Results 51 to 75 of 94
Fucking batteries are cunts
  1. #51
    Re: Fucking batteries are cunts
    Uh, its right there..
    CCS/LRRS #83
  2. #52
    Sep 2011
    Peabody, Ma
    My bad
    07 S4RS
  3. #53
    Quote Originally Posted by loki32687 View Post
    Not even gonna post the link?
    Here.
    http://www.nestreetriders.com/forum/...87778.html#top
  4. #54
    #494
    Jan 2007
    Rochester MA
    Brand new battery in the SV last fall. Left the key in the "park" position last night at work, which leaves the tail light on apparently. Punched out at 0300 this morning to a dead battery, got a jump and got home, now the battery wont take a charge. Fuck you little battery.
    Hypertarded
    Apparently all batteries are cunts and have it out for me.
    So it's a safe bet you don't have a deposit on a Tesla model 3
    Quote Originally Posted by b0xmonkey View Post
    Freakin CUNT
    Senior Member AEG's Avatar
    Aug 2012
    Simsbury, CT
    I did the same to the couple years old oem Yamaha battery. Looked dead like a brick. A Jr. tender brought it back to life after 48 hours and was as good as new after that. So not all batteries are cunts.
    Batteries are like cats: you just can't trust 'me.
    Jan 2017
    Worcester, MA
    I've been using AGM batteries in my old Hondas for years. They last between 5-7 years and are quite reliable. They're also reasonably priced at BatteryMart.com - The Best Value in Batteries! with free shipping. My CB1100F super sports and Interceptor all have Big Crank AGMs in them and they haven't let me down. I wouldn't waste any money on the cheap, conventional lead acid batteries. They don't last and worse, they can leak.
    Jun 2005
    Quote Originally Posted by tomk1960 View Post
    Are they cunty, though? That's the real metric we're measuring here. Not really sure what the unit of measure is, though... Maybe RayRays? Like, "The manufacturer supplied literature claims that this model has a range of 3.5 to 5.75 RayRays of cuntiness."
    Dic on
    Rayrays of cuntiness is how you measure tow truck drivers. the range starts at 1 million rayrays because they are ALL cunts.
    batteries are measured in "dumbasseries" of cuntiness. For example, if you blew the battery up by using a Lithium type battery with a charging system or charger not designed for it, the battery has a dumbassery of 3 on the cuntiness scale. If you blew the battery up by jumping it from an aircraft carrier then the battery has a dumbassery of just 0.1 on the cuntiness scale.
    basically, the cuntiness is almost always injected by the operator, who in the case of most broken batteries, is a cunt.
    "Too bad ponies are assholes."
    OXX
  11. #61
    Hanover, NH
    Well, I did start this thread...
    '08 Ducati HyperMotard 1100S, '14 Subaru XV Crosstrek
  12. #62
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    What are you replacing them with? The Ducati is getting a Battery Tender BTL14A240C which is supposedly a bolt-in replacement for the YT12B-BS. If it works well I'll probably put the same thing in the VFR.
    Can't wait until I buy a dirt bike with electric start and have even more of these cunts around
    I've been buying Big Crank lately from Battery Mart. We will see how they do i a couple years. The one in the quad lasted 6 years with minimal use.
    I won't buy any more MotoBat yellow pos.
    Jun 2005
    Ya a 30 min ride is not generally enough to recharge a dead cunt... usually a trickle overnight
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2005 Kawasaki Ninja 500R **
    instagram @veshlife
  15. #65
    Hanover, NH
    What the actual fuck? I bought a shiny new lithium battery for the HyperMotard last year, and then bought a lithium-compatible Battery Tender for it, and left it connected all winter. Yet it doesn't seem to have enough juice to start the bike
    Admittedly it's pretty cold today, but I left the lights on for ~5 minutes to "warm up" the battery and still no go. It cranks the motor over slowly for a second or two, then gives up in disgrace. Are you serious bro?
    I think I've got an old Yuasa lead-acid battery spare from when I had the VFR. I guess I'll try that to make sure the bike actually starts. The lithium jobbie is still under warranty, so...
  16. #66
    Ashford, CT
    I didn't realize people still bought those batteries with all the horrible reviews. I'll stick with the old faithful Yuasa battery. I usually get 5-7 years out of them.
    Jeff
  17. #67
    I gave up on them for bigger Bikes, went back to AGM.
    You shouldn't leave the tender on it all winter. If you're really concerned you have a parasitic draw, just undo the positive lead from the battery and let it sit. It'll be fine over the winter.
    That said, don't give up on the first failed crank. If you watch Ballistic's example vid of a Harley in below freezing weather I think they ended up going through four or five partial crank attempts before it finally warmed enough to do a full start.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
  19. #69
    Hanover, NH
    "Shouldn't leave it on" as in it's unnecessary, or as in it's bad for the battery? I leave it on as a matter of course; same with the 911.
    Yeah, I gave it at least that many tries. Including sitting with the running lights (no headlight) for several minutes. And it was probably 34 degrees outside, so not that cold.
  20. #70
    My YZ dirt bike has a battery and it doesn't actually do anything I pretty much get all my power off of the stator which runs when I have the bike running. So yeah you can pretty much forget about the battery but my limited observation is that batteries only last in a car about two two maybe three years and that's how long the warranty is so as soon as the warranty is up the manufacturers of the battery engineer the battery to fail within two to three years so that you have to buy another battery
    instagram @veshlife
  21. #71
    Apparently the issue is the way Ah are calculated for LiFe batteries. So while it may have plenty of cranking power, any parasitic draw makes them go flat pretty quickly.
    On our dirt bikes they work fine, no draw.
    Shouldn't leave it on as in - If you don't have a parasitic draw issue, no need for the tender. If you do, rather than use the tender for long term, disconnect the battery. Long term tender use is a bad plan.
  23. #73
    #494
    Jan 2007
    Rochester MA
    It's that time of year again...replaced the battery in my daughter's little quad a couple weeks ago, now the KLR needs a fresh one. 2 years old. Why do I waste my time rotating the battery tender through them all winter?
    Dec 2009
    Did you check the manufacturers recommendations for which motor oil is recommended for use with that battery?
    Jun 2005
    Me, I blame RayRay.
