Results 1 to 22 of 22
Setting the bead
    Setting the bead
    Why can I NEVER set the bead successfully when mounting dirt tires? WTF. I guess I need to buy a manpressor.
    Re: Setting the bead
    What are you using now?
    You using lube?
    Not enough lube apparently. Just one of those mini can compressors. Gets about 55-60 psi into the tires.
    I spray some water/windex mix on em, but maybe it's not soapy enough.
    Is the valve stem core in the tube when inflating? I always take them out. Allows for more flow quicker in order to seat the bead.
    I use a mix of dish soap, denatured alcohol, and water.
    straight Windex and 50-60 psi works here...
    Lifer golden chicken's Avatar
    Fitchburg, MA
    At work, we use tire lube that I'm pretty sure is mostly lard...and it's amazing.
    i do all the above as well, but some tires are just difficult to seat, especially the super stiff sidewall style ... when that occurs, i drop PSI, use a spoon to pry tire away from rim, spray WD in/at/around the offending bead then re-inflate to ~60psi... and let it sit... eventually seats overnight or a few hours.
    the older super stiff Motoz w/rim protector were notorious for this.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Start here
    Speedaire Air Compressor - general for sale - by owner
    As Chip said. Straight Windex works great. Back in the day that is all I used. Dish soap also but is nastier (Gets sticky when it drys on your hands). Real tire lube is nice. Tire mounting soap is the tits but spendy and a bit nastier but oh so slippery. I have some for the stubborn stuff.
    Sep 2010
    Granville, NY
    I have resorted to WD-40 as well.
    the plus with Windex and dish soap is they dry clean or sticky... no tire slip issues... i have not had the pleasure of lubing with proper rubber lube... and i have chafe to show for it
    I've got a bucket of tire mounting lewb. You can have a bunch next time I see you. I'll never use it all.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Sweet. I will love you... err, thank you for it!
    Just get a few guys and...lube it?
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2017 KTM 690 Enduro R**
    Haverhill, MA
    Honda polish works too
    A gallon of Ru-glide is cheap at NAPA and works AWESOME.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Seacoast NH
    Liquid soap & water in a spray bottle.. And I've never had problems setting a beed with a tube. Last time 'round I realized I'd lent off my compressor and did it with a bicycle hand pump.
    WMC original sdog30's Avatar
    Burgy
    I just spit on my fingers and rub it in...wait...what are we talking about again?
    LRRS/CCS #66
    Dublin, NH
    That's what I use, works great.
    2015 KTM 1290 Super Adventure
    2017 Honda CRF250L Rally
    forgot about that stuff, you've mentioned it before ... can it be used with a Tubliss setup as well? is it liquid or like a paste/gel?
    I've got this.
    It's like a paste. Similar in consistency to bearing grease. Loosens up when mixed with water.
    Amazon.com: Camel Tire 12095 Tire Mnt Lubricant 8Lbs: Automotive
    -Clayton
    2006 Suzuki SV650
    It's a liquid, think very soapy water?
