Page 66 of 66 FirstFirst ... 26465657585960616263646566
Results 1,626 to 1,649 of 1649
Let's talk trucks
  1. #1626
    Senior Member jimmycapp's Avatar
    Oct 2008
    NW CT
    Re: Let's talk trucks
    Anyone have recommendations on rust prevention? Current vehicle is starting to pop some rust. It’s a 2007 but it’s New England. I can see rust forming underneath on the floor pan joints as well. In the market for a 2015 ish tundra and want to limit the rusting.
    Oct 2008
    NW CT
    Yes. This is the one I had in a K1500. Two sport bikes fit ok. 3 dirty bikes should be good to go.
    https://ccrsport.com/ccr-sport-bed-b...-full-size-60/
    Perfect. Thanks! I’m guess I would just have to mount it a little lower if I want a bed cover?
    I93/495
    You can mount it where you want since you're drilling the holes. The truck I had it on didn't have a cover, but my current truck and cover wouldn't be a problem for it.
    2012 Tiger 800 XC
  4. #1629
    Start hitting those areas with Fluid Film to stop the rust from progressing.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
  5. #1630
    Anyone have recommendations on rust prevention? Current vehicle is starting to pop some rust. Itís a 2007 but itís New England. I can see rust forming underneath on the floor pan joints as well. In the market for a 2015 ish tundra and want to limit the rusting.
    check out NH Oil, i had my Jeep done in late June by Mass Mobile Undercoating in Grafton. they did a fantastic job, external and internal frame areas, etc. are coated.
    Let's talk trucks-jeep-nhoil-jpg
    Oct 2008
    NW CT
    I was watching their videos this morning. You doing that annually? How much $$?
    Is it a specific brand? Can you get it with center wheel locator as well?
    Mine was black widow brand. There are 3 bike setups in this and other brands.
    Used it yesterday holy crap is it awesome compared to not having one. I think i could jump the truck without the bike tipping over.
    That is pretty slick..
    No flex/bend in the front of the bed either! for 80 bucks I highly recommend it.
    they consider it an annual treatment but i'm going to see if i can get two seasons out of it. i'll spot treat dry areas with Fluid Film, have it on the shelf already. paid $240.
    Oct 2008
    NW CT
    What is that little bracket sticking out above the center hook?
    That's part of my tonneau mounting system.
    Debating doing this on my new Taco. Does everything stick to it?
    Yes, which is intentional. Best practice is to fluid film the undercarriage and then go for a slow drive on a dusty dirt road. The dust sticks to the oil, and forms a layer that resits water/etc clearing it off down the line.
  15. #1640
    my buddy Chris had his new(ish) Chevy PU done, i was convinced after seeing it. NH Oil stays wet but does 'cure' a bit over time, thickens a little but not like the wax product line. mine dripped a lot, but i knew that would happen having it done in summer heat.
    as for everything sticking to it, oddly, no. like Josh said, dust will sort of coat it but mine has stayed a nice factory black looking coating but not full of dirt or anything. the wet shine dulled down a bit as well. i've been off-road but not in deep mud, remains to be seen how it will handle a spray down. supposed to be fine under normal water pressures.
    since your Taco is brand new, you should look into their 'wax 'n oil' product for new vehicles. sounds like an even better option.
    Newbie
    Aug 2020
    Sandwich
    Fluid film...but re-application is needed. Can easily find it in Maine as it's used on snowplow's and such as well...
    edit: I see it was already posted...
  17. #1642
    Not really a truck but still kind of cool...
    Ford actually included a factory dig on the Bronco.
    TWINS! xrocket21's Avatar
    Central Maine
    Thats fucking sick
    new raptor is gonna have a trailing arm or linked rear and possibly a hybrid assist! Steppin it up!
    The Jeep is capable of digging like that as well, I suspect it'll magically appear in software soon. As it is right now if I unlock my ECU I can map the four back steering wheel buttons to the matching wheels and on demand individually lock'em.
  20. #1645
    Then why has Jeep never enabled it? Seems like an easy addition according to you, no?
    Same reason I can't click the lockers on in 2H or 4H, etc: liability concerns.
  22. #1647
    Yet Ford is doing it?
    We don't know what will be required to get into that mode, or how much control the end user will have of it yet, etc. Again, for most modern TC setups this is just a software thing given cars already have independent control of brake calipers, and as noted it's already been shown doable on the Jeep in particular. Looking at the Tazer, they use the independent brake control as a software linelock on other Dodge/Jeep stuff like Chargers too. https://www.zautomotive.com/product/tazer-jl-mini/ has a list of some of the stuff that can be done with just a software unlock.
  24. #1649
    Fully electric off roaders will be interesting. If you've got independent wheel control you can do more than just a drag for a dig, throw that wheel straight up into reverse! Mercedes has been playing with that on road cars, able to maintain stupid speed and control in the rain by controlling power to each wheel, including using back torque at times.
