Page 77 of 78 FirstFirst ... 3757676869707172737475767778 LastLast
Results 1,901 to 1,925 of 1943
Tractors - Educate me
  1. #1901
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Tractors - Educate me
    I was going to drop mine on a pallet or some lumber and tarp it. I finally did a remove and reinstall cycle with the hoe because I needed some extra maneuverability for a project and I didn't find that it was that much effort to get it back on. I've heard plenty of horror stories but it wasn't that bad in my book and I'll certainly get faster at it with some practice.
    Speaking of tarps, my cover came in and it's pretty damn solid. It weighs close to 40lbs! I'm probably going to take the bucket level indicator off so it doesn't stab it. I've tried to make myself look at it and use it but I never do.
  2. #1902
    Saved the giant piece of shrink wrap plastic from the boat to wrap the mower and cover trailer.
    If you get a thumbs down from me, pm me, it was inadvertent
  3. #1903
    Lifer Falko's Avatar
    MoonTown
    you can hit it with heat and it will still shrink.
  4. #1904
    Candia, NH
    Punched a stick through the grill yet? That’s how you know break in is complete....
    Nothing through the grill yet but I did have one of the rocks from my yard roll off the pile while I was trying to flip it over and it slammed into the front guard. Scratched the leading edge of the paint up but that was about it. I was thankful the guard was there!
    For scale, my pallet forks are 48" and are sitting about a foot away from the stone wall. I'm not sure what I'm going to do with them once I finish pulling the rest from my yard. About half of the rocks were too heavy to lift and had to be rolled end over end to get to the pile.
    I'm getting much more proficient at breaking large rocks. I used seven wedges on the first split and tried to see if I can get away with fewer on the second split. You can use fewer but I had to switch to using both hands to swing the hammer.
    Some of these rocks are leaving gigantic craters. I'm hoping to have the rest of the yard de-rocked by winter and maybe get a couple triaxles of gravel delivered to start filling in everything and fixing the grade.
    Tractors - Educate me-rock_pile-jpg Tractors - Educate me-rock_split-jpg Tractors - Educate me-crater-jpg
  5. #1905
    Candia, NH
    I think it was here that someone asked how long the masonry bits last drilling into granite. I noticed on Saturday that drilling was becoming very laborious and there was a lot of vibration when the bit had pressure on it so I decided to replace it. The new one drills in less than half the time of the spent one. I didn't keep an official count but a reasonable estimate puts me in the 50-60 hole range and I could have swapped it sooner.
    New on the left, old on the right. The leading edge of the carbide on the back side of the worn bit has a chunk missing from it. There's still a good bit of carbide sticking out past the tool steel so I may pick up a diamond wheel for the grinder to see if I can bring it back to a usable state.
    I also picked up a box blade over the weekend. Concord Tractor's price on a 6' model a step up from the lighter duty version was as good as I had found and they had one left in stock. It's around 600lbs.
    Tractors - Educate me-masonry_bits-jpg Tractors - Educate me-box_blade-jpg
  6. #1906
    Like to see what you do with the box blade. Some of my trails are pretty rough.
  7. #1907
    Seacoast NH
    Buddy, pal, friend of mine.
    one of the things I do, when drilling several holes, is switch bits between holes, I don't start a new hole with a hot bit, I have found that rotating the bits, makes em last a little longer
  9. #1909
    Candia, NH
    In the short term I have plans for it, but you're welcome to borrow it in the future.
  10. #1910
    Candia, NH
    Not a bad idea. The 3/4" Milwaukee SDS bit I'm using isn't crazy expensive at $24 compared to what others can get up to. I may snag another one when I'm out and about.
  11. #1911
    Seacoast NH
    A box blade is one of the things I'd like to add one of these days. I'm determined to find one used on the cheap. Everyone insists it isn't hard to do. I don't see a lot being offered up. Sure I'm looking in the wrong place.
    But yeah. I may bug you someday, like next summer or beyond. Maybe for a try-before-I-go-buy weekend?
    I'm pretty underwhelmed at how effective the straight grader/back blade I bought is. I tried to spread piles of decomposed wood chips and quickly got fed up, went back to back-dragging with the bucket. My little 72" blade doesn't seem to weigh enough. I've seen photos on the internet where people chain logs or rocks to the top of straight and box blades. I have plenty of logs and rocks.
    Really I bought the blade for snow. My neighbor gets'er done with this setup. So. We'll see soon enough.
    This weekend I tried backing the CX2510 into my garage for the first time. ROPS up she just barely fits. 2 fingers of clearance between the garage trim and the top of the bar. Garage is still too much of a disaster to park her in there. But it was cool to confirm it will fit. Once the bikes get put away for the season there should be room to store it in there at least before a major storm.
    Also got suckered into a pair of LED aux lamps from the amazons during "prime day". $15 for the lamps.. and I'm now in for almost $100 in an aux fuse panel, wiring, switches, etc, etc. At least the lamps were cheap!
    While I'm at it I'm wiring up a SAE plug for a tender & heated gear and I will run a circuit for a small ATV winch I have.
    I need a clever way to hang these from the ROPS. I hear magnets are the in thing.
    I'm using smaller 9/16 bits, several years ago, I picked up a dozen for $12/ea
  13. #1913
    If you sketch something up I can 3D print it.
    Made a simple little enclosure for my aux light. It's magnet mounted so I can point it wherever I want.
  14. #1914
    Seacoast NH
    I hadn't thought to 3d print. I can print as well now. I have some PETG I really should experiment.
    That may be more CAD time than I care to dedicate at the moment. I was thinking an hour of hacking-and-slashing with a file, grinder and some aluminum bar.. at worst.
    There are about 10 knock-outs on the dash of this machine reminding me that this is a base model. I intend to fill one with a nice lighted switch.
  15. #1915
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    So with the new chipper, I have developed a new system of just ripping the smaller trees out and feeding them thru whole after chopping off the base.
    Attached Thumbnails Attached Thumbnails Tractors - Educate me-img_7357-jpg
    TIMMYDUCK
  16. #1916
    scam or no scam?
    got everything but the backhoe for me
    https://newhaven.craigslist.org/grd/...206702943.html
  17. #1917
    scam or no scam?
    My money is on scam. 100%
    Candia, NH
    Usually the scam starts out at $4Kish dollars. It can’t hurt to call. If they say they will post it on EBay to complete the transaction, then it’s a scam.
  19. #1919
    Feb 2003
    Only 1 picture with a lot of missing attachments mentioned in the ad .
    The thing the really gives it away is that no way in hell is that West Haven CT in the pic .
    TIMMYDUCK
  20. #1920
    Candia, NH
    Time to start filling in some of the craters in my back yard. A triaxle of screened fill.
    Tractors - Educate me-screened_fill-jpg
  21. #1921
    Seacoast NH
    You're moving fast!
    Is that what happens when your kids are > 5 years old? Suddenly you have time??
    Exactly. One pic. Shit description. And underpriced. Def a scam
    You're moving fast!
    Also need to know the answer to this
    Candia, NH
    There is an age/maturity point where you don’t have to supervise them 24/7 and it makes your life a lot easier. Mine are 11 and 9 and they can be left home while the wife and I go out for drinks!
  24. #1924
    You're moving fast!
    ?? your kid hasn't started playing hockey yet, eh!
  25. #1925
    guess its been a year now but been Bobcats is back in the business of the tractor world again. Production seems to be made by Daedong tractors which is the same company that makes Kioti
  1. Tractors
    By RandyO in forum Off-Topic
    Last Post: 11-28-16, 08:55 AM
  2. Monsters: Educate Me
    By Pittenger5 in forum General Bike Related
    Last Post: 10-26-11, 10:13 PM
  3. Educate me on MX Gear
    By nt650hawk in forum Dirty Bastards
    Last Post: 09-06-11, 09:16 AM
  4. Snowmobiles - Educate Me
    By highsider in forum Off-Topic
    Last Post: 11-24-09, 06:28 PM
  5. Educate Me- Exhaust Systems
    By McBiggity in forum Bike Maintenance
    Last Post: 07-28-03, 11:52 AM
