Hearthstone 8040 Tribute Soapstone wood stove. This was the smallest soapstone stove offered by Hearthstone (Morrisville, VT). It has the rear heat shield so it can be mounted nearer a wall.
We've replaced it with a larger Hearthstone stove. It is stored in our garage so there is some light corrosion evident. Soapstone takes time to warm up, but provides gradual heat and retains heat for several hours. It would be perfect for a large room or small house. Rated for 1,000 square feet.
$450 or best offer. Can be seen by appointment. We can help load it.
Size 36,000 BTUs
Burn Time Up to 5 hours, Heat Life Up to 7 hours
Efficiency 83%
Width 24" x Height 25-3/4" x Depth 18"
Maximum Log Length 16"
Firebox Capacity 1.2 cubic feet
Flue Exit & Diameter 6" top exit only
Minimum Chimney Height 13'
Actual Weight (lbs.) 313
Mobile Home Certified
Clearances (With double-wall pipe & rear heat shield)
Side 16-1/2", Rear 8", Corner 7"
Hearth Pad: Minimum Size (US) 29" W x 31-1/8" DAttachment 51622
