I think I have a grip on this but figured I would throw it out there for you more experienced dirt bike people.
I bought a new chain and sprockets for my dirt bike, the rear sprocket went up one tooth in size and the front stayed stock. 49T and 14T for information sake. When I went to install the chain I shortened up the wheelbase as much as I could by sliding the rear wheel as far forward as I could in the swingarm slots.
When I was measuring the chain to cut it to length, it became apparent that with the wheel as far forward as possible I would not be able to get the chain to a point where I could make the cut without a ton of slack in the chain, just under two links worth of slack to be exact. That being the case I cut the chain at the longer length and then used the adjusters to take up the slack in the chain to the factory reccomendation for slack.
My concern/question is that this puts the rear wheel pretty far back in the slots in the swingarm effectively lengthening the wheelbase of the bike which I would think would have some affect on the handling of the bike, Is this a normal thing? Would I have been better off going up two teeth (only did the one because it was in stock) and therefore have the two additional links compensated for by the larger diameter of the ring?
In summary, did I do something wrong by making it so that the rear wheel is pretty far back in the adjustment slots or is this something fairly normal depending on the sprocket combinations that are being used?
Joel
