Results 26 to 50 of 70
Does one need to crash while at the track to become a better rider?
    Re: Does one need to crash while at the track to become a better rider?
    Concentrate on working on smoothness, precision and control. That typically yields the best results.
    In the 75-100 or so track days I've done over the years, I've had just two track day crashes.
    HOLY SHIT!! PROPS TO PETE- And you are freaking fast..been passed by you on that SV many times.
    High maintenance priss
    Central MA
    Quote Originally Posted by Lxpony View Post
    My bike has been damaged more being transported back and forth from the track then actually riding it on the track.
    Then buy your own damn trailer!
    Crashing doesn't help me. If you feel like you're on a plateau, use the CRs, personal instruction, etc...at a track day or school. Their experience is invaluable & much better than crashing.
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    - I call Keena's trailer spot next year!!
    Quote Originally Posted by kb1 View Post
    Hell no.... Adjustments have been made to avoid future damage and Kian bought a second pitbull rear stand so tie down straps are no longer needed. Get your own ride!
    Lifer 03Worc9R's Avatar
    Worcester, MA
    Mike, the way things are looking now, I may be trying to bump youth the bed of the truck.
    You really only need one, maybe two, crashes for 'street cred' purposes. Anything more than that is a waste.
    Still, I've fallen over a few more times, and taken away something from each. Learn what you can from every situation in life.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    I don't have any scars from crashes so I think I still need to do it again for maximum street cred.
    i've got a gaurd rail in Blue Hills with your name on it. it's right next to my spot
    how did this thread go from "do you need to crash to become a better rider?" to "here's where Brett needs to crash to get street cred"?
    shut up pete. doc sucks!
    Bridgewater, MA
    Quote Originally Posted by Jimmy 2 Shots View Post
    I don't ride on the street
    Jim is secretly in love with me? must be the hair.
    Life is good! gadget's Avatar
    Nov 2008
    Londonderry
    When I was autocrossing in the 80's one of the required skills was to know how fast your car could go through a turn without losing traction. The best way to learn this was to keep going through turns each time going faster until you slid out.
    You had to learn your car's limits.
    How do you do this with a motorcycle?
    Sam
    I93/495
    This! Too many people view track days as trying to go as fast as they can NOW. If only they realized if they dialed it back a few notches, and concentrated on building skill rather than the speed, they'd go soooo much faster in the long run!
    I've got less than a track day and a half and I've smashed 3 times. I'm disgusted.
    Ask yourself what's more important. Going as fast as you can NOW, or even faster later?
    2012 Tiger 800 XC
    I93/495
    Quote Originally Posted by gadget View Post
    Slowly and carefully would be my take!
    You can exceed the limits of something and not crash. It's the rate at which you exceed the limits that can bite you
    2012 Tiger 800 XC
    growing up in Greece (always a few years behind) thats exactly what we were practicing. I guess its pretty similar with the bikes.. maybe not always in the track.. for example i dont think you can learn how to wheelie, and i mean really wheelie like go far change gears etc unless you fall..
    everyone has different limits.. but finding where the limit is and crossing it successfully i think is the biggest satisfaction to any motor head..
    Central MA
    Easing into it once you have a good base skill set. You can exceed traction limits and not crash. By first learning to be loose on the bars, weighting pegs, ratcheting the gas: you can then most likely ride thru a little slide without binning it. And rain riding helps find this at a lower speed.
    Crash about 5-8 times. YMMV
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    Mike...i told you...remember "top gun" when Maverick was gunshy after the accident that killed Goose? he got out of it better....shot 4 migs......but he had to get the incident out of his mind first....tis all mental.
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    I would say to be a better rider NO...to go faster YES
    May 2007
    Southern NH
    I remember thinking about this a lot when I first started doing track days. I was pretty sure there was no need to crash to get better.
    I still believe this. But that's a bit of a different question than "Will I ever crash?"
    So, while there's no requirement to crash in order to improve, there is a certain probablity that, eventually, you will. It may not even be your fault, it's just the law of averages.
    I've crashed several times now and except for one really weird tank slapper that threw me at Summit Point, I have learned something each time....
    Muhammad Ali.
  22. #47
    Even that's debateable, IMO.
  23. #48
    May 2007
    Southern NH
    I think it's safe to say that every single expert racer, whether MotoGP or LRRS, has crashed...
    ...so, that suggests that while you may not need to crash to go faster, you certainly will crash going FASTER. See, there's faster. As in, faster than you went before. And there's FASTER as in FASTER than I went before and didn't crash.
    Kind of like skiing. Most of us could get through a slalom without falling. And we could get though the same slalom faster with practice withoug falling. But, in the process of becoming competitive...and that may be the key factor...you will certainly push limits that will cause a crash.
    Muhammad Ali.
  24. #49
    Which came first, the fast or the crash?
  25. #50
    Aug 2009
    Grafton, MA
    Is it safe to say that you have not pushed your limits until you have crashed?
    and with that, do you become a better rider having experienced that.
    99 R6 track bike
  1. Replies: 36
    Last Post: 05-31-16, 08:52 PM
  2. LOCAL CRASH< UNKOWN RIDER DOWN
    By Dichotomous in forum Vermont Events
    Last Post: 10-03-11, 11:26 AM
  3. Any news on the rider in sundays T10 Crash?
    By 6 Fingered Man in forum Pit Area
    Last Post: 06-14-10, 07:11 PM
  4. WTB: SV650 track/race/crash
    By Kitt in forum Wanted
    Last Post: 06-10-10, 10:33 AM
  5. Bad crash at the track
    By theothersean in forum Pit Area
    Last Post: 07-15-03, 04:51 PM
