Results 1 to 10 of 10
Ducati 748/852 track/race bike
    I am getting out of racing and hate to see this bike just sit. Price at end of list.
    Very good bike handles great almost telepathic
    I have not hit the deck with this one.
    Has used Pirelli slicks Fronts got a season on it, Rears got a barber practice and one race
    Should replace the belts. Just because it been two years
    Not used a lot in the last two years. Maybe 10/12 races/practices in that time.
    Valves should be good
    Last adjustment was done at Clubhouse two years ago.
    Oil changed often.
    Engine:
    2000 748 with 916 pistons and cylinders. All rockers and valves that were bad at this time where replace when the kit was installed.
    Stock heads, cams and bottom end.
    Stock injectors
    996 oil cooler upgrade
    Chipped ecu believe it’s a ferracci.
    Bike dynode at 95hp have sheet somewhere
    Clubhouse did the install and dyno
    Samco silicone Tube kit in blue. Bike runs cool.
    Stock wiring harness not cut everything street was pulled at connectors
    Frame:
    Stock 99 with adjustable steering head
    Mag/alum? rear mono sub frame
    Carbon air box and intake runners
    Carbon heal and exhaust guards
    Lg single air filter over injectors
    Marchesini mag front wheel
    848 stock rear the lightest stock rear you can find
    520 gearing
    20mm Penske kit in forks
    Penske Triple adjust rear
    DP pads
    Quick change rear sprocket
    Brembo 18-20 front master
    Cycle cat rear sets right side shortened bought them that way
    Lightened vented clutch cover
    45mm Terignoni carbon slip-ons
    Stock headers
    Shark skin body work in fair usable shape, paints rattle can.
    Tanks mint not rattle can
    Speedo removed
    Tach, water temp gauges remain added oil and neutral lights
    Aluminum fairing stay
    Spares:
    Stock set of five spoke Marchesini sliver/gray wheels with front rotors prefect
    Stock airbox and runners
    Stock subframes (2)
    A full set of street body work After mkt. in better then good shape
    Stock three spoke front wheel straight with rotors
    Spare rear sets and gear shifter
    GP shifter
    Spare rear sprockets some still in pkg. new.
    Spare clutch plates
    And anything else I can find that fits this bike
    Price just the bike alone $4250.00
    If you want everything above $5500.00
    Ducati 748/852 track/race bike-20191020_081637-2-jpg
    Feb 2011
    Newport, R.I.
    Re: Ducati 748/852 track/race bike
    Building mine into an 853 for this season lol what was your best time at nhms? Is either spare subframe allow/mag? Any race nose fairings?
    On this bike at 64 years old I did 1:20s might have done a high 19s. Both spare sub frames are stock alum and buy my bike you will save a lot of money building yours!
    Feb 2011
    Newport, R.I.
    If those are actually aluminum not steel id be interested in buying one. Ill pm you as well. Lol and way to wait to save any money now
    sorry their steel not sure what I was thinking.
    Feb 2011
    Newport, R.I.
    Roger that thanks for checking.
    Ha, not surprised to see this listed here. to answer your question Duffy, I raced a 748/853 in the early 2000's and got down to 1:17's, more consistently in the 18-19's, as a middling Expert around the time. Seems high teens are well within the limits of the platform, and mid- or low- teens if you're proper fast. I think Brett Guyer recently raced his 748 no? Unsure of his times but he's quick AF.
    CCS/LRRS #83
    Brett has a 748R did 15s I believe.
    Feb 2011
    Newport, R.I.
    Appreciate the response to that, gives me some hope lol
    15's sounds about right. Maybe someone named wood could improve on it but there's your target!
    CCS/LRRS #83
