Results 1 to 11 of 11
Shock opinions
    Shock opinions
    Looks like Ohlins and Penske are the 'go to' shocks around NHIS, haven't played with Penske but I do know Ohlins from both Ducs and minis. Great shock when you can afford them.
    I've found one person selling a Fox 'Twin Clicker' used, I know Works makes a direct fit unit new for $400... Am I doing myself a disservice trying to find a used unit, or something other than the two NHIS favorites, or is there some other brand I should be looking for for the GS500? (It's been suggested to me that WP has a unit that'll fit, Ohlins might have a direct fit as well?)
    Suspension is the one area that's going to make or break this rig, so while I want to keep my budget in check, I don't want to save a buck only to cost myself 5 later on when the cheap option doesn't do me any favors.
    (And not directly shock related, but has anyone played with ProMecha Provalve fork cartridge emulators? They use a shim stack instead of a spring valve ala Racetech?)
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
    Feb 2004
    Bellingham, MA
    Shock opinions
    I have a used Penske for the GS in the shop, I'll find out what the owner wants for it.
    Shock opinions
    Cool, let me know, along with any added costs to refresh it if needed, as well as spring/valving changes to account for my weight. (I'm only 145lbs fully suited up, so I imagine most shocks I'm looking at will be over sprung for me.)
    What are your thoughts on fork tube repair? One of mine has got some pitting encroaching on the swept area, a new unit is going to run $150 to $180 from Suzuki, I dunno what the cost would be to rechrome.
    Just Registered Doc's Avatar
    Jericho, VT
    Shock opinions
    SV650 shock should bolt right up too...
    Shock opinions
    You have to drill a new mount point on the lower mount, and cut off the excess bracket, plus the SV650 shock raises the ride height in back a good 1.5 inches.
    And I'd still be pushing a stock shock with unknown valving and spring rate. : ) I rather pay a bit more and get something that I at least know can be adjusted to match my setup/riding.
    Feb 2004
    Bellingham, MA
    Shock opinions
    Wrong shock for the app. Dangerous.
    Jericho, VT
    Shock opinions
    ahh....
    Re: Shock opinions
    Bumping this up, is the shock still on the market? If so sling me a price, including a service if needed, and an appropriate spring for a 135lb before gear rider.
    Feb 2004
    Bellingham, MA
    Re: Shock opinions
    Sold a while ago.
    Re: Shock opinions
    Drat, oh well. Is Penske still offering a GS500E fitment new? (Ohlins doesn't list one that I can find.)
    Feb 2004
    Bellingham, MA
    Re: Shock opinions
    Yes they do, Sport shocks (no Res. or Compression damping Adjuster) start at $553, 8983 $770, 8987 $1075 I need 4 weeks to get one made for you.
  1. SHOCK HELP!!!
    By The Crashing Tomato in forum General Bike Related
    Last Post: 04-30-07, 08:41 PM
  2. rear shock
    By SVRACER01 in forum General Bike Related
    Last Post: 01-18-06, 06:15 PM
