Page 28 of 28 FirstFirst ... 81819202122232425262728
Results 676 to 696 of 696
Sprinter build thread
  1. #676
    Re: Sprinter build thread
    Probably run better if y'all put diesel in it, not gas.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    Hah funny you mention that one of my friends was on a cross country trip in another friends sprinter. Middle of Iowa and they filled the tank with gas then drove 50+ miles. It basically destroyed the fuel system and motor as well as their diesel heater and cooksurface. They spent the next 6 months of the trip stopping at one Mercedes dealership or another trying to get things fixed. I think eventually they needed to put in a complete new motor and fuel system.....
    0 Not allowed!
  3. #678
    How many gallons in the tank?
    26.4. 100 liters. Reserve light comes on with 2.5 gallons/ 10.5 L.
    My first recorded tank was 22.6mpg. Lots of people do better but that’s great for city use.
    Insulation is shipped can’t wait, it’s loud on the highway.
    One of our guys put gas in a diesel Cruze. $1,700 repair.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
  4. #679
    Posting Freak joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    A friend of mine worked as a driver for Domino's Pizza back in the 1980s. This was back when Domino's actually owned all the delivery cars -- they were painted in a crazy Domino's paint scheme.
    He told me that as a fuel-saving measure, the company bought diesel Chevettes to deliver all the pizzas. He told me that the pizza drivers would fill them with gas more than once per month, and the repair costs were beyond crazy. I think they switched back to gas in less than a year.
    0 Not allowed!
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
  5. #680
    Still waiting on the insulation and some small parts (like the rear door upper striker plate, notorious for falling off) so continued inspection and cleaning.
    These diesels sometimes develop injector seal leaks. The name for the condition is overly dramatic, but it does create a mess and requires removal of the injectors. So wanted to check for myself: so far (147,000 miles) so good.
    Also cleaned up some of the metal surfaces that have what seems like varnish on them.
    Hit 400 miles on this half tank so seems to be doing better mpg-wise.
    0 Not allowed!
  6. #681
    Harlingen, Texas
    Ah, the black death! haha! Fortunately, at 222,000 miles the OM642 in my Jeep hasn't needed injector seals yet. I keep an eye out for any signs of leakage though.
    0 Not allowed!
  7. #682
    I’m getting random glow plug codes. They are notorious for one or more sticking in the head and breaking. I’m probably going to bring it to a shop (one recommendation is Banchworks in Providence) who does it all the time, and git ‘er done while its warm. Runs great otherwise so I’m assuming the injectors are bueno.
    Cargo floor was pretty rough, unsurprisingly.
    Painted it a medium gray, with textured deck paint.
    0 Not allowed!
  8. #683
    Ran into a “Gotcha” while getting ready to start installing L track. Bought some 1/4-20 flat head bolts and they stood proud of the countersunk holes.
    The deal is there are different standards for flat head screws. The aircraft industry typically uses a 100 head: that’s what L track is drilled for. Most standard screws are 82.
    The 100 1/4 bolts are usually 1/4-28 (UNF) versus 1/4-20 (UNC). Turns out 1/4-28 Rivnets are not as widely available as 1/4-20.
    Still evaluating but I think I’m going to buy an 82 Countersink and face the holes so I can use standard screws. There may not be enough material to drill down that much.
    Update: ordered 100 1/4-20 from McMaster.
    FYI Metric standard is 90
    0 Not allowed!
  9. #684
    Sorted through the screw issue: ordered 100 1/4-20 flat head screws. Also using the heavy wall threaded inserts from McMaster.
    Finished putting in the 20 Nutserts to replace the rivets used to hold down the floor. Putting down two layers of closed cell foam, then the OEM floor panel.
    I’d like to put down some of the coined rubber covering over it, but haven’t found any place that has a wide-enough roll.
    Probably going to use flanged track on the sidewalks, and tie the wall panels into it. This is the test fit.
    0 Not allowed!
  10. #685
    careful building up the floor too much. The insulation doesn't do much, but the lost headroom is a real drag.
    0 Not allowed!
    What replaced your van?
    0 Not allowed!
  12. #687
    Re: Sprinter build thread-(Pictures are back!)
    A longer van. With a full winnebago in it...
    1 Not allowed!
    Haverhill, MA
    Forgive me for chuckling at you complaining about losing headroom
    0 Not allowed!
  14. #689
    Ha! well, he has the low roof van. I know he can't stand up in it anyway, but losing 4 inches is a big deal... that's what she said anyway.
    0 Not allowed!
    I can’t stand up anyway but the minicell is only 0.25” thick.
    This is our fifth van and we have always insulated the floor. If for simplicity sake we say it’s a 10’ x 5’ x 5’ box, the floor would represent 20% of the surface area. Our experience is that drivetrain heat is disproportionately high in warm weather, and the floor cools down very quickly in cold weather.
    Stock there is just the thin layer of plywood and some tar paper-like underlayment.
    It didn’t seem particularly effective and didn’t fill the channels.
    We are going to fill in the channels with 0.30” foam (which does not raise the floor) then add a 0.25” solid sheet over that. Should be very effective against heat and noise. Along with Thinsulate for walls and roof, it’s the latest development.
    Still looking for a good tape to minimize thermal bridging. Have a couple to try.
    0 Not allowed!
  16. #691
    Travato? Which model is that?
    0 Not allowed!
  17. #692
    Yeah, it's a '19 Travato 59G
    1 Not allowed!
    Hell of a rig!
    Although it runs great, van is throwing various glow plug error codes. Bringing it to Banchwerks in Providence, RI Monday.
    Been installing Nutserts for the L track. A lot of Nutserts. Have the 13” Astro Pneumatic hand setter and while it works well, it takes some effort with the heavy wall 1/4” inserts I’m using.
    0 Not allowed!
  19. #694
    Fixed spare tire hanger bolts. Old ones were twisted and frozen. Had to drill out the heads to get them off. Put Nev’r Seize on the new ones.
    Installed seat swivel. So it’s an adventure van. Small “a.”
    1 Not allowed!
  20. #695
    Sprinter build thread-4a6464ee-f8d9-4270-b96c-33f2906313abMore minor progress. Like most cars the textured plastic holds dirt and is hard to clean. Got a product called Spray Nine and a bristle brush - good as new!
    Attached Thumbnails Attached Thumbnails Sprinter build thread-5732f00e-7194-404d-89c5-66069f853527
    1 Not allowed!
  21. #696
    Some good progress this weekend. Removed the center console to pull out the front floor mat and clean it.
    Before.
    After.
    Installed minicell foam under the floor. Another layer went over this.
    And reinstalled the stock floor after repainting with two layers of textured deck paint. Floor is held down with 20 1/4-20 flat head screws threaded into heavy wall 1/4-20 Nutserts.
    1 Not allowed!
