Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
first 2 stroke rebuild
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Re: first 2 stroke rebuild
    I don't know much but that looks like chipping to me, not cutting. Then again I try not to use stone tools
    Flushed it out a few times? Any evidence come out in the drain?
    On my DR (which granted I knew to have metal bits in it) there were fragments hiding in the tiniest places, no way I could have found them without splitting the case. But you would think with the damage to that piston there would be some evidence elsewhere...
    Good luck!
    05GSXR75005SV65090DR350
    i'll trade you a kdx I have for your el camino
    I wouldn't trade it -- too many bikes already -- but if you're interested in buying it, let me know. I won't be asking that much for it as it's a basketcase right now...
    El camino....Go on......
    Apr 2004
    boston burbs....
    some more pics of the cylinder....KDX new pics - Album on Imgur
    here are some more update pics of the cylinder and one of the piston
    [album]http://imgur.com/a/nUo5H[/album]
    basically the inside felt very smooth, more so after a light rub with a scotch brite pad
    there is some "smearing" but its on the bottom of the cylinder not the top and towards the intake side.
    i did find a small "hairball" about 3mm x3 mm in a corner very odd, was not magnetic
    hmmmm......
    '69 painted (badly) in metallic midnight purple. Was built with a Powerglide but previous owner converted it to a TH350, which I freshened up. Was built with a wheezy 350 but I rebuilt it with a 383 (well, 385) stroker kit. Ditched the heads for Chevy Vortecs, Edelbrock intake, new valve springs and guides, rebuilt Quadrajet, new headers etc.
    Interior is stripped as I'm in the process (the stalled process) of putting new floorpans in it with new, proper sheetmetal. You're welcome to come and take a look...
    Have rebuilt gauges for the interior, rebuilt steering column, new trim, new just about bloody everything.
    Hmmm, that motor is pretty sacked out. Doesn't mean it won't do another 100 hours on a fresh piston though. If I cared about performance, I would send the cylinder to millenium for a recoat. But if I were in your shoes, I's slap a good piston in and move on the the suspension. FWIW I restored a 91 in basically the same way. It was great afterward
    Apr 2004
    boston burbs....
    my first time looking and "diagnosing a cylinder" what are the tell tale signs of it sacked out? the streaking? shoudl it look pretty pristine and crosshatching very visible??
    hmmmm......
    Well, like all things motor, other than obvious damage you have to measure it to determine how good/bad it is. The diameter needs to be the same top middle and bottom.
    Apr 2004
    boston burbs....
    diameter at top ( or 20 mm from top) is within spec. Manual doesn't state to measure the bottom or middle.... Is that necessary?
    See my eye looking at this sees nothing major going on ( but I'm a newb and your guy's eyes are better than mine)
    hmmmm......
    THat is how it is done. yes.
    Are you talking about the piston or bore? Are you measuring with a dial bore gauge, or an inside micrometer, or telescoping gauges? Bores should have very little taper, and need to be measured top, middle, and bottom both in the thrust and non thrust axis. Pistons, on the other hand, are made tapered and are a lot easier to measure with a caliper to get close 'nuf. Not only is there taper on the piston top to bottom, some are slightly oval at the middle when cold to allow for even expansion taking into account the pin hole and reinforcing bosses.
    Except for the KDX, which was probably cast in a discarded soup can.
  1. Supermoto Rebuild
    By union in forum Pit Area
    Last Post: 04-16-14, 08:04 AM
  2. two-stroke rebuild questions
    By burnham in forum Dirty Bastards
    Last Post: 05-28-11, 02:22 PM
  3. 2 Stroke in modern 4 stroke chassis
    By REXXX in forum General Bike Related
    Last Post: 12-09-10, 01:23 PM
  4. 2 stroke top end rebuild
    By Twheat18 in forum Dirty Bastards
    Last Post: 11-03-10, 02:09 PM
