Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 101 to 125 of 298
Bumpy tires again
  1. #101
    Central MA
    Re: Bumpy tires again
    Well, I made several changes at once. When I installed the fatty, I also installed a stiffer rear spring. This combination worked out really well for me. Prior to these changes, I was having difficulty turning in the tight stuff.
    Central MA
    Standing the fatty side by side with the Pirelli Scorpion that came off, the fatty was easily 3 inches taller. I was amazed.
    Central MA
    On the down side, I have a Terra-X lowering kit in my 350. Now, as it sits, it is almost back to stock seat height.
    Wow, 3 inches is a LOT. I would thin you could raise the forks like 2" in the triples. You will get your seat height back down, and get somewhere closer to traditional chassis settings. The stiffer spring effectively raised the rear a little, but not close to 3".
    sometimes you just gotta plow.
    I'm not staring at my dirt bike, but I don't think there's 2" of slide available on those fork tubes, and then you'd likely have some interference with hand guard mounts and/or handlebars and wires and hoses up above. strictly speaking off the cuff.
  6. #106
    i think by pure mfg spec measurements the Fatty was 1" larger than my standard Motoz front, would have to look it up. Joel posted the difference at one point.
    i def had to make adjustments, forks were already raised but i had to go up in the rear a bunch to get the bike turning again.
    Central MA
    WOAH! the difference wasn't that dramatic here. what size tire is your previous one again?
    found the spec i was referring to.. .
    the pic sucks but it's def a beefy tire... +0.4" sidewall, +0.8" diameter (going by numbers alone).
    Wow, that's drastic.
    I have 0" of space to raise the forks in my triples, so unfortunately these are a non-starter for me unless I jack up the rear even higher.
    2016 BMW S1000XR
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    For some strange reason it doesn't seem to slow the turning at all, at least for me. That tire is a game changer, like running a damper for the first time, getting an auto clutch, or getting stock suspension done. Rocks, mud, slippery roots, sand, it grips consistently better than any other tire I have used. It recovers nicely when it pushes. It also makes the suspension feel better.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
  12. #112
    Central MA
    I believe that pic is a comparison of an 80/100-21 Michelin AC-10 against the Fatty. The difference between the Fatty and the Pirelli Scorpion was not as great, but it was still very significant.
  13. #113
    Central MA
    My Terra-X lowering kit also has a 35mm spacer that installs under the upper triple clamp. This allows me to raise the fork tubes even higher.
    Central MA
    I agree with all of this. It also has an odd affect of enhancing stability over gnarly stuff - almost like a damper.
    Do it.
    few updates.. .
    - the weirdo Sedona seems to be working well for my buddy so far, he's been running it at 5psi w/TUbliss.
    - i'm still running the revised Motoz Tractionator S/T rear but reversed it's direction. still bummed they got rid of the rim protector.
    - ordered TUbliss for rear on my bike, can't wait. was getting jealous hearing C+C talk about the benefits although the new Motion Pro beefy rim lock i put on has been working much better (tire slip every ride before swapping).
    - throwing on a GEN5 Fatty front soon as well, supposed to be a revised compound, 5mm narrower with same height.
    - once this Motoz rear wears out, think i will try the Kenda IBEX next but i want a 110. only avail in 120 at the moment.
    dunlop At81: thumbs down at conventional 10-15psi. I'm not comfy going less than 10psi with a tube and on a 4t. like a fucking bowling ball.
  18. #118
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    After my trip to the great north both tires are SMOKED
    I bought another MT16 rear. I know i should experiment but.. It's hard when this works so good. But after watching Slaven's Racing's review last night on the Ibex I think I will try one. I think I'm going to give the B Stone a while on the front this time. One problem I have with the Fatty is that it hits my pipe guard when I land off jumps and shit.
    I will say for certain that the MT16/Fatty combo worked really well up north in the relentless rocks and mega climbs..
    sweet! where did you ride? sounds like an awesome time
    on the Golden front, mabye try the 90/90-21. same width as Fatty but less height.
    saw Jeff's review on the IBEX as well, i've been really interested in this tire but his latest vid made my mind up. i don't want a tall tire, the IBEX looks like a sweet hybrid mix without going tall.
    Sep 2010
    Granville, NY
    I am working on a write up of the trip. Both to share and document the memories so when I'm old and can't remember I can be reminded of how totally over the top this trip of a lifetime was.
    BTW. We rode 6 days on the Gaspe` peninsula in Quebec..
    Bumpy tires again-20170701_141652-jpg
    Haverhill, MA
    Clinton, check out the # #woodsrunners on social media and you should get an idea of where we were and the epic riding we got to do.
    Looking forward to Adam's write up!
    This was some type of guided adventury hootenanny?
    Looks fun.
    I'd like to do more things where I don't necessarily have to think about where I'm going.
  23. #123
    Fairhaven, Ma
    I've been watching the trip on the social media. It looked like a blast. When you right that up give us some details on how to do it.
    LRRS EX 151 AMSOIL
  24. #124
    oh, man, sounds amazing... looking forward to reading/seeing more!
    ordered a Kenda IBEX Super Sticky to test out in Fall conditions. can't wait. should pair well with Tubliss
  1. For Sale - Other | Free vintage truck tires - 7.00x15 - Decent yard tires (not roadworthy, IMO)
    Last Post: 06-03-14, 11:29 AM
  2. Yet again, Tires.
    By scottfromboston in forum General Track Day Talk
    Last Post: 07-19-12, 11:39 AM
  3. Buy Tires on the I'net?
    By mikem317 in forum General Bike Related
    Last Post: 08-30-05, 03:52 PM
  4. i need new tires...
    By mr phil in forum General Bike Related
    Last Post: 08-12-05, 09:24 AM
  5. tires tires tires free tires
    Last Post: 12-16-03, 10:10 PM
