Results 1 to 25 of 35
Required Fork Rebuild Equipment
    Nov 2007
    I'm planning to rebuild my forks this winter (fluid, seals bushings). I was wondering everything I will need to do this, and what equipment I should purchase.
    Traxxion offers this kit:
    eBay Motors: Traxxion Fork Service Tool Kit GSXR, R6, ZX, Ducati (item 230031274188 end time Dec-14-07 11:51:25 PST)
    Is this kit good? Is that a good price? Is there anything else I will need? I have inverted forks, btw (06 r6). Won't I also need a seal driver?
    Should I just use stock yamaha parts for the seals and bushings? If so, I assume mrcycles.com is the best place to get these since they are OEM?
    I assume Peter will chime in. Thanks in advance for your help.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    my rebuild list is as follows.
    1 - Trailer
    2 - Pete's Phone number
    3 - Money
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    Just Registered Wishbone's Avatar
    Jul 2006
    I watch Pete rebuild a few sets at one of his seminars, lets just say I love doing things my self and do all my own work BUT forks should be left to the pros
    Nov 2007
    Ok, advice acknowledged. I watched Peter rebuild a set of forks in september at TTD and it looked like something I could do with a little aggravation the first couple times, but might be worth it. I'd like to give it a shot. Learning how to do something yourself is a worthwhile investment.
    My question still stands.
    Also, to add to my initial question, what would be the additional equipment/tools/parts required to do a rear shock when the time came?
    LRRS/CCS #103
    1 - Trailer
    3 - Money
    how do you have time between repairs and mastering every game in the arcade section?
    easy.... I work for a living
    Another Busa Riding Troll CAT3's Avatar
    Oct 2007
    Pueblo West, CO
    I built mine and a few others..
    I didn't use the nice fancy fork spring compressor, although I wished I had. I used a 3" metal fitting collar, some threaded rod and thats about it for disassembly. Bushing dont always need to be replaced, only if they are worn. Springs, fluid, seals and dust wipers are needed.
    Here is a link to a pictoral/write-up I done last year, using the old skool home made tool.... Fork Rebuild
    I have since used the fork spring compressor offered from Motion Pro, Trax, Racetech and others.. so much nicer.
    If this helps cool, if you need more info let me know.
    Charlie
    The Big CAT rides the fastest bird!
    Only two defining forces have ever offered to die for you, Jesus Christ and the American GI. One died for your soul, the other for your freedom.
    need to login to view the link
    Oct 2007
    Pueblo West, CO
    Sorry I didn't know... I had this posted on the Busa site..
    Jun 2005
    I've done a bunch... At the very least I'd get the manual.
    Foxboro, MA
    Quote Originally Posted by l3uddha View Post
    PK is doing mine. he's drrreeeaaammmyyyy
    dont be gay dude
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Just Registered beet's Avatar
    May 2002
    Meriden CT
    You got a real job Pete.
    www.bostonmoto.com
    Forum Rules
    It's not that hard to do. I don't use any special tools, but I'm a hack! I do have the softjaws that are drilled to hold cartridges and pistons for actually changing the valving.
    There have been tasks I couldn't do, like removing the rebound valve from my 125 forks. Needed a custom tool made out of a CBR axle or something that Peter just happened to have. He's handy that way.
    But a basic rebuild doesn't require much more than wrenches, a drift, a screwdriver, a heat source, and an oil pan. Be carefull while using not specialized tools.
    Nov 2007
    Quote Originally Posted by trickphoto View Post
    Yeah I have the shop manual. Haven't really looked at it yet, just figured I would ask up here.
    Quote Originally Posted by Denno View Post
    dont be gay dude
    Pot calls kettle black.
    I see... I'm thinking I should invest in the right tools if I'm going to be doing it regularly...
    Any further input on the actual tool kit I asked about, anything else needed, info on the parts question I asked, etc?
    LRRS/CCS #103
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by ceo012384 View Post
    Not that its a difficult thing but aside from the right tools you do need a bit of experience to know what youre looking at so you know if you need to fix it or not.
    James
    12 KTM SMR 450
    07 CRF 250R
    LRRS/CCS #79
    NEMM #79
    GMD Computrack
    Diamondback Designs
    Robs Dyno
    Nov 2007
    I see... I figured I would replace the seals and fluid for sure, and the bushings probably since I've already got them all taken apart. I imagine those OEM parts aren't too expensive, are they?
    LRRS/CCS #103
    Blackstone, MA
    Ive never bought OEM fork parts. If your bike is kind of new or lowish miles you probably wont need bushings. I had 11k miles on my bike and the bushings were good. Ill find out how they are at 15k when I pull it all a part one of these weekends. Seals you will need. I guess if you were real careful you could reuse them but why take the chance in having a leaky fork? They should be cheap anyway.
    Good luck.
    James
    12 KTM SMR 450
    07 CRF 250R
    LRRS/CCS #79
    NEMM #79
    GMD Computrack
    Diamondback Designs
    Robs Dyno
    Nov 2007
    Good luck.
    The bike is pretty new and pretty low miles. I don't think the bushings will need to be replaced. I was just considering the option since I would already have everything all stripped apart. I def wouldn't reuse the seals though, like you said.
    LRRS/CCS #103
    Nov 2007
    Re: Required Fork Rebuild Equipment
    So is this the proper procedure? I thought you needed a spring compressor for inverted forks? Also, they left the forks on the bike....?
    PD8HE5zehgo
    LRRS/CCS #103
    Feb 2004
    Bellingham, MA
    Please get that shit off the internet. That was the biggest hack job I have ever seen.
    so I have those pitbull front stands, a new torque wrench, new air compressor, and new impact gun & wrench. someone wanna help on a fork rebuild on a GSX-R
    EX 105 : AMA, ASRA, CCS South East, and WERA
    2014 ASRA SuperStock National Champion - Amateur Division
    Thanks to my sponsors: Motul, Michelin/STS, K&N, Woodcraft, Yoshimura R&D All Balls Racing, Galfer, Sidi Boots, Vortex
    Feb 2004
    Bellingham, MA
    Only on a Gixxer 'yo, only on a Gixxer...........
    Jul 2006
    You think thats bad? You should see this clown in action.
    I think he is some sort of Charlie Brown and Soda Popinski love child
    Nov 2007
    Fair enough. It certainly seemed easier and far less involved than when I watched you do a set at a TTD 2-day event...
    LRRS/CCS #103
  1. Pete, I need a fork rebuild..
    By bump909 in forum General Bike Related
    Last Post: 05-09-07, 07:09 AM
  2. Deposits for VIR required.
    By Degsy in forum General Track Day Talk
    Last Post: 07-15-05, 07:11 PM
  3. Advice Required
    By glo in forum General Bike Related
    Last Post: 06-24-05, 07:48 AM
  4. pointless crap..... (speakers required)
    By zombie in forum Off-Topic
    Last Post: 10-29-03, 09:10 AM
