Page 54 of 54 FirstFirst ... 14344445464748495051525354
Results 1,326 to 1,344 of 1344
Snowblower
  1. #1326
    Seacoast NH
    Re: Snowblower
    Weird snow here. Ground must be quite warm as the snow is light and fluffy on top and wet and heavy underneath. Nothing stuck within ~8" of the foundation.. then there's 10-12 or so. Looking at the forecast I'm not even going to bother roof raking.
    12" of the wet, heavy stuff down on the south coast. My Ariens Deluxe 28-SHO did well, but certainly not flawless. Cutting through the plow drifts I had to feather the clutch quite a bit to keep it slowed down enough to blow snow instead of pushing it. If I had this purchase to do over again I would have bought the Platinum 24 SHO at similar money and sacrificed width for more tons/hr.
    I have similar feelings about my Troy-Built 30" machine. I bought it with the expectation that I could do the throat of my driveway in just 2 passes (out, back, out, back.. done). Doesn't work out this way. I wish I'd bought a smaller, better built machine.
    Getting the carb tuned up on the Troy-Bull now. I think it is just getting some crap from the tank occasionally making it surge a little. The old thing is a tank, but the secondary impeller, I feel, is too small. It is very wide and deep, handles a ton of snow, but doesn't throw it as far as I'd like. It will just get about 6" of snow fully across my 2 car wide driveway. I'm going to do the impeller mod this off season and see if that helps next winter. But the way this thing is built, it's a keeper. Might have to get a Briggs v-twin and big pulley on the engine to speed things up a bit.
    I am having similar problems with mine surging. Purrs under load. Notsomuch at idle. I just fed it some sea-foam in the hopes it clears without further intervention.
    I feel exactly the same re; the small impeller. I feel like the motor has more than enough power. But the bucket can easily over-whelm the thrower.
    Also the drive speeds are idiotic. 1 is usually too slow and 2 is almost always too fast. 3+ just never gets used. I've tried adjusting it and just can't get it right. I'd like 2 to be your normal clearing speed, 1 to be for packed plow crap and 3 or 4 to be for clearing those ~2-3" dustings quickly.
    What is this auger kit?
    0 Not allowed!
  2. #1327
    Central MA
    Re: Snowblower
    What is this auger kit? - It is basically a set of 4 pliable paddle blade extensions that you bolt on to the impeller. I made a set out of an old truck mudflap. My old Ariens went from throwing snow 5-6 feet, to throwing heavy wet snow 20-25 feet! They can heat up (and wear down your housing!) if you make them fit too tightly, but they will eventually wear down to size.
    1 Not allowed!
  3. #1328
    Lifer wiggeywackyo's Avatar
    Feb 2009
    Medford
    Re: Snowblower
    Strangely enough, for the first time, my ST1032 had been running like a champ but 3/4 of the way through this morning, I heard a grinding noise, stopped the machine and noticed that the worm shaft looks crooked going into the gear box??? Any initial ideas? I'm hoping that it just lunched the brass gear.................
    0 Not allowed!
    LRRS 878 Clapped out Gixxah
  4. #1329
    Jan 2012
    Mass
    Re: Snowblower
    Quote Originally Posted by wiggeywackyo View Post
    U prob need to rebuild the gearbox or get a new one
    Sent from my SM-G960U using Tapatalk
    0 Not allowed!
  5. #1330
    Jan 2012
    Mass
    Re: Snowblower
    What is this auger kit? - It is basically a set of 4 pliable paddle blade extensions that you bolt on to the impeller. I made a set of of an old truck mudflap. My old Ariens went from throwing snow 5-6 feet, to throwing heavy wet snow 20-25 feet! They can heat up (and wear down your housing!) if you make them fit too tightly, but they will eventually wear down to size.
    That's why I use these
    Amazon.com : MTD 4 Pack Genuine 735-04033 Rubber Center Auger Pad Fit Bolens Craftsman Huskee : Garden & Outdoor
    And space them with a piece of cardboard from a cereal box..
    1 Not allowed!
  6. #1331
    Member Tom M's Avatar
    Dec 2012
    Re: Snowblower
    Sounds to me like your augers might be rusted onto the auger shaft so the shear pins wouldn't work. If the shear pins don't work the auger gearbox or drive shaft will break instead of the shear pins. I know of two people that happened to recently.
    This is why the augers usually have a grease fitting on them. Keep 'em greased if you can.
    0 Not allowed!
  7. #1332
    Re: Snowblower
    Your idle jet is plugged. Long brass jet, looks like it should be an external adjustment but it's not, unscrew it, clean, make sure you can see light through the tiny ports, reinstall and the surging should stop. if you look at the metal around the carb, you'll likely have a sticker over a hole that is perfectly placed to unscrew that jet without removing the carb from the machine or taking the tins off.
    0 Not allowed!
    771 Racing -=- FaceBook
    Backed by Heroic Racing Apparel
    A-ko - 1992 FZR400RR SP / Mistake - 1992 WR250ZD / Facade - 2003 YZF-R6 / 2000 LS650P
  8. #1333
    Re: Snowblower
    +1,000,000 on the mudflaps. i have this on all my machines. I would not go without even on a new machine
    0 Not allowed!
  9. #1334
    Re: Snowblower
    Along with breaking a lot of shear pins, the other thing I didn’t like about the Honda was the 19.5” high housing. A local guy sells an add-on housing which brings it up higher and squares off the front. First substantial snow in Boston this year, worked well.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
  10. #1335
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Snowblower
    ...and sacrificed width for more tons/hr.
    Buy the minimum width you can live with and the largest engine you can afford. When it comes to EOD piles, no one thinks "I wish I had saved money on a smaller engine!"
    0 Not allowed!
  11. #1336
    Re: Snowblower
    the reason I will never again own one that is not hydrostatic
    0 Not allowed!
  12. #1337
    Candia, NH
    Re: Snowblower
    I agree completely! Set your speed so that the snow load fully opens the governor and enjoy your machine working at its maximum capacity.
    0 Not allowed!
  13. #1338
    Lifer Falko's Avatar
    MoonTown
    Re: Snowblower
    I have the opposite problem I have with the bull, yesterday's snow I did in 4th gear out of 5. Only had to pump the clutch once at the end pass. 5th gear is not fast enough for transport.
    That's one thing I like about my old MTD track unit. I can set the height in transport, put it in 4th and lock down the drive handle, point it at my neighbor's driveway and send it on its way while I go grab my shovel. I can usually catch up before it hits something.
    0 Not allowed!
  14. #1339
    Re: Snowblower
    My kid joined me while we snowblowed the whole driveway last night. She was mesmerized.
    1 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Re: Snowblower
    anyone put on a smaller pulley wheel on the stage 2 side. been thinking of doing that to get more speed out of the stage 2 to throw wicked far and chuck more snow in relation to the forward speeds.
    0 Not allowed!
  16. #1341
    Seacoast NH
    Re: Snowblower
    Why stop there? Why not a BX with hydrostatic and a hydraulic thrower attached.. and maybe a cab too!
    0 Not allowed!
  17. #1342
    MoonTown
    Re: Snowblower
    There's several videos on that if you search. The two issues, horsepower, finding the correct belt to match the new pulley. Spinning the impeller faster will add more load to the engine. If you have excess power, it won't be an issue, if you don't you might have to sacrifice lbs/hr for throw distance. From what I've seen on the belt issue is auto parts stores don't carry umpteen thousand belt sizes anymore because modern cars are serpentine belts. Going in and just grabbing a handful of belts to find the one that fits is a difficult option. Best results have been at HVAC parts suppliers as those fan belts are the same and have a better selection.
    0 Not allowed!
  18. #1343
    Re: Snowblower
    can't just wrap a string around the pulley and measure?
    0 Not allowed!
  19. #1344
    MoonTown
    Re: Snowblower
    You can use a thick rope to get you close, but I've never had great success. But I'm not great at the measure twice cut once thing. I'm more the measure as many times as you want, you're still going to fuck it up and need extra stock...
    0 Not allowed!
