Re: How to remove frozen axle
Quote:
Originally Posted by
Chippertheripper
He does not read.
Paul, I'm a little disappointed we have yet to see pictures of this mauled axle.
I'd be lying if I said I wasn't mildly freaked out by this. I go back and forth between a cheap set of wheels and the stock wheels all the time, and now I'm a little weirded.
I can post up. I'm not sure pics do it any justice though. I would just keep an eye on the spacers for flaking or corrosion. Once it starts getting a little hard to remove the axle, replace them.
Also, typeone, it does look like my tire spun. The valve stem tore right out of the tube. That's a first for me. Rimlock was tight.
It's possible the tire stayed put and the tube moved inside it. I've never torn a stem off but I've gone to change tires where my valve stem is pointing at an angle which means something moved. I've never marked the tire and rim to see if it's the tire. I've debated running a second rim lock but never got around to installing one.
No MO GAS! I must have been layin down too much power!
but which way was it crooked? i thought i was spinning on accel as well but it was actually decel dragging brake down rocky hills.
breakdirt916
Eek hidden costs of dirty maintenance I am sure 95% of CL riders don't do
95%? That's being generous!
Paul, glad you got it fixed.
Well. It was not a pinch flat at least... https://uploads.tapatalk-cdn.com/201...5e748e7c2f.jpg
No patching that one to keep as a spare lol
Sometimes you can tug the nips too hard.
ZX-12R
Ouch!
It sure felt good to insert that axle and have it go all the way in with a smooth action...
You have been known to use all the power
breakdirt916
Was any lube required
I have decided natural is best. Lube plus sand equals cement paste.
How has no one turned the last two posts into something dirty.
I thought it was already obvious after the pull the nips comment...
Easy or not... don't think I've ever seen this group miss an opportunity.
isaac_
I personally like them easy, but thats just me.
Pittenger5
You disgust me.
csmutty
You disgust me.
PM sent
Pittenger5
PM sent
Lies.
hmm, starting to suffer from this ... found corrosion on axle and spacers before Sun ride, i've never seen that before. rode through a few deep water crossings two rides before. crap. hadn't washed the bike so i know it was from those crossings.
i'll clean up the axle and spacer for now, did it quickly Sat afternoon, but will prob upgrade to that SKF spacer/seal kit this winter.
