Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 26 to 50 of 259
Wood stove
    Re: Wood stove
    Yep. Stove is going in the basement, and I guess I shoulda added that square footage to.
    So total area about 1900sqft. So it seems that this stove will be to small? I am a bit new to wood stoves so I am just unsure and want some opinions.
    If this one wont do it, have any suggestion what to look for? Cost will be a big factor so I'll be searchin craigslist.
    Brands matter? What size? Blowers needed?.....Yea i'm a bit lost on this one
    0 Not allowed!
    Re: Wood stove
    Mostly pine here.. and only 2 acres at that. No way I could reliably heat off this land. But even then, green firewood is comparatively cheap.
    You guys make me really wish I could have pulled off a proper wood stove. Just getting the insert out to get to the flue is a half a day project.
    same here, 2acres, (300x300) primarily big sawlog pine, but enuf red maple, beech & oak that I cut 2-4 cords every year for the past 25 years and I still got plenty of hardwood in the understory, also,about every 12 years, I have cut about 10,000 ft of pine, due for another pine harvest this year, only takes a dozen trees the size mine are, this year, I got about 2500ft of hemlock marked too. I'll have a guy come up with a portable mill and make me some roughcut for projects I have planned
    0 Not allowed!
    Re: Wood stove
    How's that woodstove doing in your house on these cold nights?
    Mine is chugging down the firewood fast with a stove top temp of 700 at the moment, I have not even turned on the oil heat yet this season. 93 in my basement now, 72 in the house
    0 Not allowed!
    A Big Powerful Sportbike
    Ashford, CT
    Re: Wood stove
    Ha ha 93? Nice. Mine is in the living room so it's about 85 in here so the rest of the house can be about 70-72. But yeah, it's using up the wood at a pretty good rate. I haven't had to run the oil at all either. I've been having to get up at about 3 or 4am to load it back up or it gets chilly at the far end of the house by morning.
    0 Not allowed!
    Jeff
    Re: Wood stove
    Stoves great. Even with this cold air I have no issue keeping the house heated. Usually go to bed with the first floor at 70*.
    Have found that if I really get that stove going, I can get about a degree a hour back in the house and stove top will be in the 700+ range too. Helped today when the house was at 62 after work.
    Sure using some wood though! I would have to guess i've burned 3 cord give or take.
    Havent even bought oil yet
    0 Not allowed!
    Seacoast NH
    Re: Wood stove
    I'm still too much of a pussy to run it during the day when I'm not here. Today the stove was a real bitch to get going when I got home from work.
    0 Not allowed!
    Re: Wood stove
    3 cord? I've honestly burnt about half that, maybe 2 cord at the most.
    That seems to be the trick, make it last all day burning slow, then crank it up when you get home from work. It was 67 in the house when i got home today and the stove still had a good bed of coals
    That's about what I get, a degree an hour when it's this cold
    0 Not allowed!
    Re: Wood stove
    Why? Do you not trust the stove?
    I'm sure it was. Its nice to have that bed of coals, re-fill and walk away
    Yeah I'd say close to 3 cord, Mark. When I measured the pile I had about 8 cord. So just going be eye
    0 Not allowed!
    Seacoast NH
    Re: Wood stove
    I'm paranoid I'll come home to a pile of ashes. I'm not saying the paranoia is rational, but I have it.
    I fill the stove before bed, but not in the morning before work.
    I'm also on my 2nd tank of oil this season and have barely burned a cord.
    0 Not allowed!
    Ashford, CT
    Re: Wood stove
    Get the stove ripping in the morning while you're getting ready for work then choke it down before you leave.
    0 Not allowed!
    Jeff
    Re: Wood stove
    2nd tank of oil? That hurts, I can't stand filling mine once every 2 years, never mind twice in a season!
    Quote Originally Posted by GearHd6 View Post
    Similar to what I do, but I really don't let it get ripping before I shut it down. I get 11-12 hours no problem doing that, but I do have to make sure I burn it hot for a while when I get home to burn off any buildup
    0 Not allowed!
    Seacoast NH
    Re: Wood stove
    I average 3 tanks/year. Before the stove, that was 4.
    Based on everything I've seen, your house is about a gazillion times better insulated than mine.
    Seriously, I need to do something about the attic/roof this year. I've already started warning the missus the kitchen fund is at risk. Those conversations have not been fun.
    0 Not allowed!
    Re: Wood stove
    Probably have used 2-3 cords so far. every day every night since mid November. Pretty constant 65-70 and leave the T-stat at 55. Don't think the heat has had a chance to kick in. I can tell because the basement is cold (50 's) lately when I go down to work on the bikes.
    benn bringing home 1 cord of oak, Cutting and hand splitting a week for the past 3 weeks for next season. I may take a brake this weekend and just enjoy the woodstove.
    0 Not allowed!
    Ashford, CT
    Re: Wood stove
    I burn 3 cord for the whole winter. I go through roughly one tank of oil every year seeing it assists heating my hot water. I can shut the furnace off but then my electric bills goes up quite a bit.
    0 Not allowed!
    Jeff
    Re: Wood stove
    I should mention . In a non-insulated house.
    0 Not allowed!
    Re: Wood stove
    I've only burned half a cord so far this year. Also only went through half a tank of oil since early November. Thought it would be a lot more than that given we have double the living space now and more than twice the windows as last year. That and I'm heating the garage.
    I keep the house around 66 on the coldest nights with the stove. It's down to 62 in the morning which is where I set the thermostats (in floor radiant is a set it and forget it heat, not supposed to turn it up and down all the time). The bigger difference in temp between inside and outside, the faster you lose the heat you paid for. I don't mind keeping it a little cooler on the really cold nights.
    I figure once we get our double cellular blinds for the windows, it'll help a bunch.
    Shitty vinyl windows in the existing house have rings of ice on the bottoms of the panes. Junk. They are all getting swapped out for the triple pane windows that I put in the addition. 69x64 and the inside glass is room temp to the touch, even last night. Love it.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    2000 Honda CBR929RR
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Re: Wood stove
    I've burned about 1.5 cord, heating with the stove two-thirds of the time and using the boiler for the rest. Some of the cement has come off the joints in my stove and it's fucking up my burn times and heat output, so fixing that and getting piss drunk are my projects for today. I'm probably going to install a kit to make the stove burn outside air too later in the day. We have an IR camera at work we use to detect hot spots on power lines and equipment, my plan is to bring it home and figure out where some of this cold air is getting into the house.
    0 Not allowed!
    Re: Wood stove
    +1 on my cement failing onthe stove hence a lot of wood i have gone thru. Last time I rebuild the woodstove was probably 7 years ago. it's due
    0 Not allowed!
    Seacoast NH
    Re: Wood stove
    Cement?
    The door seal on mine is looking a little rough after only 4 years. I think I am burning more this year due to that.
    0 Not allowed!
    Re: Wood stove
    Cement.
    the thing that seals up the corners and edges of my woodstove.
    0 Not allowed!
  21. #46
    Apr 2006
    massachusetts
    Re: Wood stove
    Cement?
    my stove is made of soapstone tiles that are keyed together with steel splines, and sealed with cement.
    0 Not allowed!
  22. #47
    Seacoast NH
    Re: Wood stove
    Huh. Mine is cast iron. I thought the firebox was welded.
    0 Not allowed!
  23. #48
    Re: Wood stove
    Typically cast iron stoves are all put together with furnace cement.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    Re: Wood stove
    welded cast iron and heat. you must have a lot of cracks due to expansion.
    0 Not allowed!
  25. #50
    Seacoast NH
    Re: Wood stove
    I honestly don't know. I do not believe it is leaking. There is no evidence of it leaking, except from the door seal. The manual does not list cement/joints as a maintenance item.
    0 Not allowed!
  1. wood burning stove folk
    By R1 in forum Off-Topic
    Last Post: 02-28-10, 09:27 PM
  2. WTB: Wood stove
    By MidNight Powder in forum For Sale
    Last Post: 08-29-09, 10:18 PM
  3. WTB: Wood Stove
    By TheIglu in forum For Sale
    Last Post: 06-24-08, 05:38 PM
  4. Help - Looking for NH Wood Stove Tech
    By ancosta in forum Off-Topic
    Last Post: 11-20-06, 09:13 PM
  5. Installing a wood stove
    By highsider in forum Off-Topic
    Last Post: 09-07-05, 09:44 PM
