 450 of 573
Snow tires....
  1. #426
    Re: Snow tires....
    Snows go on usually in November and come off in March/April. No time for anything else and they behave better in the cold.
    Re: Snow tires....
    Mine usually go on mid/late Jan and come off at the end of March. This year was an exception, because I bought a new set for a different vehicle.
  3. #428
    Re: Snow tires....
    Just ordered wheels and tires for the new sled. 18x8.5" rims. Pirelli Sotto 3 tires. Hopefully it turns this race car into a decent winter machine.
    Those sound pretty wide man! Might have a bit of float but that means fun....
    CCS/LRRS #83
  4. #429
    Re: Snow tires....
    Maybe a silly question but once their on the car do you guys bother taking your tires off and putting them back on with weather fluctuations?
    Winter tires are designed for low temps but they don’t melt. Until temps are consistently in the 60’sand 70’s you probably aren’t giving up much. Road & Track tested winter tires on a race track.
    https://www.roadandtrack.com/new-car...-track-tested/
    “ Most importantly, at the end of a hard session of high-speed lapping, the Wintersports didn't exhibit any measurable or visible wear at all. That settled it for us: there's no reason to slide through winter on second-rate tread. ”
    Re: Snow tires....
    Wide they are. Maybe 18x8? I don't remember. As long as they fit over the monster brakes and don't make the car go sideways we'll be stoked
    Re: Snow tires....
    But.... sideways is the fun-ways... Snow tires....
    CCS/LRRS #83
  7. #432
    Lifer 01xj's Avatar
    CT
    Re: Snow tires....
    Cool link, thanks. Yeah I was a bit worried about the 45-60 temps but that makes me feel a little better. Most sunny days have been around 50* on my way in, but leaving work at nights we are well into the 30's. As someone else said, I guess having "snow tires" in my mind is incorrect as "winter tires" is exactly what they are.
    Re: Snow tires....
    Uh, well, sideways and forward at the same time, yes, but just going sideways instead of forward on track rubber in the snow isn't fun at all.
    Haverhill, MA
    Re: Snow tires....
    Do some donuts in it in the snow. AWD makes it so it pivots around the stick shift. Foreign feeling the first time.
    Re: Snow tires....
    We will when we get the snows. It's a complete shitshow on the summer tires. The car won't go on flat ground in the snow, nevermind pivot in any predictable fashion.
    Haverhill, MA
    Re: Snow tires....
    Hopefully not too many electronic nannies to shut down the fun on the STI. Even if I shut mine off it turns itself back on if I try to have some fun
    Re: Snow tires....
    Just drove in the worst road conditions in memory.
    Drove up to Sunapee this afternoon. As we climbed over 1,000 feet elevation, temps dropped to 28. We got some light freezing rain as we got nearer Sunapee.
    By the time we were within 4 miles of home, the road was glazed ice. With even partial throttle I could break all for wheels loose. When we came back from Ziggie’s pizza, there was a three way crash (two pickups and a CR-V). You can guess how many of them had winter tires.
    Always hate to spend the money, always glad we do.
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Snow tires....
    The main hilly roads in my town froze over tonight before the sanders could get out. Cars were crabbing down the road, some couldn't make it up the hills, and a couple spun out. My car with the R3s felt squirrely but tracked straight, climbed the hills fine, and stopped with only a little fanfare.
  14. #439
    Re: Snow tires....
    The Jeep is doing well on this stuff, noticed a couple slight movements going over rough roads but otherwise no drama while everyone else was slowing to 1mph and avoiding my road completely. I could light up the rear if desired but had to romp it to do so, stopping distances were increased with ABS lighting off but not horribly.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
  15. #440
    Sep 2007
    Re: Snow tires....
    Yep. The way I look at it is one accident prevented makes it worth it.
    Street Triple R, Ducati Scrambler Icon, Monster 1100evo, VFR, CRF250L/M, CRF230L
  16. #441
    Re: Snow tires....
    I finally picked up the winter wheels for the STi. Should transform this thing into a winter monster. Trying the contis. It was actually hard to find tires in these sizes in stock, so my choices were limited.
    Re: Snow tires....
    Those should give you the razor sharp response needed to avoid potholes of death.
  18. #443
    Re: Snow tires....
    We’ve punched out 45 aspect ratio tires in potholes before (why I went to 16” on the WRX) but this is a first. Punched out a (we think) properly inflated 225/55x17.
    Re: Snow tires....
    Well, i can't get 17s on over the big brakes. These were the smallest rims/tires i could reliably fit.
    Haverhill, MA
    Re: Snow tires....
    Pics of them mounted on the car along with one with the stock wheels. Wonder which wheels will look "better"?
    Grab yourself a relatively narrow snow brush to get in between the spokes of the wheel and knock out the snow that will pack in behind the spokes and around the brake rotor/caliper. My 2.5RS with similarly shaped wheels, the snow liked to pack in there and the ride would go all to hell with the wheels out of balance due to the snow.
    Re: Snow tires....
    Yeah. Snow packing in the wheels was always going to be an issue on this car. The stockers are quite nice. Y spoke design. We figured it would be fun to have something totally different for winter.
    Hypertarded
    Re: Snow tires....
    , for when it gets really frozen on the inside of the rim I normally also keep a plastic no-mar scraper in the car, this or similar
    https://www.harborfreight.com/automo...set-95832.html
    IF you have time before mounting I'd add a layer or 3 of a quality wax to the inside of the wheel
    Re: Snow tires....
    Beast mode engaged.
    Haverhill, MA
    Re: Snow tires....
    Agreed the stockers do look pretty good when doing the side by side comparo. New ones make great looking winter wheels without having to have steel wheels and much more access to remove packed in snow.
    Re: Snow tires....
    They look a lot nicer in person. Smaller wheels are always going to look a little lame side by side with bigger ones
