Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
new struts worth it?
    Oct 2007
    Milton, MA
    Re: new struts worth it?
    A big part of that is the run-flat tires they spec for their cars. It's not neccarisly that it's supposed to be 'sporty', it's just a consequence of ultra-stiff sidewalls. But I have no doubt their marketing department points out it happens to enhances steering response and 'road feel'.
    The tires on the car now aren't runflats, are they?
    No - neither were the OEMs (though they were low profile).
    0 Not allowed!
    Strut tower mounts.
    That thick piece of rubber sandwiched by metal plates with studs. One side bolts to the car, the other side bolts to the strut assembly.
    Helps to quell vibrations in the car. If those go, you'll have metal on metal transmitting every tiny hit through the suspension into the cab.
    It's a guess.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Harsh ride is usually something that's over damped and/ or over sprung.
    In the case of worn out components resulting in a harsh ride, check for collapsed spring(s), broken spring seat(s), collapsed strut mount
    0 Not allowed!
