Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Best solution for waste oil & fluids storage / recycle in garage?
    Lifer golden chicken's Avatar
    Fitchburg, MA
    Re: Best solution for waste oil & fluids storage / recycle in garage?
    I have never tried it, but I wonder if you could pressurize it just enough to fill the hose and then open the top valve and let it siphon.
    But...yeah, everything carsick says is true: if you completely empty it while it still has pressure in it, it makes a big mess unless you have the hose end in a mostly empty large container.
    I love the mityvac. I almost exclusively do oil changes on cars/trucks with the mityvac these days. You always get 80-90% of the oil out, and no mess no crawling no stripping drain bolts bs. Plus I use it to evacuate other fluids too - diff fluids, t-case, old gas, you name it.
    You really use it to change oil?? I have used it to pull out old gas too, but you have to make sure you empty the container of it into something metal (or disposable) and leave the Mityvac open to evaporate. I ruined the rubber top stopper by leaving some stale gas in the bottom, not to mention the fire danger.
    But...yeah, everything carsick says is true.
    Quoted for posterity.
    xxaarraa
    Guest
    Yup, sucks the old oil right out of the dipstick. It gets 80% of the oil out that way, and with good high quality synthetic, I am never worried about the remaining 20% getting recycled. Mercedes dealerships have been doing this for years.
    Senior Member Viper897's Avatar
    Apr 2014
    Seacoast Maine
    Its already been said but I second race fuel jugs. You can usually snag a few after a race weekend. Best part they stack easily, don't require a dolly to move, and are 5 gallons per container so you can get rid of them locally. Oh and if you race you can bring the waste oil to the track for disposal to the hazmat building at the end of the north garages (I believe this is part of the garage rental fees)
