Page 56 of 62 FirstFirst ... 16364647484950515253545556575859606162 LastLast
Results 1,376 to 1,400 of 1541
Let's talk trucks
  1. #1376
    Lifer Falko's Avatar
    MoonTown
    Re: Let's talk trucks
    New Tundra coming next year will supposedly have a twin turbo V6. I hope they actually make a truck V6 and just not strap twin twirlers on their standard 3.5. I can't imagine Toyota doing that, but given the R&D and updates they give the Tundra, hard to tell. If you want a truck to do truck stuff, the Tundra is hard to beat. If you want fluff with your truck stuff, F150 is hard to beat. I've never been huge on Toyota interiors, but the Tundra suffices for my needs, not my wants, but my needs.
    0 Not allowed!
  2. #1377
    TWINS! xrocket21's Avatar
    Central Maine
    yeah, but how does it SOUND?
    2 Not allowed!
  3. #1378
    MoonTown
    better than a Prius...
    0 Not allowed!
  4. #1379
    Central Maine
    Chirpin gears and pullin brodies
    0 Not allowed!
  5. #1380
    I93/495
    I'm astounded at how capable these new 1/2 ton trucks are now. I don't have to wonder if I'd be satisfied with "just" the 5.3l anymore. Truck was pretty much maxxed out weight wise and it took it like a champ.
    Let's talk trucks-truck-jpg
    4 Not allowed!
    2012 Tiger 800, 2007 DR650, 2012 WR250R
  6. #1381
    Hey I know that truck
    1 Not allowed!
  7. #1382
    Meriden, Ct
    Anyone actually spent any time in one of the new bowtie half tons? You know, after the "let's ditch the dated early 2000's styling and make it so half of America thinks it's ugly as hell" change for 2019. Their market share has lost ground to Dodge, so perhaps they are looking to sell them for a more reasonable amount later this year.
    Was considering an F-150 with the 3.5l twin whistlers until I started reading numerous horror stories about that 10 speed trans. And a LOT of super low mileage 1 or 2 year old ones that have been traded in at other brands' dealerships.
    I might know a thing or 2 about the new Chevy Silverado... hit me up with questions.
    9-10k lbs
    That's a big ask of a half ton. It'll do it... but I wouldn't do it on the regular.
    Chevy with a 5.3l gives you 9700# tow rating. You can get higher with the 6.2l and the right configuration. But 10klbs is never fun in a half ton.
    1 Not allowed!
  8. #1383
    Seacoast NH
    This weekend @ the local home center I watched a couple guys having a pallet of cinder blocks loaded into the back of their GM half-ton.
    I haven't seen tires bulge that badly in a while. I got the hell out of there as I wanted to be on the road ahead of those fools. Wondering how far (or if) they made it.
    0 Not allowed!
  9. #1384
    I93/495
    After towing close to that with the 5.3l I concur. It will do it and be acceptable, but I wouldn't be comfortable pulling that on the regular. I'm not really sure the 6.2 would make a difference either. The drama from towing that weight with a "small" truck isn't from lack of power. Yeah, more power is always nice, but the truck did what I thought was acceptable given the work load and I never had it pinned and thinking, fuck me, this thing NEEDS more. I hauled up and over Franconia notch too. Out west with longer and more frequent steep grades, sure, more power would come in handy. Out here, it's more want vs. need in my mind. The truck still pulled grades better then the 98 K1500 I had with just a car on the trailer.
    I also normally tow with a tuned diesel that barely knows there's a car back there so I've been pretty spoiled in the power dept. I was still quite satisfied with the 5.3L.
    Interesting. I wonder what that weighed. Payload is 1800+ on them. I was loaded pretty close to the limits all around and the tires weren't bulging. Pressures were set correctly though.
    0 Not allowed!
  10. #1385
    Member jimmycapp's Avatar
    Oct 2008
    NW CT
    2019 with 5.3
    Max Payload
    (lb. / kg):
    REGULAR CAB
    2280 / 1034 (2WD)
    2160 / 980 (4WD)
    DOUBLE CAB
    2190 / 993 (2WD)
    2180 / 989 (4WD)
    CREW CAB
    2180 / 989 (2WD)
    2130 / 966 (4WD)
    0 Not allowed!
  11. #1386
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    As noted there is so much more to pulling and carrying a heavy load than motor. Tires, suspension, and brakes are key as is the weight of the tow rig.
    10 ply tires and air bags can help a lot but for every day heavy haul the 1 ton pickups will be happier day in and day out.
    My Tundra does pretty well with 40 PSI in the bags and 10 ply tires for most things. Not sure I would want a steady diet of 9K though.
    That said today's 1/2 ton trucks are so much more capable than those of yesteryear. I remember my 1990 F150 with 150HP and puny brakes was pretty entertaining with a 5k pound load in tow. Yikes.
    0 Not allowed!
  12. #1387
    Central Maine
    Got a bigger intercooler for the raptor
    The ports were lined up like shit
    So I cleaned them up
    Partway done
    New vs old. New is 50% bigger
    Jacking it into place
    3 Not allowed!
  13. #1388
    MoonTown
    Years ago when i worked at home depot, we had a folder at the loading station with releases people had to sign if we loaded any palletized material into a bed or at any time we felt the load was too high for the given vehicle.
    Notable occurrences,
    Two foot high stack of plywood on a small boat trailer (like the ones made for an aluminum row boat, 8" wheels, crushed it)
    Pallet of brick in a Ranger, broke a spring shackle or something under there went boom, guy still drove it home.
    Huge load of pressure treat into an F-150. only bottomed it out, bulged the tires, drove it away
    I was never called into a court case regarding these acts so I assume there was no drama. (Except the boat trailer, it didn't go anywhere.)
    2 Not allowed!
  14. #1389
    Central Maine
    http://www.teamjdm.com has a familiar looking truck on their front page now...
    0 Not allowed!
  15. #1390
    Saw 'jdm' in the url and thought it must mean 'Japanese Domestic Market' which lead to quite the surprise when I saw what they make kit for.
    0 Not allowed!
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
  16. #1391
    Central Maine
    JDM 4 lyfe y0
    If it ain't a type R, it ain't a tyte car
    2 Not allowed!
  17. #1392
    I93/495
    JDM 4 lyfe y0
    When are you gonna embrace the stance life on your truck?
    1 Not allowed!
  18. #1393
    Central Maine
    Who makes the best 20x11" wheel?
    1 Not allowed!
  19. #1394
    Central Maine
    Dirt drags at the fair tonight. Got caught sleeping, but reeled him in.
    Gen 1 V8 with a Procharger supercharger.
    Double Elimination, I got knocked out the 3rd round by the eventual winner, a diesel pulling truck, and the 4th round by an STI.
    1 Not allowed!
  20. #1395
    Central Maine
    1 Not allowed!
  21. #1396
    Looks fun, but that runoff is a bitch, eh? Understeer!!!
    Did you air down your tires a little for traction?
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    2000 Honda CBR929RR
    Central Maine
    I aired down from 38 to 20 psi.
    I also dumped in 5 gallons of 98 octane for a little help with keeping the truck from pulling any timing.
    Baja mode, manual tranny, rear end locked, stability control and traction control off.
    Yeah, lotta pucker in the shutdown area...
    0 Not allowed!
  23. #1398
    MoonTown
    Given the clientele at the local suspension shop getting new ball joints, BRP offers the most leverage...
    0 Not allowed!
  24. #1399
    Central Maine
    I would need a flat brim hat for sure
    Attached Thumbnails Attached Thumbnails Let's talk trucks-3d72f264b0cf2e7ad14d4eafd894c101fb52afd6e68f74af079d2ff93a495be3-jpg
    0 Not allowed!
  25. #1400
    MoonTown
    Don't forget the Monster star on the side of your truck. Preferably in lime green...
    0 Not allowed!
