Now, I am quite proficient at changing the tires out on my (or anybody's) dirt bikes, but I had read a while ago in Dirt Rider magazine about a different procedure for removing the old tire. It involved levering the bead of the tire over the rim on one side, and then flipping the wheel over and levering that tire bead outside of the rim as well, and then pulling the entire wheel and tube out of the tire in smooth easy motion. I have now tried this method several times and I have reached the conclusion that it does not work well with an 18" tire installed with an Ultra Heavy Duty Tube. The tube rubber is so thick that the wheel will not "sink" into the tire far enough to be removed easily. A 19" rear with a thick tube is even tougher, as the sidewalls are not as tall as those on an 18" tire.
So, I will stick to my old method of levering one side of the tire over the rim, pulling out the tube, and then using a long iron and a large mallet to lever the entire tire off the same side.
If you are running a standard "thin" tube, the Dirt Rider method will work great and probably save you a little bit of effort. On the other hand, if you are still running a standard "thin" tube and are sick of getting flats, get a Bridgestone UHD tube and never get a flat again! I have tried the Moose UHD tubes and some others, but the Bridgestone is the thickest!
Happy Trails! - Greg
