Results 1 to 14 of 14
any triumph 675 guys out there with gearing advice for loudon?
    Aug 2011
    Coventry, RI
    hey everyone. so im finally going to leave stock gearing in the dust and go with something better for racing at loudon. i havent changed yet just due to laziness and stupidity but with the triple im not really sure what to go with. anyone run loundon with a triumph 675 have any advice on the gearing they find the best? thanks in advance for anything
    LRRS EX #329
    Thank you to my 2022 sponsors: Vortex, Hot Bodies, Cycle gear, Spectro Oil, DP brakes!!
    Jun 2015
    Republic of VT
    Re: any triumph 675 guys out there with gearing advice for loudon?
    Quote Originally Posted by Mgiossi View Post
    Hard to offer advice without knowing more about your issues.
    No drive out of (what) corners?
    Running out of top end on the straight?
    Between gears somewhere?
    x
    Senior Member Viper897's Avatar
    Apr 2014
    Seacoast Maine
    What is it currently stock?
    Also same questions Studio X asked so we can send you in the right direction.
    Nov 2007
    Stock gearing is almost always to tall for Loudon. In general bikes need -1 front +2 rear or something in that region. Your sig says you are an amateur, what kind of times are you running? -1/+2 is usually a good start for middleweight, unless the daytona needs something wildly different than other bikes.
    If i recall for MW bikes you try to gear to almost redline 4th under the treehouse (you can hear fast guys like scotty actually hit the limiter under there). Also roughly top out 5th on the straight. Carry 3rd through all the slower corners, etc.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    15/48
    Nov 2007
    What year is it btw? looks like 06-12 was 16/47 stock. So paul is suggesting -1/+1.
    LRRS/CCS #103
    that's it? the GSXR's run -1/+4 for NHMS
    Nov 2007
    Yeah I had -1/+3 on my 06 R6.
    Maybe the extra torque and powerband of the 675 triple makes things a bit different.
    LRRS/CCS #103
    Aug 2011
    Coventry, RI
    Triumphs are all mid range. They do nothing in the upper rpm's and nothing in the low rpm's. The gears do seem to be too long and i could use more punch out of the corners but I don't want to be too high or I will just be shifting contently to try and keep the rpms down.
    Nov 2007
    Well there's at least a starting point in this thread. One thing is for sure, stock is not right. Go with Paul's suggestion for starters if not one tooth larger on the rear. What lap times are you running on it?
    LRRS/CCS #103
    Aug 2011
    Coventry, RI
    Thanks CEO, and thanks Paul I will try your suggestion. I know I need more punch out of 2, and 12. Most bikes are pulling out of those turns on me pretty well. And I'm only just getting into 5th on the straight. As for times I'm a new AM running 22's with the stock gearing
    Nov 2007
    I would Grab the -1 front for sure, then grab a couple rears so you can try them.. They're cheap. Also sometimes it's nice to have several sprockets if you are going to go to other tracks.
    Cory Hildebrand is running triumphs as well. But he is running 8 seconds faster than you so maybe not using the same gearing that would be ideal for you. Not sure if he's on NESR
    LRRS/CCS #103
    You can go 49 butbitbwill be high in the revs and very aggressive off the corners.
    Apr 2014
    Seacoast Maine
    15/49 will put you into 6th gear on the front stretch at loudon. at a 1:22 15/48 would be the best starting point
  1. Gearing for Loudon
    By bogie413 in forum Pit Area
    Last Post: 10-14-12, 10:21 AM
  2. recommended Loudon gearing for a 600?
    By feralchimp in forum Pit Area
    Last Post: 04-20-12, 02:02 PM
  3. SV 650 Gearing for loudon
    By KB in forum Pit Area
    Last Post: 01-28-09, 06:22 PM
  4. SV gearing for loudon
    By vintage ex race in forum Pit Area
    Last Post: 02-23-08, 09:03 PM
  5. Loudon.....Gearing Question
    By By-Tor in forum General Bike Related
    Last Post: 04-24-05, 10:19 AM
