Page 91 of 92 FirstFirst ... 115171818283848586878889909192 LastLast
Results 2,251 to 2,275 of 2300
Tractors - Educate me
  1. #2251
    Re: Tractors - Educate me
    https://www.ofa.fi/fi-en/products/tr...o/6045/tapio-9
    And ATV chains for front. Think that’s what I paid, could be a misremembrabce.
    Update: guy on Advrider got an updated quote for rear chains. $750. Front chains are much much cheaper, ATV-size.
    “If at first you don’t succeed - don’t become a Paratrooper.”
  2. #2252
    Lifer obsolete's Avatar
    Norf Sho
    Ok you yard equipment nerds, buy me a thing. New house has 2 acres and I will not be push mowing it. I also have a longish driveway that, if it makes sense, I would add that to this machine. I have no other uses. Ain't chopping wood, ain't digging holes...
    -Alex
  3. #2253
    Norf Sho
    Tractors - Educate me-screenshot_20220118-192335-jpg sat cap for reference
    -Alex
  4. #2254
    2 acres and not chopping woods, digging holes, hauling things, etc? That’s what you think NOW. Lol
    Anyways if you want nice lawn and stripes you should get a sit down commercial mower. If you just want things mowed one of the compact tractors should do just fine for mowing and snow removal.
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    So many great machines to choose from .
    So basically you need a sub compact or compact tractor with a mid deck mower and a PTO or hydraulic driven 2 stage snowblower.
    The big thing to consider is you probably want a front mounted snowblower instead of a rear one , where you are constantly driving backwards looking over your shoulder.
    I would also not skip loader arms with quick connects for bucket and forks .
    As an example take these pesky hemlocks , you can just roll up and scoop them out.
    Attached Thumbnails Attached Thumbnails Tractors - Educate me-dba2d4da-687a-4ced-8226-be73606ea6b4
    TIMMYDUCK
  6. #2256
    How many zeros in the budget?
  7. #2257
    Norf Sho
    I just want the grass shorter than prior to having mowed it. I really don't have a much going on above those 2 things so I certainly don't wanna pay for overkill. My projects would be so small that renting bigger equipment for a day or 2 would be worth it over the long run.
    Yep, front mounted definitely seems like a better choice.
    As many as I need to pay to get those things accomplished. I'm not opposed to 2 pieces of equipment either.
    -Alex
  8. #2258
    Haverhill, MA
    You sell the one the tree fell on or adding to the collection?
    Norf Sho
    I'd entertain the idea as it'd pay off the maine house but keeping it as a rental now seems like what we'll be doing.
    -Alex
  10. #2260
    Haverhill, MA
    Where is the house you posted the picture of? That the Maine house?
    Norf Sho
    Nope, that's the new one in NH. That's the one I'm trying to figure out the yard equipment for. Maine has a plow guy.
    -Alex
  12. #2262
    Subcompact with mid mower and front blower.
    Where in NH?
    TWINS! xrocket21's Avatar
    Central Maine
    Buy once cry once
    NH has plow guys too!
    Of course mine just broke my bridge.....
  15. #2265
    Norf Sho
    That's where I'm leaning bergs, and Kubota has 0% all the time. Atkinson.
    I wonder if they paid Fitz or he just wants to be a part of anything NH.
    -Alex
  16. #2266
    Lifer ZX-12R's Avatar
    Candia, NH
    This last storm put about 6" of snow on the ground before it started pouring rain. By the time I got outside to plow, the snow was fully saturated. To my surprise, I was still able to move it without much trouble using the 8' plow. I had a couple traction issues due to some ice and no chains but it was nothing a little momentum couldn't fix. At the end of my driveway while doing some cleanup with the plow angled, I ran into the front not having enough traction for the first time. A couple of shallower passes at higher speeds handled that situation. At the end, I put the bucket back on and rolled the snowbanks back for better visibility.
    I was under the impression it was going to rain most of the day so I plowed in the rain shortly after it started to avoid having a giant mess. Of course the sun came out less than 2 hours after I finished.
    ...edit...
    My neighbor plows with an ATV but wasn't heavy enough to fully clear his EOD pile. The tractor pushed it without batting an eye.
  17. #2267
    ...edit...
    Yeah...I was up early enough to get out with the wheeler & plow. BUT I held off once it started raining as it was pouring and I didn't want to get soaked. I figured I'd wait a little while, the rain would stop, sun would come out and melting would help. Wrong call. I got it done, but it took forever. Little sections at a time. And as you said, momentum certainly helped. In a few spots, I figured the snowblower may help. Not a chance. Took about 3-1/2 hours what usually takes an hour to 1-1/2 hours. I've said this before, but I won't make that mistake again. This time I mean it.
  18. #2268
    Tractors - Educate me-401bc4ab-eba3-4c5d-bea9-27db41f21d49
    We had some fun moving piles last night.
    Norf Sho
    Here's the driveway. Not opposed to doing a mower and blower separate as well. Thoughts?Tractors - Educate me-pxl_20220119_212612539-jpg
    -Alex
  20. #2270
    Seacoast NH
    That driveway is a bit smaller than mine. Estimate about 30-40 minutes or so with a decent walk-behind 2-stage blower. Less than 1 hour including hand shoveling the walks.
    That metal roof is going to be annoying without snow bars as it will keep putting snow back on that walk you just shoveled. Ask me how I know...
    Do you really have 2-acres of grass? Or is this 2-acres of land with 1/8 - 1/4 acres of grass?
    I have ~3 acres of land with ~1/4 of grass. A ride-on mower is the ticket for its 40-50" pass; doing it with a ~22" walk behind is no fun. Problem with the rider is it starts to get annoying turning the thing around. By the time you are done the rider is barely faster than the walk-behind.
    A zero turn would be better.. or a wide-deck semi-pro walk behind. That's what I'm after now, a ~33" self propelled walk-behind. I can use the exercise.
    I cannot imagine how much edge cleanup there would be with a less maneuverable tractor with a 54 or 60" deck.
    Clearing snow off the driveway is a bit different. Although not by much. Bill called it; scalpel vs chainsaw.
    IMO an (at least) $25,000 sub-compact tractor with a mower deck and front blower is an awful lot for that work. Meanwhile $2500 worth of walk behind snow-blower and mower would do the deed just the same. Budget $5k to go nuts with the newest, nicest bits you can and still have enough leftover for a decent back-pack blower, good battery powered line trimmer & small chainsaw combo, plus maybe a gas brush saw for tending to the woods 1x per year.
    Put the rest in the bike fund. That's my $0.02.
    Truth told, as fun as my machine is, I should not have bought it. I should have put the $300/mo into paying someone else and watching them sweat instead.
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Well said, Garandman. I agree totally. I have a mid size Mahindra tractor and I love it, but for mowing the lawn and blowing snow, i use dedicated machines…and that was with a more difficult driveway and probably more grass.
    My tractor is a big too big and heavy to be good for lawn mowing and a front snowblower for it is extremely expensive. There are better tractors out there for mowing and snowblowing (like Kubota Bx series) but they arent ideal for bigger tractor jobs, and cost an arm and a leg with mower and snowblower attachments.
    5 grand range for brand new husqvarna snowblower and zero turn mower. Done.
    Candia, NH
    Poor Bubs gets no love...
  23. #2273
    I have 2 33” walk behind mowers to choose from for anyone interested.
    Also I think a tractor is the best solution for your case.
    But you can get an Ariens Pro blower ($3000) and find a used sit or stand mower also. Especially if you really think you won’t use the tractor for digging or moving shit around your property then don’t buy it. But having it is awesome.
    Seacoast NH
    I think the front-mount blower kit for my CX2510 runs like $7-8k. Would rather have the backhoe.
    It is badass though: https://youtu.be/dMmvg-pVepM?t=482
    Whatchugut and whatchu want for it?
    Craftsman, Troy built and I have a bunton I think also.
  1. Tractors
    By RandyO in forum Off-Topic
    Last Post: 11-28-16, 08:55 AM
  2. Monsters: Educate Me
    By Pittenger5 in forum General Bike Related
    Last Post: 10-26-11, 10:13 PM
  3. Educate me on MX Gear
    By nt650hawk in forum Dirty Bastards
    Last Post: 09-06-11, 09:16 AM
  4. Snowmobiles - Educate Me
    By highsider in forum Off-Topic
    Last Post: 11-24-09, 06:28 PM
  5. Educate Me- Exhaust Systems
    By McBiggity in forum Bike Maintenance
    Last Post: 07-28-03, 11:52 AM
