I missed that post. Great bike. I’d be careful buying anything that lowers the stock height of the rear sets if you are going to track it. You’ll eventually be scraping them.
Printable View
The stock tires are Battlax BT016R. Suitable for track day use? They have 2,200 street miles. Seems to be a common sportbike stock tire.
BT016’s are a fairly sticky street tire. They don’t last a long time so 2,200 on them is quite a bit. I’d replace with a set of Q3’s or the like.
Kudos to TechSpec. Ordered the SnakeSkin kit for the GSX-R750. When I went to put the 3rd panel on, the adhesive had failed about 1/2 way up the tank.
Emailed Revzilla Friday and they got back to me Saturday with the customer service email. Sent them a pic, and they responded today (Sunday) asking for my address and are sending the replacement panel two day shipping.
GSX-R riders, how do you disconnect your brake light? Is there a harness plug or can you pull a fuse? If it’s a plug, where do ai find it?
Apparently the connectors for the front turn signals are a PITA to reach.
Its hard to see and get at but you can unplug it. Assuming the wiring harness hasn't changed. I'd look and see what I need to press to unplug and then by feel, get in there with a long thin flat head screw driver in one hand to press down on the connector. And the other hand pulling on the connector or the wires at the connector because its hard to get a finger on it and pull. Front just pull the speedometer. It's easy just 1 bolt and pull rearward. Pop the windscreen off too if it helps to pull the connector (once disconnected) out the hole.
Edit: if you are tugging on the rear wires because you can't get ahold of the connector, don't pull too hard. I never had an issue pulling wires out of the connector, but I never pulled hard. Once released it pulls fairly easy. Also the connector tab may need to be lifted instead of pressed to disengage.
Got the bike back Saturday as promised. But couldn’t go to TTD due to a minor-ish but urgent surgery. Next time.
GP Suspension 25mm cartridges and springs front.
JRI MC/10 Triple Clicker Rear shock with 550# spring.
All made in USA. It rides niiiice.
https://photos.smugmug.com/photos/i-...-kdXm69J-L.jpg
https://photos.smugmug.com/photos/i-...-T2JSqhp-L.jpg
Suspension is some of the best money I've ever spent on a motorcycles. Possibly second only to fuel and tires.
I'm considering JRI bits for the Harley. They are big in that segment too.
What are you GSXR owners adding for crash protection? Thus far all I have is WoodCraft axle sliders.
Most don’t use axle sliders. Full set of case covers, solid rear sets, and make your argument for or against frame sliders.
It’s a gixxah. Alls you need is duct tape.
They have a “Cut Kit” and “No Cut Kit.” Does I care? The cut kit is 50%.
Not sure. I used no cut for simplicity.
Generally speaking the 'no cut' kits compromise protection for ease of install.
Been riding the bike for longer periods to be ready to ride a couple hours a day on track days. It’s been warm lately, and man do these things pump out the BTU’s.
You like a thigh roaster? Try a big twin.
When I got the bike back from PK, their inspection notes said, “Front brake lever pulls back to bars.” Hadn’t noticed this as the bike stops really well compared to everything else. But the Triumph is full on well away from the bars.
Bled them with a MityVac and they seem a little firmer, but if I grip hard the handle still comes back all the way. Stocks pads, only 2,200 miles.
Is this normal with Brembo Monobloc, or I didn’t bleed them properly, or Other?
bleed them up and down. zip tie the live over night too is another good trick (if you can read this).
Surfed around on gixxer.com and this is considered the definitive brake bleeding technique. The dealer serviced this bike this spring, looks like he didn’t bother to bleed it well though the fluid seems good.
The idea of putting Teflon tape on the bleed screws seems reasonable.
Did your master have a recall on it?
Just checked Suzuki Cycles - Recalls
No open recalls. Think I’m set.
Recalls seem to be 2004-2013.
Massive Suzuki GSX-R recall | MCN
FYI Lowes has made a deal to sell Craftsman-branded tools so a lot of their Kobalt line is on closeout. Bought a two drawer steel toolbox for $40 instead of $50 original price (as a track day box). They have some wrench assortments on closeout as well.
Pretty easy to get this set up for a track day. Pull one fuse for the brake light and turn signals, one for low beam and you’re done with that.
The mirrors have the turn signal in them. But the connectors are behind the instrument cluster, removed with a single screw. If I’d thought it through better would have attached a pennant to the connectors to make it easier to put back on.
