Page 68 of 69 FirstFirst ... 2848585960616263646566676869 LastLast
Results 1,676 to 1,700 of 1710
Snowblower
  1. #1676
    Re: Snowblower
    One guess what's wrong with my father-in-law's blower:]
    Tecumseh Snow King?
    If they are at all low on oil, rocking them back for the EOD pile often results in a broken con rod, which then punches out the case.
    ďIf at first you donít succeed - donít become a Paratrooper.Ē
  2. #1677
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Re: Snowblower
    No-good piece of shit one year-old snowblower won't start. Seems like it's not getting gas despite the fact I put Sta-Bil in it.
    Sigh...
    Stopped using that crap decades ago.
    Since then I store with TruFuel in everything, 100% satisfied since
    Lifer obsolete's Avatar
    Norf Sho
    Re: Snowblower
    Quote Originally Posted by zxme View Post
    Its expensive but I don't use my equipment enough to not use it but none of my stuff has failed to start because of fueling issues. I definitely recommend switching to anyone that hasn't.
    -Alex
  4. #1679
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Re: Snowblower
    Even my DRZ400sm gets the old gas sucked out every year and 2 cans of Trufuel.
    I93/495
    Re: Snowblower
    Man that thing looks like it blllllllllloooowwwwwwwwwwwwwws
    That it does. 1800 tons per hour. Actually a baby compared to the Oshkosh trucks. Those will move something like 8,000.
    Snowblower-received_647835683017063-jpg
    2012 Tiger 800 XC
  6. #1681
    Re: Snowblower
    Next door neighbor bought a new Ariens. Every year he couldn’t get it started. Never heard of Sta-Bil. So every year the dealer would pick it up and replace the carb.
    Before last winter gave him a couple gallons of no-Ethanol fuel, so it ran. Haven’t seen it yet, bet he used it in his mower.
  7. #1682
    Senior Member B440's Avatar
    Jul 2012
    Thompson, CT
    Re: Snowblower
    For awhile I was using Sunoco 260 GTX straight from the pumps at the race track; 98 octane, no lead, no ethanol, $11/gallon. Cheaper than the box store trufuel cans of any size.
    Recently I started removing the ethanol from 5 gallons of 93 octane pump fuel. I've got a few small engines sitting in the shed that have this fuel in it from leaf cleanup. This spring should be interesting when I go to start them.
    Snowblower-img_1550-jpg
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Re: Snowblower
    I have a snowblower up on the marketplace .
    250 to any NESR member in good standing .
    Original owner , think it’s 12 or so years old .
    https://www.facebook.com/marketplace...47810552063771
    TIMMYDUCK
  9. #1684
    Lifer golden chicken's Avatar
    Fitchburg, MA
    Re: Snowblower
    GC's pro tip: make sure the ignition switch is in the ON position before you spend an hour in the freezing garage trying to figure out why it won't start.
    8 Not allowed! Not allowed!
  10. #1685
    South Coast MAsshole
    Re: Snowblower
    pro tip #2...never turn the ignition switch off and never pull the key out...ever...just turn the gas valve and let it die...i've had the ignition switch freeze in the off position after i removed the key with an older single stage snow blower...i never touch it anymore now
    Point37s Garage Sale Thread
  11. #1686
    I93/495
    Re: Snowblower
    Screw Ariens. Someone needs this for their driveway.
    https://municibid.com/Listing/Detail...MSV-Snowblower
    2012 Tiger 800 XC
  12. #1687
    Haverhill, MA
    Re: Snowblower
    Bet that would make short work of nhbubba's driveway without bending his tractor up
    I93/495
    Re: Snowblower
    True. The auction will be closed for a year before he would make up his mind if it made sense or not though.
    2012 Tiger 800 XC
  14. #1689
    Re: Snowblower
    Shots fired!
    Jul 2012
    Thompson, CT
    Re: Snowblower
    My buddy has the Holder brand of this machine. Quite an amazing snow machine (heated cab, AWD, articulation, PTO snowblower), but purpose-built for sidewalks. Could use more width on it for residential use. Weighs at least 8000lbs so no parts will be cheap or easy to replace. And coming from a municipality, it will need major repairs to all hydraulics and the frame from salt use.
    Re: Snowblower
    Well, my budget Ariens 824 is now a single stage blower.
    A rock wedged itself between the auger and scoop and something in the gearcase let go. Hoping it's just a woodruff key...
    Re: Snowblower
    Pro tip #3: when you get a snow thrower, zip tie or safety wire the key to the machine so you can’t lose it!
  18. #1693
    I93/495
    Re: Snowblower
    Quote Originally Posted by B440 View Post
    I mostly posted that as a joke. Is a 50" blower really that much different then what most people would mount on a small tractor for driveway use though?
    2012 Tiger 800 XC
  19. #1694
    Fitchburg, MA
    Re: Snowblower
    Yes. That's how I kill the blower and in the winter I leave the key on. I must've turned it off last spring for whatever idiot reason made sense in my head at the time.
    Once I figured out it was a self-inflicted issue, I took the key into the house and wrote RUN and OFF on it with a sharpie, then put it back into the blower in the RUN position.
  20. #1695
    I93/495
    Re: Snowblower
    Shots fired!
    Nah. I'm the same way. Obsess and research every angle and then can't make up my mind in the end. Choice paralysis.
    2012 Tiger 800 XC
  21. #1696
    Re: Snowblower
    if you never turn it off you can't lose the key cause you can't pull it out
  22. #1697
    Re: Snowblower
    I always turn mine off by shutting the fuel off
  23. #1698
    Senior Member Philkinson's Avatar
    Jun 2012
    Warwick, RI
    Re: Snowblower
    What's this pulling out you speak of?
    now retired LLRS AM #642
  24. #1699
    Fitchburg, MA
    Re: Snowblower
    Can't seem to remove the key when it's in RUN, so I'll just leave it that way forever now.
  25. #1700
    Re: Snowblower
    Just unplug the wire from the switch. All it does is ground out when the key is pulled. Unplug it and you're back up and running.
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC / 2016 KTM 500XC W
