I tore into the SX125 tonight. Pulled off the suspension to send to Kates. Greased upper/lower steering head bearings. They were getting a little dry, so that was good. Pulled the swingarm. Things still looked good, but I packed some fresh grease in the bearings. The lower shock mount has a heim joint in the swingarm. This is frozen in place, so I'll get it pressed out and replace it with delrin bushes. The hiems are notorious for failing.
ANyway, when I get my suspension back my winter maint will be done!
