Parting Out 2005 Kawasaki ZX-6R 636 with 7,109 miles on bike.
Clean California Title, to be sold with frame.
VIN JKBZXJC1X5A004951
List of parts not including shipping.
Make offer, if price is not to your liking.
Have a couple more pictures, if needed.
Call (805) 404-4191, or E-mail mdgracing@sbcglobal.net with questions or offers.
Bike is located in California.
Thanks.
Marcel Graeber
Ex-AMA #767 / WSMC #767
Clean California Titled Frame with 7,109 Miles, Straight but Lightly Dented $1,500
Sub-Frame $150
Sub-Frame, Small Fracture on Left Rail $100
Sub-Frame, Bent Rear Section but Front Section is Usable $50
Forks $275
Forks, Straight but Scuffed $200
Front Axle and Nut $30
Front Fender, SharkSkinz, Slightly Damaged $40
Front Fender Side Mounts, One Scratched $25
Triple Clamps $125
Triple Clamp, Missing Top Nut $100
Scott's Steering Damper Mount and Top Nut $60
Mirrors $50
Radiator, Fan, and Over Flow Bottle $150
Radiator Only $75
Gas Tank, Green $250
Gas Tank, Scratched, Broken Cover, White $125
Gas Tank Cover, Lightly Scratched and Cracked but Usable, Orange $50
Lock Set With 1 Key $125
Ignition and Rear Seat Latch Only, No Rear Seat Latch Lock with 1 Key $75
Gas Cap with 1 Key $50
Windscreen $25
Front Wheel $300
Front Wheel Only, Slightly Bent, No Rotors $75
Rear Wheel with 44 Tooth 520 Sprocket $250
Rear Wheel, Slightly Bent Wheel, Straight Rotor, No Cush Drive $100
Swing Arm $75
Right Fairing with Right Blinker, Lightly Scratched, Green $75
Tail Fairing $125
Front Seat, Ripped $25
Front Seat $50
Rear Seat, Ripped $25
Shock $50
Left Rear Set, Sato Racing, Black $150
Left Rear Set, Slightly Bent Shift Pedal $50
Shift Linkage $25
Right Rear Set, Sato Racing, Black $150
Right Rear Set Bracket Only, Brand New, Stock $25
Rear Brake Master Cylinder, Line, Caliper, and Hanger $50
Rear Brake Master Cylinder Rod Assembly, Brand New $20
Dyno Jet Quick Shifter $125
Left Clip-On Only $25
Left Clip-On $50
Left Clip-On with Short CRG Clutch Lever $100
Right Clip-On Only $25
Right Clip-On $50
Clutch Lever, CRG, Damaged but Usable, Long $20
Clutch Lever, CRG, Damaged but Usable, Short $20
Front Brake Lever, Stock $30
Front Brake Assembly $125
Front Brake Calipers and Bolts $60
Passenger Pegs $50
Frame Sliders, Sato Racing, Black $35
Spools $15
Taillight $50
Chain Guard, Stock $15
Chain, 520 Pitch $50
Heat Shields, Two Pieces $25
Kickstand and Switch $25
Kickstand and Switch, Cut Connector $20
Battery Tray and Sub-Frame Plastic $40
Front Blinkers $25
Rear Fender with License Plate Light $25
Dog Bones and Pivot $25
Horn $10
Radiator Cap $10
Rear Brake Switch $10
Rear Axle $25
Swing Arm Pivot Axle $25
Motor with Two Holes in Block Will be Parted Out so Ask About Pricing For Parts You Need Not Listed Below
A Few Good Pieces From the Motor:
Air Box $40
Throttle Bodies $150
Complete Head $200
Transmission $200
Clutch $150
Clutch Cover $75
Oil Pan $75
Rectifier $50
Wiring Harness $75
Stator $50
Stator Cover, Scratched $50
www.gotmotoparts.com / Central Coast Mechanics / Bombay Motorsports / Motul / Galfer USA / GP Suspension / Shoei / LP USA / K & N / E-Racings / www.slime.com / Suzuki / Dunlop / WSMC / OFD Racing / 50Stunt / ESD - MFG / Fast 50's / Suzuki of Van Nuys / Creative Persuasions / www.GotHomesForSale.com
