Results 1 to 7 of 7
Clutch
    Member flippedr6's Avatar
    Jul 2015
    Reading, MA
    Clutch
    I have only ridden the Beta 390 on the road a couple times and once off road up at Clough. The last ride was back in like Sept I think, warmed it up went to rip it around the block and clutch wouldn't disengage. So I took it apart and this is what I found. The outer portion of the stack was stuck together and overheated. New clutch time!
    Clutch-20181221_173425-jpg
    Clutch-20181221_173517-jpg
    2008 Kawasaki Concours 14
    2018 Beta 390 RR-S
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Re: Clutch
    Dang! I've somehow managed to burn out two clutches this year. I might start blaming Rotella.
    05GSXR75005SV65090DR350
    Re: Clutch
    Get a piece of glass (or something perfectly flat) and make sure none of the plates are warped. Check the frictions and the steels...
    Jul 2015
    Reading, MA
    Re: Clutch
    Parts of the friction disk are stuck to the steels, most of the stack is trashed. I'm just going to replace everything now so I don't have to mess with it.
    2018 Beta 390 RR-S
    Lifer Falko's Avatar
    MoonTown
    Re: Clutch
    My FJR (I know completely different bike) came from the factory with a pre-lube or something on the plates. They'd stick all the time. It was actually a little dangerous as you could come into a stop sign, pull the clutch and the plates were stuck together and you'd keep going. I learned to bump the throttle when pulling in the clutch to knock them loose. There was a fix of pulling the clutch pack and wiping them down and soaking them overnight in fresh synthetic oil, wipe them down, and re-assemble. Fixed the issue for that problem.
    Re: Clutch
    that sucks with such low hours. do the 390's have this issue? never read about it before ... what oil?
    oh, and ... we need to hook up at Clough this season, i haven't been up in a while.
    Jul 2015
    Reading, MA
    Re: Clutch
    It was the factory Motul oil, I have not been ale to find any info on it online so I'm thinking no it's not common. We absolutly do eed to catch up, I've only got it dirty once.
    2018 Beta 390 RR-S
  1. Clutch spring...lessen clutch pull
    By black in forum General Bike Related
    Last Post: 06-29-20, 10:25 AM
  2. Wanted - Parts & Tools | Clutch perch bolt for 03+ SV650 (or complete perch) also 00-03 GSXR clutch perch
    By juha_teuvonnen in forum Wanted
    Last Post: 05-22-18, 10:57 AM
  3. For Sale - Parts & Tools | Yoyodyne slipper clutch, Ducati 848 wet clutch
    By jwm2k3 in forum For Sale
    Last Post: 04-27-17, 10:07 AM
  4. 848 Dry clutch mod
    By obsolete in forum General Bike Related
    Last Post: 07-15-11, 02:13 PM
  5. F4i Clutch
    By Daytona440 in forum Bike Maintenance
    Last Post: 07-22-04, 11:21 PM
