if I have a '96 XR80R which will start to throw more and more blue smoke under WOT, the warmer it gets, and the valves, camshaft, cylinder, gaskets, and rings look ok.
So will re-honing the cylinder and re-ringing the piston potentially reduce the smoking on the premise that the smoke I'm getting is from a very minute leak around the ring?
what else should I replace while the top end is apart to potentially reduce the smoking?
