I need a very simple part cut out of 4mm aluminum sheet. Can anyone recommend a place to have this done? Ideally within metrowest but I can travel...
It's so that I can mount the OEM turn signals on the Hyper with the 2-into-1 Termi.
Mountog.pdf
I don't have access to waterjet or metal capable laser, but do have access to a CNC plasma table. I'm not sure if that will get you the tolerance you need.
You might check with artisans asylum to see if they can help.
I get all my stuff done at xometry.
It's pretty quick and fairly cheap. Just need to upload a 3D model.
