Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Required Fork Rebuild Equipment
    Feb 2004
    Bellingham, MA
    Re: Required Fork Rebuild Equipment
    Quote Originally Posted by ceo012384 View Post
    Fair enough. It certainly seemed easier and far less involved than when I watched you do a set at a TTD 2-day event...
    That's because there are no short cuts to doing a job correctly. Seriously those guys are hacks. If any of my employees tried to service a set of forks that way it would be there last set for me. They did not take apart the cartridge, clean out the tubes, check spring preload, look for broken shims, debris in the valving, worn piston bands. Total hacks, not even a half assed job.
    Just Registered Wishbone's Avatar
    Jul 2006
    Yeah but look at the goofy face you got going on
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by fasterthanu View Post
    Remember, my secret weapon is I only LOOK stupid!
    Jul 2006
    My secret weapon is I look dumb, but in actuality I'm a moron
    Nov 2007
    On this same note Peter, I recall you using a gas charged can of some very smelly chemical as a parts cleaner when you stripped those forks down. What was it? What are other substitutes for it? Would, say, brake cleaner work?
    p.s. If I have a 25% discount coupon for GMD, can that be applied to the fork/shock rebuild deal this winter, or no?
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Feb 2004
    Bellingham, MA
    It was brake cleaner, Isopropanol Hexane. You can use the coupon, but not combined with the special.
    Lifer BostonSVkid's Avatar
    Dec 2005
    Hey Peter
    I just picked up a set of 01 gsxr 750 forks for my SV. One of the forks seems to be weeping a small amount of oil on compression. I wiped off the oil then compressed it again and same thing just a tiny bit of oil. I assume the seals are bad as the other one doesnt do this.
    I should be down by the end of the month hopefully or my buddy Q will bring them to have them rebuilt.
    2006 Ducati Monster S2R800
    Feb 2004
    Bellingham, MA
    Hey Peter
    I have adjustable clamps to fit them to the SV. Don't buy the bearing from the online place, it does not fit right. I can also make a proper stem for the stock clamps if you like.
    Lifer GMAN226's Avatar
    Coventry RI
    Please get that shit off the internet. That was the biggest hack job I have ever seen.
    You should be more specific. I can see 2 or 3 pitfalls to doing it that way.. And I have only assembled a few sets of forks, you should be able to tear that apart.
    G-man
    Gerard
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by GMAN226 View Post
    G-man
    I don't have the time to point out all the mistakes The Three Stooges made in that video.
  1. Pete, I need a fork rebuild..
    By bump909 in forum General Bike Related
    Last Post: 05-09-07, 07:09 AM
  2. Deposits for VIR required.
    By Degsy in forum General Track Day Talk
    Last Post: 07-15-05, 07:11 PM
  3. Advice Required
    By glo in forum General Bike Related
    Last Post: 06-24-05, 07:48 AM
  4. pointless crap..... (speakers required)
    By zombie in forum Off-Topic
    Last Post: 10-29-03, 09:10 AM
