Results 1 to 25 of 31
Tractor guys - have a question moving granite steps
    High maintenance priss
    Central MA
    I have a deck/3-season room which was built on top of existing granite steps. I'd like to re-purpose these steps, so I'm considering if I can drag these granite block steps out from under the deck. The pieces look to be 6'l x 8" h x 12" d. There are 3 pieces total: one is on the ground by itself and the other two are stacked to form the 2nd step.
    Is this something which can be reasonably done? Or is this way more trouble than its worth?
    Of course it's not totally straight-forward. There is only about 14"h clearance between joists and ground (dirt) but it is possible to crawl to them. The slabs are roughly 8' from the side of the deck where I'd want to slide them out. The top step is up in the joist cavity (the contractor framed the deck around it...), so the bottom slab would probably have to be pulled out from underneath the top one....a trick in itself.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: Tractor guys - have a question moving granite steps
    I don't have anything valuable to add... but I kinda want to be the guy to drop the inevitable "Just get a couple guys" comment.
    How much does each weigh approximately? (someone else google it, I don't want to)
    Fuck it, I did the math. 168lb per cubic foot, approx 4 cubic feet per step. About 672lbs per step. Manageable to drag, especially if you can slide it on some wet plywood or 2x10's.
    And do you have something you can use as a winch point?
    Tractor may not be necessary. Strap/chain and a come-a-long could work wonders. Though even a useless homeowner toy tractor could pull that on some hard surface fairly easily.
    Also, are you sure the steps aren't drilled and re-bar'd in between them to hold them in place?
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Tie a rope to your SUV bumper?
    Ok, that wasn't helpful. I all seriousness dig out enough earth to insert two 2x6 boards under the bottom step parallel like train tracks to drag the stone on. you can wet it, but don't likely need to. wrap a chain or serious strap around the bottom step and pull it out with your tractor. careful not to loop out the tractor in a wheelie.
    Central MA
    Yeah, I believe these are about 750lbs and run $300-ish (plus delivery) each.
    I don't have a natural anchor point but probably could sneak my truck up to the spot. I thought about a come-along but not aware of any tool or method to attach to the granite. I figured some sort of clamping device like they use for logging? I don't have a tractor - I'm just figuring out if its worth finding someone.
    Hey guys, hold my beer...
    Lifer Falko's Avatar
    MoonTown
    I used 4-lo in my old SUV to pull some pretty big shrubs once. Did it with ease.
    I think it would be easier if you got one end and pulled it around and then pulled it out long ways, instead of cross ways. Get a two strap and a pry bar with wedges, you should be able to lift one side of the stone and get a loop around it. Do both sides if you want to pull it out that way. In no way get your fingers in there when doing it, I don't want to be reading about some jamoke who had to chew his hand off to get himself free from a couple of stone henge relics. I've done something similar with a come-along.
    Central MA
    Long-ways is the way it would have to come out. If you think a loop will cinch up enough to hold the stone while pulling then it's something I may give a try. I'll post pics of the broken tow strap thru my truck's rear window this weekend...
    drill a hole, install an expansion bolt, and hook onto it with a chain and pull
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    +1
    I worked with my step dad for a summer, as a laborer, for a masonry restoration co. When they lift stones that you can't get a strap around they drill 2 holes at opposing angles and insert pins to hook onto. A hammer drill makes very short work of it. Be sure to wear atleast a dust mask because granite dust is just as bad as asbestos to breathe in.
    Get some 1-1/2 or 2” pipes, put down a plank, and do it like the Eqyptians.
    Our Kubota L3200 worthless toy/overgrown lawnmower has SSQD forklift tines and can lift 1400 lbs 8’. We move rocks around all the time, and it’s given me a lot of respect for those farmers who built all those rock walls by hand. But unless you were moving a substantial number of them a significant distance, can’t imagine it would be worth hiring a tractor.
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
    Quote Originally Posted by myzx6 View Post
    now ya tell me
    Lifer obsolete's Avatar
    Norf Sho
    I used a few wooden broom handles to roll em on and another rock as a pivot point to rotate them.
    -Alex
    Build a massive canal system to float the blocks around?
    -Clayton
    2006 Suzuki SV650
    MoonTown
    No, I think he means you need to go conquer a smaller feeble nation and take their people as slaves to do your work. Canada is kind of close I guess...
    Lifer loudbeard's Avatar
    Yes but you don’t have to conquer the Canadians, just ask them nicely and they’ll be happy to help.
    Pics would be helpful but based on your description it sounds to me like a come along and some tow straps are going to be key here. Depending on a few factors, you might consider using lengths of 2x10 to reduce friction however you might end up fighting with the stone to get up onto the board in the first place.
    Once they are clear of obstruction, they can be moved in whatever way your heart desires.
    If this is something you want done by a hired hand, my schedule is reasonably light the next few weeks. Send PM if you want to set something up.
    South Coast MAsshole
    ^^^these...pieces of pipe on top of flat boards for runners will work well...moved an 8'x8' shed this way as well as some large rock...had to build a wood sled for the rock...i used a strap and a come along to get the rock out of the hole though...and if you just want to get rid of them...drill holes in them and get a bucket of Dexpan (expansive grout)
    Point37s Garage Sale Thread
    I've never used Dexpan, thought about it though, I have an iceberg in my driveway.
    I do have a coffee can full of feathers & wedges I have acquired over the years, I've tried my hand and cutting granite, but it is hard labor, even with a power hammer drill
    i did 2 rocks like that...rented the drill and bit at home depot and went to town...blew out the holes with the air compressor...mixed the dexpan and poured...both took a couple days to pop after the dexpan was poured...made the pieces much more manageable to move by hand
    Central MA
    Drilling a hole or two in the side of the granite isn't a big deal.
    Stud/Sleeve/Drop-In anchors seem to be heaviest duty (link). No specs on strength from that site. About what size should I be looking for to avoid sending a 900mph projectile into low-earth orbit? Some quick googling shows that even a 1/2" anchor at 4"+ would be more than enough...sound about right?
    Bergs - if I'm unsuccessful I'll let ya know.
    you can't wrap a chain around them or a strap?...do you have to drill?...a photo would help
    Central MA
    I might be able to strap them but it's tight clearance. That why i was originally thinking of those friction clamps. I meant to mention in my last post: I will be getting pictures.
    Yes, I have a rotary hammer.
    I would really like to see this operation.
    Bet the Canadians will sing while they work. It would be like Bridge On The River Kwai, only with less torture.
