Page 47 of 47 FirstFirst ... 7273738394041424344454647
Results 1,151 to 1,169 of 1169
Tractors - Educate me
  1. #1151
    Re: Tractors - Educate me
    Possible air bubble/cavitation due to the thickening of the hydraulic oil due to temp?
    Or, you had water in the system in an unimportant location, it melted from the previous use, but froze in a much worse spot this time (like in the pump, pickup, filter, or controls).
    Can you drag it into your barn to let it thaw?
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    your water theory sounds most plausible, stabilizers are down, boom and dipper are stretched out, bucket is half curled resting on ground, all at about 20 degree alignment from the toe-hoe axis..... drag it, no it don't move without a much bigger machine
    1. wait for a warm day
    2. build a campfire under it
    0 Not allowed!
  3. #1153
    Lifer ZX-12R's Avatar
    Candia, NH
    Does the tow-hoe use a fixed displacement pump with open center valves? If so, can you tell if oil is circulating in the tank?
    0 Not allowed!
  4. #1154
    Lifer Falko's Avatar
    MoonTown
    If you have an open system where the pump pulls from a tank, you can get hydraulic gumming from the low temps. The pump will not pull any fluid due to the viscosity. Was the hoe stored inside the day before when you got it out?
    0 Not allowed!
  5. #1155
    Sounds like you could use a tractor to pick that thing up and bring it into the barn.
    The other possibility is that your reservoir is too low if you are at max extension for a lot of those cylinders. Less likely, but can't hurt to take a look. Pull the filter and see if there is significant blockage as well.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Any chance it's simply frozen to the ground?
    And did you try 2wd?
    0 Not allowed!
  7. #1157
    I would need a barn to bring it into, my "barn" is still set up as office, and loft is 100 years of survey records.
    the way it is stretched out, it would be awkward to move, would require a 225CAT sized excavator, and would only end up in the way....it's stretched out, but out of the way, it will stay where it is till I get the hydraulics running. It needs a filter and fluid change anyway.
    0 Not allowed!
  8. #1158
    gosh, I didn't think of 2wd
    yes, frozen a bit, but the bucket I just resting on the ground, not frozen from curling
    0 Not allowed!
  9. #1159
    Then I'm thinking water in the system. Should have a day soon where it'll get thawed, or close to it.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    I picked up a filter and a pail of fluid, (specs say is only takes 5 gallons) and just haven't got to it. in the meantime, I've had a couple leaks (a couple of the hoses tend to loosen) I have used some, so, I gotta buy another pail
    the pia is that there is no drain plug in the reservoir, gotta disconnect the lower hydraulic hose (not an easy task due to the short length to bend it out of the way). I'm thinking I want to drill a drain plug hole, tap it and put a drain plug in
    0 Not allowed!
  11. #1161
    Look into a boat oil change pump.
    They're designed to pull engine oil through the dipstick. Might be helpful in pulling hydro fluid from the reservoir.
    1 Not allowed!
  12. #1162
    Def helpful when the oil runs easy, but I'd worry about how well it would work with the cold hydraulic oil being as thick as it is. The suction tube is tiny which makes it all the harder to pull molasses through. I did a diff/trans/transfer case fluid change using a manual plunger style oil sucker with a 1/2" hose when the temp was in the teens previously. Misery. If he can get the fluid warm, it should work well.
    You need heat, Randy. Got a propane bullet heater and some scraps of plywood to box the heat in?
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    molasses?, it's only 10w, hydraulic fluid, not gear oil
    propane heater... nope, but I got a 175,000 btu kerosene heater, maybe I could built a tent
    0 Not allowed!
  14. #1164
    this is my Toe-Hoe, marketed as "Muscle Man" in UK, and "Cricket" in US & Canada
    Tow-Hoe, Muscleman, Digger, Excavator, Backhoe
    0 Not allowed!
  15. #1165
    Ense petit placidam sandman's Avatar
    sema
    dump some 911 diesel fuel conditioner in.
    throw a tarp over it with a tiger torch or your kero heater.
    id carefully use a propane torch on some stuff with it running and the 911
    I've done a fire under equipment before but only on something really big like a 3-5 yard loader.
    tiger torch and a tarp works really well so does the 911
    0 Not allowed!
    jim
    "Molon labe"
  16. #1166
    Randy,
    I'm around if you need equipment on site.
    Not sure how critical your situation but figured I'd throw the option out there.
    0 Not allowed!
  17. #1167
    Randy,
    it's not critical, infact, more out of way than where I had it stored for the winter, I'd just like to replace the fill over my septic tank cover, and return it to transport mode (requires lifting each side and moving the wheels to the rear axis, and stabilizer to the front axis using the boom), then I'd leave it parked right where it is, I can get at it with my UTV
    0 Not allowed!
  18. #1168
    The worthless toy/overgrown garden tractor came in handy today, and glad we added chains this year.
    Lowes was delivering a new fridge. The truck was coming from Tilton so I figured it would be something setup up for snowy roads. Silly me: they showed up in a Big rental truck - with well-worn rear tires. He couldn’t make it up the hill, and spun the rear wheels sideways so he couldn’t back up for another run.
    Hooked a chain up and pulled him right up to the front door.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
  19. #1169
    TWINS! xrocket21's Avatar
    Central Maine
    I have pondered buying a lathe, but just one more of too many hobbies, I have a friend who makes bowls. He donates them to fundraisers in the professional associations, over the years, I have managed to win 4. H uses a lot of birch, but whatever species, he always uses old stumps, big knots, burls, etc, to make bowls that have grain or spauling rot for character
    Attachment 50222
    Ive got some ShopSmiths with the lathe option and knives I need to move after my dad passed....
    0 Not allowed!
  1. Tractors
    By RandyO in forum Off-Topic
    Last Post: 11-28-16, 08:55 AM
  2. Monsters: Educate Me
    By Pittenger5 in forum General Bike Related
    Last Post: 10-26-11, 10:13 PM
  3. Educate me on MX Gear
    By nt650hawk in forum Dirty Bastards
    Last Post: 09-06-11, 09:16 AM
  4. Snowmobiles - Educate Me
    By highsider in forum Off-Topic
    Last Post: 11-24-09, 06:28 PM
  5. Educate Me- Exhaust Systems
    By McBiggity in forum Bike Maintenance
    Last Post: 07-28-03, 11:52 AM
