Page 79 of 81 FirstFirst ... 395969707172737475767778798081 LastLast
Results 1,951 to 1,975 of 2013
Tractors - Educate me
  1. #1951
    Re: Tractors - Educate me
    If you get a thumbs down from me, pm me, it was inadvertent
  2. #1952
    i thought you got these last year.
  3. #1953
    Lifer ZX-12R's Avatar
    Candia, NH
    I put the box blade to work over the weekend to good effect. More than half the dirt I ordered is dumped behind the rock piles at the far end of the yard so I can navigate down there without falling into any of the craters I've left behind. The other half is in the smoothed out area you can readily see. The box blade did most of the large volume material movement which I then smoothed out by back dragging. I then ran it over a bunch of times to try and compact it down. I still need more fill and I have another triaxle on order but I'm off to a good start and there's light at the end of the tunnel for this project (at least for the back yard).
    Tractors - Educate me-box_blade_work-jpg
    I also tried out my tractor cover. At 40lbs, it's a little unwieldy to put on by yourself, but I managed. I think if I plan ahead and fold it up properly, I could make my life much easier in the future.
    Tractors - Educate me-tractor_cocoon-jpg
    Tractors - Educate me-box_blade_work-jpg Tractors - Educate me-tractor_cocoon-jpg
  4. #1954
    Seacoast NH
    That looks great!
    You going to cover the backhoe? I need to figure something out. I did get the bright idea to get it up on some PT 4x4 scraps out of contact with the ground. Now I'm having trouble with the bucket filling with water and freezing.
    Candia, NH
    I'll set the backhoe on wood when I'm done with it for the season. Right now it's off temporarily as I needed the 3 point hitch for other duties. I'll most likely cover it with a cheap tarp when the time comes.
    Also, the little snow storm that blew through this morning with some crazy winds didn't even budge the tractor cover despite it not being tied down.
  6. #1956
    Harbor freight has the heavy duty tarps on sale. Many options and very good quality.
    Well, I am impressed with R2 Mfg. Ordered the Edge Tamers on a Friday, had them inhand by Tuesday.
    The items are of exceptional quality. No slag around the welds and the fit and finish is excellent. I almost don't want to use them! LOL
    Candia, NH
    Load #2 was delivered this morning. I have to switch back to rock moving mode for a bit before I spread the dirt around.
    Tractors - Educate me-tri-axle_02-jpg
    In my search for less expensive SDS+ bits, I decided to try a couple from Amazon. The bit in the middle is the (lightly used) German made Milwaukee from Home Depot for $24ish. To the left is the same Milwaukee bit but made in China which you can get on Amazon as a dual pack for $25. Notice the difference in the carbide shape between them. The bit on the right is a German made Dewalt branded bit for $13 on Amazon. It has a similar carbide shape to the German Milwaukee but the tool itself appears to be milled from round stock where the others (at least the Chinese Milwaukee) appear to be twisted bar stock. I haven't tried the two new players yet so we'll see how they do.
    Tractors - Educate me-bit_comparison-jpg
    Tractors - Educate me-tri-axle_02-jpg Tractors - Educate me-bit_comparison-jpg
  9. #1959
    my bits look like your #1 I bought, what has turned out to be a lifetime supply, about 30 years ago, when I bought my Ryobi rotary hammer, from one of those sales guys that tells you a terrible joke when he calls, but it seemed like a good deal at the time, about a $100 for a dozen, and has turned out to be a good deal, below is a slightly used, 500 holes ? mostly just an inch deep as angle points on property lines, but some 2 deep to place aluminum disks
    Tractors - Educate me-img_2476-jpgTractors - Educate me-img_2478-jpg
  10. #1960
    on another not, I wanted to dig a test pit with my toe-hoe, yesterday, but a broken pin on the boom, after searching, and driving here and there, I finally found a 1" dia x 8" long grade 8 bolt that works as a temporary fix at least, and by the time I got the machine all greased, it was too late in day, I went out today and dug the pit.
  11. #1961
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Fun day moving out the leaves today.
    Attached Thumbnails Attached Thumbnails Tractors - Educate me-img_7653-jpg
    TIMMYDUCK
  12. #1962
    TWINS! xrocket21's Avatar
    Central Maine
    thats a ton of leaves!
    Lifer Falko's Avatar
    MoonTown
    I find around our house that the neighbors' oaks and the crimson maple have the worst leaves to pick up. They just dry up and turn into papyrus, very bulky. The sugar and silver maple shrivel up and easier to handle. I have to haul my leaves to the dump and I know that I've posted before but before mulching, I would take 20-some truck loads to the dump and after I got the bagger for the mower it is about 5 to 6. This past weekend when the leaves were a bit wet, the truck got loaded down pretty good, probably dropped the suspension 3". Guy at the dump had one of those Harbor Freight bed unloaders (tarp with a crank). I always thought those weren't too good but watching him with a garden fork in my hand, I was jealous.
  14. #1964
    South Coast MAsshole
    i had no idea that these existed...
    https://www.harborfreight.com/2000-l...der-60800.html
    so far i have done 2 leaf cleanups...triple bagger on the mower for part of it...then i use a tow behind sweeper...have to keep on it cause if they leaves get too thick the sweeper wheels can drag and the sweeper won't work
    Point37s Garage Sale Thread
  15. #1965
    Candia, NH
    My schedule has kept me from from the yard work the past couple of weekends but I had managed to get my dirt delivery moved to the back yard last weekend.
    Tractors - Educate me-back_yard_fill-jpg
    Here is is all spread out and compacted as best as I can. I still have to excavate at the boundary of the stone wall but I'm almost there for this section of the yard!
    Tractors - Educate me-spread_fill-jpg
    Here's the primary rock pile with all the big'uns...
    Tractors - Educate me-rock_pile_01-jpg
    Here the secondary pile that has more of the smaller rocks. It's hard to judge scale but the dirty rock on top is the width of my bucket.
    Tractors - Educate me-rock_pile_02-jpg
    And finally, one of my goldens chased a mouse into the bucket so he laid down and played with it until he finally crunched it.
    Tractors - Educate me-dog_caught_mouse-jpg
    Tractors - Educate me-back_yard_fill-jpg Tractors - Educate me-spread_fill-jpg Tractors - Educate me-rock_pile_01-jpg Tractors - Educate me-rock_pile_02-jpg Tractors - Educate me-dog_caught_mouse-jpg
  16. #1966
    Seacoast NH
    Those of you that have installed extra lighting on your machines.. how do you have them switched? Are they on/off with the key, or switched independently? Anything like that?
    I have my little toy in the garage now for some electrical gooberage. Minimum is wiring up a panel mount SAE connector for a battery tender and my heated motorcycle gear.
    I have found there are auxiliary circuits everywhere on this thing. Behind the seat/tank there is a circuit switched with the ignition. On the fender there is another that is hot with the key in ACC. Two more plugs down there that I read are set up for trailer lighting or something. Now thinking about using one of those drops instead. Will I regret not being able to switch work lights off independently? I think I will.
    They must use the same fuse box for their entire line of tractors. Mine has ~12 spots with only 4 of them hot. Interestingly there are fuses populated in ALL of them. Sticker calls all the extra fuses "spares".
    I bought a switch that I thought would fit one of the dash knock outs. Turns out it is just a bit too small. Will 3d print an insert to trim it out at some point.
    Did I mention this thing has 2 USB power outlets on the fender?! Dumbest feature I can imagine a tractor having.
    Candia, NH
    I haven't added any lights but I did futz around with my horns. I keep contacts around so I can populate the unused spots in the fuse blocks.
    For the ATO/ATC style fuses: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    For the relay connections: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  18. #1968
    Seacoast NH
    Way ahead of you there. Although the fuse block is already fully populated. Just have to back the connectors out and crimp on wires. I bought a marine fuse box and feel like a dummy now as it really seems pointless.
    Candia, NH
    You could always run it like a subpanel. Feed it with a large fuse from the main box and locate it wherever is most convenient for you.
  20. #1970
    Seacoast NH
    With 8 spots in the factory panel open there seems like no need. All the yootoobe crowd installed their own panels. Most of them have the other orange flavor. Maybe they don't come with so much open? Who knows.
    I was disappointed that the main and starter fuses seem to be in individual holders buried in wads of tape in the harness. Also everything in the panel is ignition or acc. No always hot circuits there. The hazzards work without a key. No idea how those are fused. Someday I'll maybe buy a shop manual for this thing with a wiring diagram.
    I think I just decided to run a new switched circuit. Circuit will be tied to the acc switch position. That way I can run the work lights with the engine off but pulling the key kills them.
    Candia, NH
    I wouldn't be surprised if our fuse boxes are the same. Mine has a lot of extra space to accommodate the cab model. I do have the shop manual for mine so if you're curious about anything (except the wiring of your USB ports which I don't have), I can at least take a look and if it isn't identical it may at least give you an idea where to look.
  22. #1972
    Seacoast NH
    Where did you buy the manual? How much was it? Is it any good? Half the illustrations in my owners manual are for the old CK2510. My CX seems to have a whole different front axle. All the grease points are different. If the workshop manual is just as bad...
    Candia, NH
    I bought mine from Concord Tractor and it was in the $130 range. Since the tractor is new, I haven't done much with it but it seems ok from the get go. My model is fairly well established though.
    My owner's manual left a lot to be desired too which is part of the reason I bought the workshop manual.
  24. #1974
    Haverhill, MA
    First thing I thought of when I read your initial question. Glad you wound up posting this later in the thread.
    The idea of having always on power is nice but the reality of it is that you wind up with a dead battery more often then you should because you simply forget to turn off whatever it was you were powering.
    Seacoast NH
    I don't know. I would like to think a gang of LED work lights (I will probably have 4x 60W by the time I am done) being left on would be somewhat obvious.
    Got the fuse panel sorted last night. Reusing the existing tabs in the panel is probably not the brightest move, especially given the tabs are cheap. But it is done and looks factory on first glance.
    Need to chase the wires and build a harness for the switch.
    Got most of the battery tender & heated gear plug sorted only to realize I'd crimped and dressed on terminal connectors that were too small! Decided that was a sign I had done too much and called it a night.
    Still have to figure out a cleaver way to mount the lights themselves. They need to hang below the top of the ROPS as it clears the garage door by a fraction of an inch. I hear magnets are the hot way to do this.
  1. Tractors
    By RandyO in forum Off-Topic
    Last Post: 11-28-16, 08:55 AM
  2. Monsters: Educate Me
    By Pittenger5 in forum General Bike Related
    Last Post: 10-26-11, 10:13 PM
  3. Educate me on MX Gear
    By nt650hawk in forum Dirty Bastards
    Last Post: 09-06-11, 09:16 AM
  4. Snowmobiles - Educate Me
    By highsider in forum Off-Topic
    Last Post: 11-24-09, 06:28 PM
  5. Educate Me- Exhaust Systems
    By McBiggity in forum Bike Maintenance
    Last Post: 07-28-03, 11:52 AM
