Page 1 of 6 123456 LastLast
Results 1 to 25 of 129
Tire Pressures @ the track
    could we have the local vendors list their recommended HOT tire pressures for 120/160 & 120/180 tires? I wanted to keep a cheat sheet handy for when I go to the track.
    Bridgestone 003 - 30 psi front, 30 psi rear
    Bridgestone BT003 RS Track Day Tire 32 psi front, 31 psi rear
    Bridgestone BT003 Pro DOT Race 31 psi front, 30 psi rear
    Bridgestone R10 DOT Race 31 psi front, 33 psi rear
    Bridgestone Superbike Slicks 31 psi front, 28 psi rear
    Conti DOT - 30 psi front, 28 psi rear
    Conti slicks - 29 psi front, 26 psi rear
    Dunlop DOT - 33 psi front, 23 psi rear
    Dunlop slicks -
    Michelin Pilot Power, Power 2CT and Pilot Pure - 31 psi front, 28 psi rear COLD
    Michelin Power Race and Power One - 31 psi front, 22 psi rear COLD
    Michelin Power One 16.5 slicks - 31 psi front, 22 psi rear. COLD
    Michelin slicks 17" - 31 psi front, 28 psi rear (1247A / 1847C generations) COLD
    Pirelli DCIII - 33 psi front, 33 psi rear
    Pirelli Supercorsa Pro DOT Race - 32 psi front, 28 psi rear
    Pirelli Diablo DOT Race - 32 psi front, 28 psi rear
    Pirelli Diablo SLICK - 32 psi front, 28 psi rear
    ...etc
    May 2007
    Southern NH
    Re: Tire Pressures @ the track
    This is a GREAT idea...
    ....lets see who's first to post this up!
    Quote Originally Posted by DBKromz View Post
    Bridgestone DOT -
    Bridgestone slicks -
    Conti DOT -
    Conti slicks -
    Dunlop DOT -
    Dunlop slicks -
    Michelin Pilot Power -
    Michelin Pilot Power 2CT -
    Michline Power One -
    Pirelli DCIII -
    Pirelli SC2 -
    Pirelli Diablo -
    ...etc
    Muhammad Ali.
    Ummm its a bit more involved than just the manufacture, its also has Diff ratings for the Diff spec tires as Ntecs are 33/23 hot and the 211's and 209 are diff..I will get the sheet from Dunlop and post it...so you can see
    32/32 HOT
    Next thread.
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Quote Originally Posted by Paul_E_D
    32/32 HOT
    Next thread.
    Go post your arrogant additude somehwere else. I'm sure there's some new track riders out there that would be interested in getting some info for their tires.
    Dude, chill, it was a joke. This topic has been beaten quite a lot. It's also preference. but most tires work well between 30 and 34 lbs hot. For beginners, there's not much more to it.
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    32/32 HOT
    Next thread.
    Sense of humor failure this morning?
    Uxbridge, MA
    This Morning?
    Lifer obsolete's Avatar
    Norf Sho
    Jim was funny last night.
    The waitress brought over his chicken fingers and he acted shocked when he saw how many there were.
    -Alex
    Bridgestone DOT -
    Conti slicks - 29 psi front, 26 psi rear.
    Dunlop DOT -
    Dunlop slicks -
    Pirelli DCIII - 34 psi front, 36 psi rear
    Pirelli Diablo DOT Race - 32 psi front, 36 psi rear
    Pirelli Diablo SLICK - 32 psi front, 26 psi rear
    CCS/LRRS #83
    Make sure you differentiate between pressures to set at off the warmers (like Dunlop provides) and pressures / where they should be *right off the track* when hot.
    CCS/LRRS #83
    Bridgestone DOT -
    Dunlop DOT -
    Dunlop N-tec's- 33F- 23R Hot
    Dunlop slicks -
    May 2007
    Southern NH
    Scottie...
    Which are the ones you put up for Conti and Pirelli? Off warmers or off track?
    Muhammad Ali.
    Off track for Continental and Pirelli.
    Our pressures are always given as HOT pressures, meaning where the tire should be at it's operating temperature (as in on the track) for any given day. The trouble with pressures "hot off the warmers" are the track surface temp and ambient temps vary wildly, especially in New England and you will see very different gains depending on the weather. Some tire brands may be less sensitive to this, but IMO regardless of brand you should *always* get in a habit of figuring out what your typical *gain* is (change in PSI up or down from when the tires come off the warmers to when they are HOT right off the track). It is not unusual to see a front tire LOSE pressure on colder days, and on super hot days a rear tire can gain 3-4 psi.
    Here is an article that was put together earlier this year explaining tuning your tire pressures in more detail.
    Typically, we recommend off the warmers as leaving the front at it's HOT spec, and to expect a gain of around 2 psi in the rear. This was fairly consistent between both Pirelli and Continental. We also found that most customers turning quicker lap times, liked the rear tire to be about 1 psi below the recommended HOT pressures.
    Scottie...
    CCS/LRRS #83
    Hiram, ME
    These are all recommendations for a starting point for tuning the pressures. All are hot off the track recommendations. For trackday riders not running warmers, set them cold about 2 psi lower and check them right when you come off your morning warmup session, adjust, then check/adjust again after your first open session. I've got a document that describes the pressure tuning process pretty well, email me at mike@gomtag.com and I can send anyone interested a copy, or you can pick one up at any LRRS event.
    May 2007
    Southern NH
    Excellent thread...adding relevent items to my Track Day Punch List!
    Muhammad Ali.
    updated list on post #1.
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    Yay Jim! Good idea...
    Very helpful information.
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
    added michelin, dunlop & Bridgesont DOT race pressures taken from this article
    vendors, feel free to post correct these pressures if they're wrong.
    Feb 2009
    Lost in constant migration
    holy jebus. 25/23? I've been using 27/25 and people were saying it was too low (bstones, cold. according to the chart I should be @ 25/23). I should try those pressures and see what happens.
    Good info, I apologize for being arrogant.
    Seems like tire manufacturers are getting a little more adventurous with their recommendations lately.
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Quote Originally Posted by "Dangerous" Dan K View Post
    Those are COLD preasures referenced at 25/23. You might not heat the tires as much as the bikes/riders referenced in that chart. That is why you should set your preasures hot. I would not drop to those cold. I would use the hot preasures recomendations on the same chart and go from there.
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
    Feb 2009
    Quote Originally Posted by 6 Fingered Man View Post
    Fair enough. I was only given cold pressures to baseline, I should work on getting accurate hot temps I suppose.
    i knew the michelin recommendations were a bit lower than the traditional 32/32, which was the reason for this thread. i wanted to make a quick index card to bring with me when at the track. i plan on trying different tires, as I have Dunlops, Michelin, and Conti's to use. Plus, i've been asked by fellow riders I'm garaging with, and it would be convient to have something handy.
  1. Tire pressures during winter months?
    Last Post: 11-12-14, 03:28 PM
  2. Street Tire Pressures
    By Doc in forum Bike Maintenance
    Last Post: 05-12-11, 03:55 PM
  3. Motard Pressures...same as big bike
    By Manny in forum Pit Area
    Last Post: 03-14-09, 01:35 PM
  4. ex500 tire pressures
    By catch2otwo in forum Bike Maintenance
    Last Post: 03-04-09, 10:42 PM
  5. Tire pressures, etc
    By TheIglu in forum Dirty Bastards
    Last Post: 10-27-06, 04:06 PM
