Results 26 to 50 of 57
Overtaking advice
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Overtaking advice
    Ignore me. Isaac has it. Rachet the throttle (click click click) up.
    If the rear does step out just hold where you are, do not chop, do not increase, give it time to recover.
    Going slow will do it in most cases
    Ratcheting the throttle
    Hi Tony!
    Basically you want to treat the throttle like a ratchet. Make mental "clicks" as you consistently roll on the throttle. If you start to feel the rear slip hold the throttle where it is (at that click). The mental ratcheting mechanism will not let you roll off the throttle. Hold that throttle position consistent until you feel the rear regain traction, at which point you can resume your throttle roll on and then pit in a check your trousers to see if you need to change them out.
    Oh yeah...bring spare trousers!
    Congrats on being addicted soon!!
    Mar 2012
    Chichester, NH
    Well, yeah, that's what I tend to do.
    The ratchet technique is secondary to this other "RULE".
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    Attachment 42121
    ^^^ How it's done.
    Ok, that's ridiculous. For some perspective, what bikes were y'all riding?
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Quote Originally Posted by TTD View Post
    Don't use the rear brake?
    Never. Ever. Ever apply throttle while leaning the bike, only while standing it up (on exit).
    I'm a bit overtired here. Am I seeing things or did smutty just use the word "trousers"?
    Jul 2014
    Central CT
    he did
    Quote Originally Posted by -Dutch- View Post
    Jason is on a 1928 Honda CBR600. I am on my SV650.
    We both felt we were starting to put some things together. Dearest potato man felt the need to smack the pride right out of both of us simultaneously and remind us that school was still in session. It worked.
    And what is the most sure-fire way to prevent a high side crash?
    I always straightened the bike while leaning my body into the corner i am exiting more in order to increase the size of the contact patch...but I don't think that is what you are referring to. I am assuming this is already a pass on the outside after the apex of the corner.
    And wtf is wrong with trousers bubsss?!
    Ding, Ding, Ding... we have a winner!
    Increasing throttle should only be done as you reduce lean angle.
    One of the main reasons for exit crashes are because riders do not get the bike turned enough by the apex. They are now past the apex and their eyes are seeing the next straight so they apply throttle. However, they realize they are not pointed enough down the track so they continue to turn or worse... turn more!
    If you blow a corner, then don't stack one error on top of another. Get the bike pointed correctly and then start reducing lean angle as you apply throttle. Better to blow a corner and lose a little time than highside.
    Tony
    Windham NH
    The beauty of a TD is no passbacks. You can go rambo on the brakes to make the pass, then blow the corner and run wide, stay off the gas the whole way around while you correct your line, then recover on the next straight!
    ...I'm totally kidding
    ...sort of
    When you start racing and the red mist descends, you will make this mistake a few times despite our warnings. LOL. Unfortunately, you really CAN'T learn from others mistakes when trying to be fast. The hard pavement is really the best teacher.
    My first track related win. Woo hoo!
    Oh, wait..
    i do something similar to sav but its tough to do with such huge speed/hp differences.
    to pass in 3 i start in 1.
    take a wider entry into T1 and late apex it
    then late apex T1a and hold it
    turn in later for T2 and late apex that as well
    this will have you exit T2 very low (on the inside) while the other person is running out towards the wall up high. because you late apexed T2 you have a straighter trajectory and can get on the gas way way sooner so when you get to the halfway point between T2 and T3 youre at the very least going as fast if not faster than the person you are trying pass.
    as they start to slide left to set up for the braking zone and turn in T3, you are moving right which puts you on the inside. basically your lines crisscross. he will move over in front of you and you will move over to where he was.
    you only have to brake slightly later and get next to him. after that he would have no choice but to concede the position and let you go. just be sure that if you go into that turn side by side that you hold a tighter line so as to not run anyone wide by accident. this will mean that you will have to take the corner slower than usual
    Senior Member AVI8_636's Avatar
    Jun 2012
    NH Seacoast
    Don't be afraid to ride in the rain. Great way to learn about traction management!
    This is super important. I was at a TTD a couple summers ago and it started dry, and then it turned into a steady drenching rain, completely soaking everything. I was bummed, I brought both my bikes and thought, what the hell, it's just water. It was a GREAT learning experience. Tony opened up the track to all riders since almost nobody was going out, so for a few laps I shared the track with only a handful of other bikes. I learned a lot about traction management, and more importantly, I learned just how much grip the track still has when wet.
    The only downside was that my boots got soaked!
    2006 DRZ400SM
    Jan 2014
    Chelmsford
    Have to say, this has been one of the most informative threads here so far. Lots of stuff to learn!
    Learning daman's Avatar
    Jan 2015
    Nashua,NH
    Quote Originally Posted by JackFrost View Post
    Totally agreed! Very very helpful to me as a noob!
    Honda CBR 600RR(Track), BMW S1000RR(Street)
    Jul 2014
    Central CT
    Quote Originally Posted by AVI8_636 View Post
    Wrap your feet in plastic bags before putting on the boots. It won't keep your boots from getting wet but will minimize your feet from getting wet.
    Or you could get some rain gear to put over your boots.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Honest.
    I didn't mean to smack my pals down.. Lol.
    I never understood the plastic bags. Don't your feet just get soaked in sweat then?
    Feb 2014
    Pawtucket, RI
    What were you riding? All I see is a blur.
    Mar 2012
    Chichester, NH
    Not that it matters, but I *think* Rada was on his 1K Gixxah. It would have looked the same if he were on the SV.
    i have waterproof socks
  1. New Here and need some advice
    By jtryz in forum Welcome and Intro
    Last Post: 06-08-11, 05:09 PM
  2. I need Advice......................
    By Wayne-o in forum Rides & Events
    Last Post: 10-29-04, 09:13 PM
