Results 1 to 5 of 5
CRF450x oil leak
    Nov 2006
    Stoneham
    CRF450x oil leak
    My bike sat most of the summer, I started it up/let it run for a few minutes and a straight stream of oil came out of the overflow tube.
    I checked the oil and it wasn't over filled. And its not leaking any where out of the motor. The bikes never been knocked over or touched since the last ride.
    Anybody got a clue of what the problem is?
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    CRF450x oil leak
    you have little gnomes that put oil in your bike when your not looking.
    Maybe if you keep it in a shed where it gets hot the oil heated up and expanded, when the engine runs it takes in the oil so of course the oil is spread out through the components, or there was an air pocket after you changed the oil last that is trying to break free. I really have not much of a clue but figured to toss out an idea. Try changing the oil and see if it comes out of the over flow right after you change it, then let it sit for a week and see if it overflows then.
    Nov 2006
    Stoneham
    CRF450x oil leak
    Its worth a shot, thanks.
    Lifer Rye's Avatar
    Nov 2002
    Northshore...once again
    CRF450x oil leak
    Stuck float on carb? Not a good scenario. Dump oil quickly as it's probably loaded with gas. Did you happen to leave the petcock open?
    ALWAYS close petcock, especially on a carbed bike!
    Ryan
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Nov 2006
    Stoneham
    CRF450x oil leak
    Always closed it after a ride. I'll still take a look though. Thanks for the thoughts!!
  1. Oil leak
    By jimaug87 in forum Bike Maintenance
    Last Post: 08-15-07, 08:34 PM
  2. I am looking to buy a CRF450X
    By jre302 in forum Dirty Bastards
    Last Post: 08-13-07, 12:03 AM
  3. Caliper bleeder valve odd leak?
    By Billy in forum Bike Maintenance
    Last Post: 02-20-07, 11:19 AM
  4. coolant leak test
    By Awesome in forum Pit Area
    Last Post: 07-25-06, 06:21 PM
  5. Leak down tester
    By KB in forum Bike Maintenance
    Last Post: 07-20-04, 03:51 PM
