Page 70 of 71 FirstFirst ... 3050606162636465666768697071 LastLast
Results 1,726 to 1,750 of 1755
Tractors - Educate me
  1. #1726
    Re: Tractors - Educate me
    It has its own subframe that bolts to the tractor's chassis. It looks like the weld that goes across the main rectangular tube that holds the vertical supports is what cracked and tore. It wouldn't be hard to weld on a fishplate and strengthen the joint considerably.
    There are a number of similar reports on the Kioti group on FaceBook. A lot of them blow off the dealer and have it welded commercially.
    If stupidity got us into this mess, why canít it get us out?
    Will Rogers
  2. #1727
    why the box grader, and not a york rake or a front runner https://ruralhometech.com/the-front-runner/
    i like idea IF i had the opportunity but i would have to get a plow attachment
  3. #1728
    hmmm 0% on kubota .. TLB series tractors...
  4. #1729
    Anyone have any leads on mini excavators?
    I missed out on "the one" last week because I was working. It was perfect....8000lbs, cab, full HVAC, hydro thumb and it sold the day before I called about it.
    Also, has anyone ever heard of (or dealt with) Mahoney Equipment in Sutton, MA?
    If you get one I’ll hire you for a couple jobs.
    Will Rogers
  6. #1731
    Ense petit placidam sandman's Avatar
    sema
    maybe try leasing one for a while to see how it goes?
    what sort of budget 40-50k?
    jim
    "Molon labe"
  7. #1732
    https://www.facebook.com/marketplace...6083799752229/
    I donít know anything about it. Just saw it on FB.
    I donít know Mahoney either but Iím close enough if you want me to run over for you.
    Older Kioti KL1231 - 1200 hours for $11K
    https://www.facebook.com/marketplace...7188163781402/
    Quote Originally Posted by sandman View Post
    Not interested in leasing.
    The budget is somewhat fluid in the sense that I'd rather find the right machine however the goal is to be 30 or less.
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Good day out on the tractor.
    Cant wait for my chipper to show up .
    Attached Thumbnails Attached Thumbnails Tractors - Educate me-img_6660-jpg
    TIMMYDUCK
  11. #1736
    ..You can borrow ours if you are a desperate man....
    Attached Thumbnails Attached Thumbnails Tractors - Educate me-b44a06fd-7149-4003-a161-c0f6f5260992
    Will Rogers
  12. #1737
    Lifer ZX-12R's Avatar
    Candia, NH
    Still waiting on my backhoe and grapple. In the interim, I've been learning how to use the Ratchet Rake and I've been surprised at what I've been able to pull out of the ground with it! It's absolutely worth the money.
    I've also decided that I'm in the market for an equipment hauling trailer. Trying to find something that is at least 16', has 8,000lbs payload, and weighs under 3,000lbs.
    Tractors - Educate me-kioti_ratchet_rake-jpg
  13. #1738
    Seacoast NH
    Your guy is completely wiped out. At present I do not think they have a single open station machine in stock.
    Actually all Kioti dealers are wiped out. Some Kubota dealers are too. From what I've seen it is a damned good summer to be in the business of selling tractors.
    I had a similar thought about trailers for a few minutes recently. I was pretty impressed with some of the stuff I saw on the website at REP Enterprises in Greenland. Unfortunately I think this is a seasonal game and they have sold most of their inventory off to make space for plows and sanders.
    They had some really nice looking all aluminum trailers that weren't as bad as I was expecting price wise. Given I was looking for something smaller; in the 10-12' range. I was trying to figure out how to pull off carrying ~2500 lbs of machine on a single axle trailer. I've decided it is possible, but only barely with no comfort margin.
    Any tips for using that rake? I read many pages back where Bergs advised to never forward drag with the bucket curl cylinders fully extended.
    I93/495
    Used car haulers pop up on Craigslist all the time for $1500 to $2000. That will carry the 2500 pounds no problem but still be on the lighter side. Might be worth considering over a single axle if open decks are what you're looking for
    On the other hand, a real deck over with 5k+ axles seems pretty rare on CL unless it's pretty beat. That one is probably a better buy new. There a trailer for 5k on there now but it looks rough for the price in my mind.
    2012 Tiger 800 XC
  15. #1740
    Candia, NH
    I've had my best results when dragging backwards. I push the downward facing tines into the dirt just past the rock and use the loader to just barely lift the front wheels off the ground. I pull backwards until I spin and slowly raise the loader hoping some of the teeth get a grip. I'll reposition and try different angles with the bucket until it grabs and eventually I can roll the rock out of the ground. You can see from the scratch marks on the rock that it took some coaxing to get it out of the ground.
    I measured the rock and it has a volume of about 13ft≥ which puts its weight around 2275lbs.
  16. #1741
    We use the forks to pop out rocks, usually.
    Was surprised to learn that many tractor owners didn’t know about the “float” function. Essential for snow plowing and useful for many other tasks.
    Will Rogers
  17. #1742
    Candia, NH
    Now I'm excited. I just got notification that my grapple is shipping today!
  18. #1743
    Hydraulics already installed?
    Will Rogers
  19. #1744
    Seacoast NH
    Candia, NH
    I had the 3rd function kit installed before they delivered the tractor.
  21. #1746
    Seacoast NH
    I feel like I needed to see this tip.
    Feb 2003
    I don't quite know all the details on this one yet .
    But here is a 100 hp Deere with a 553 loader frame and grapple.
    It's going to be well under $20,000 if anyone might be interested .
    Attached Thumbnails Attached Thumbnails Tractors - Educate me-img_6675-jpg
    TIMMYDUCK
  23. #1748
    Lifer Falko's Avatar
    MoonTown
    It's pretty amazing how much tractor for the money you can get in the used market when you get into the bigger sizes.
  24. #1749
    with a ton of hours
  25. #1750
    MoonTown
    with a ton of hours
    I assume that subjective unless you've figured out how to weigh time.
  1. Tractors
    By RandyO in forum Off-Topic
    Last Post: 11-28-16, 08:55 AM
  2. Monsters: Educate Me
    By Pittenger5 in forum General Bike Related
    Last Post: 10-26-11, 10:13 PM
  3. Educate me on MX Gear
    By nt650hawk in forum Dirty Bastards
    Last Post: 09-06-11, 09:16 AM
  4. Snowmobiles - Educate Me
    By highsider in forum Off-Topic
    Last Post: 11-24-09, 06:28 PM
  5. Educate Me- Exhaust Systems
    By McBiggity in forum Bike Maintenance
    Last Post: 07-28-03, 11:52 AM
