Page 1 of 3 123 LastLast
Results 1 to 25 of 59
how mad should i be?
    back story:
    so this winter/spring i spent a fair amount of money on my dirtbike (03 KTM 300EXC). probably more than i shouldve and certainly more than i paid for the bike. i replaced stuff that was worn out, damaged or just upgrading things. This project was prompted by the fact that i broke a ring last summer and the motor needed a top end as a result. so since i have no history on the bike i decided i would do the bottom end as well and start anew. i was originally going to do the job myself but after talking with the shop, they convinced me to bring it to them because the crank would need to be pressed apart/assembled, shims, blah blah blah. i decided, that i would just pay the experts. in hind sight, i couldve done it myself. especially since i had to go get the crank from them and bring it to a machine shop to have the new rod installed and bring it back to them. i will admit the shop was good to me, they allowed me to purchase parts at my work for cost and bring them in for them to install, but they charged me a couple hundred more than they originally quoted me for the job with no explanation why.
    got the motor in the bike in time for the dirt classic. bike ran great, no issues. took the bike to clough a few weeks ago and bike ran ok. didnt start on the first kick like it did all day at the classic and seemed to keep loading up on fuel. at this point im chalking it up to a fueling issue/adjustment.
    i go out into the garage the other day and notice a small puddle under the bike. its oil. i pull the bike out and look to see that it appears to be coming from the countershaft seal. obviously that was replaced during rebuild. a few days later and the puddle has tripled in size and now theres a second puddle back by the rear tire. the oil is running down the chain and the swing arm and dripping down from the rear sprocket/chain guide. the engine has 8 hours on it and a new seal is already leaking. i am aware that those seals are pretty common, as i had replaced it once before the rebuild. i didnt expect it to fail this soon though. i called the shop and they said to bring it down and drop it off and they would fix it in a few days. they apparently dont make appointments so i cant schedule a time to haul it down there, wait, and then haul it home. its mostly just an inconvenience. i am tempted to just buy another seal and replace it myself, but then i think i shouldnt have to do either.
    TL;DR
    paid a shop to rebuild dirt bike motor. 8 (engine) hours later and a seal is leaking. should i be mad and give them the chance to fix it or just fix it myself and rely on them for KTM parts only and move on?
    Hanover, NH
    Re: how mad should i be?
    TL;DR
    I think it's too early to decide. If they handle it well, i.e. they warranty the work for free (or maybe the cost of the seal), then I don't think you should be mad. Disappointed, sure, but not mad.
    On the other hand, if they tell you it's not their fault & you should go pound sad, I think madness might be an appropriate response.
    thats kind of where im at now. what sucks is they are 40-45 from me. i work 6 days a week so i only have 1 day i can bring it down/ pick it up. maybe im more agitated that i cant make an appointment for me to go down on my day off, wait and hour or so, and then leave with the bike vs. drop it off and then not be able to pick it up until the following week.
    Eh, I am always a little sketched out about cranks and 2 stroke internals after the RM125 fiasco
    So many things can go wrong during a bottom end rebuild...so if it's truly *just* a crank seal then let them fix it and move on with life
    Any idea why the crank seal is leaking?
    iIRC it's just a rubber circular thing that has an interference fit...unless it was smashed into place/deformed, defective part, or the cases are mucked it shouldn't normally leak
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2017 KTM 690 Enduro R**
    Lifer union's Avatar
    Blackstone, MA
    Countershaft seals on KTMs are notorious for leaking. Don't know how many PK has put on his 125. New one goes on and it might last one ride before leaking again. Sometimes not even that long. I don't think I would be too upset about it especially if they fix it. Same thing will probably happen again. Get some extra seals.
    James
    12 KTM SMR 450
    07 CRF 250R
    LRRS/CCS #79
    NEMM #79
    GMD Computrack
    Diamondback Designs
    Robs Dyno
    PK went so far as to make a custom tool JUST for counter shaft seal installs.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    The seal is like $5-7. It's not even a one beer job. Just make it happen.
    One seal per ride?!?
    Would an OEM or aftermarket seal work any better?
    Man that is too much maintenance imho
    @OP - is it stator side at least?
    Maybe bring it to PK to see if his tool will seat it "more properly"?
    Edit: Google said to also check your crank bearings for play. Grab the flywheel and shake it...if it's floppy then the bearing is causing the seal to fail. Seeing how this is a rebuild, I would hope the bearings are in good shape. If they're not, then yes...piss away.
    Ashford, CT
    They're saying countershaft seal, meaning behind the front sprocket, not crankshaft seal.
    Jeff
    its the countershaft seal. behind the front sprocket.
    yeah, i kinda knew that. i just didnt expect it so soon. the last one started leaking shortly after replacement but i installed it cockeyed so i attributed it to that. good to know that its even more common place than i thought
    i may need one then lol
    thats where im leaning. doing it myself is far less of an annoyance.
    Quote Originally Posted by GearHd6 View Post
    correct
    im thinking im just gonna rotate the rear wheel a little so the leak will lube the other half of the chain for me
    Oh phew...brain fart
    Ya then definitely don't be mad...like a date that doesn't put out, just DIY and move on
    If it's anything like the 200, All-Balls makes a kit with both new seals and a new spacer. They are know weak points on these bikes.
    Did the kit in mine. No puddles yet.....but also haven't ridden it either.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Seacoast NH
    Motorbikes plus all but forces you to buy the seal and spacer together. They have a gazillion seals and spacers in stock. I've had no problem getting replacement seals quick. As Chipper says, easy job. Sprocket isn't even bolted on, just a snap ring. Just do it and be done. I would not be angry. These things are consumable.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Now.. Why does it start harder?
    Thats the next question. Like i said, i believe it to be a fuelling issue. Even during the road sections at the dirt classic it ran erratically. I figured it just didnt like the long hauls. But when it started loading up even in the slow stuff i started to think she might be a bit rich. I suck with carbs. Both food and mechanical
    Sep 2010
    Granville, NY
    If your engine guy equally sucks at seals. Then you may have issues with the right crank seal. One thing to keep in mind is that fixed jet carbs don't just go out of adjustment.
    Seacoast NH
    Ktm "book" jetting has been spot on for me on my 200.
    So, if one is concerned, how does one check crank seal integrity beyond bare eyeballing?
    Keep an eye on your tranny oil levels, and spooge. If the crankshaft seal is bad, it will siphon gearbox oil and it'll run extra fat.
    its gonna be hard to tell if the gearbox is low because of a crank seal if the CS seal is already leaking. im not noticing any spooge out the silencer, but im not really looking for it either. i do notice oil on the cylinder around where the expansion chamber mounts. i was thinking it may be from weak springs though.
    i have also discovered that my CDI box is crushed due to an AWOL steering stop. im gonna have to fix it and relocate it.
    replacing the pipe o-rings with quality Viton o-rings and new springs should cure that unless the pipe is tweaked too much. don't use the cheap FMF red o-rings, they wear VERY fast, my new set lost seal in a few rides. i now have KTM Viton rings on, which also cured some vibration. consensus says they are way more durable.
    i saw those on the micofiche. TBH, there wasnt one on when i disassembled it so it went together without it as well. i just didnt know it was supposed to be there. the pipe is new. what are the chances that poor seal is causing my running concerns?
    C'mon dude... it's just a seal. It's not like they pissed down the side of your new truck
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    Ya i mean its not like they dropped chocolate ice cream inside my new car
