Results 1 to 5 of 5
Coppah's baaack....
    Massachusetts' Noth Shoah
    Coppah's baaack....
    Coppah's baaack....-funny-pictures-ostrich-police-chase
    Over the past two years, my '03 SV1000S developed a pounding through the bars that was directly dependent upon engine rpm. There used to be a "sweet spot" at around 4,000 rpm, but even that had gone. I think Mark B. (TLRman) was right on when he postulated that it was a crank bearing (side clearances were a rare, but known issue).
    This past January, I picked up an SV motah from MaxSalvage via Argo Cycles in Raymond. (Thanks to Scott622 who put me in touch with Tyler at Max.) I didn't like the looks of the valves, so I decided to swap the heads from the original motor.
    Coppah's baaack....-repl-motor-wo-frt-headCoppah's baaack....-repl-frt-cyl-head-2-a
    It took a while, but I got the original motor out, and began the swap over.
    Coppah's baaack....-halfway-head-repl-motor-1-aCoppah's baaack....-bikeless-motor-jpg
    I took bunches of reference pictures to supplement the shop manual, and eventually got the original heads on the replacement motor.
    Coppah's baaack....-cam-alignment-1-jpgCoppah's baaack....-heads-repl-motor-1-jpgCoppah's baaack....-orig-heads-replacement-motor-jpg
    So, two weeks ago, I got the motor in the frame. Last week I had it running and needed to replace the gasket at the front cam-chain tensioner. Today, I road-tested it and got it inspected.
    Coppah's baaack....-frankenmotor-frame-jpgCoppah's baaack....-inspected-road-tested-jpg
    Ready to RIDE!
    Go fast. Have fun. Repeat.
    Lifer obsolete's Avatar
    Norf Sho
    Re: Coppah's baaack....
    Nice! Glad you got it up and running!
    -Alex
    Thanks! Might do those brake lines next weekend, too.
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    Looks good! Love the copper SVs.
    My '06 has a "knock" after it warms up, but everything I've read over at the SV-portal forums say it's not life-threatening. Nonetheless, I might follow your lead with a teardown one of these days...
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Thanks! Just wait 'til she's fully dressed....
    Yeah, I did a lot of research on the "knock" on the SV forums, too. This was definitely not that, and it was getting worse as time went on. Sure glad I got it remedied, though!
  1. Where to get Coppah looked at?
    By dontpanic in forum Bike Maintenance
    Last Post: 09-15-11, 09:16 PM
  2. Coppah: Self-destructing?!!
    Last Post: 05-26-10, 06:53 PM
  3. I'm baaack.
    By ameliaRR in forum Welcome and Intro
    Last Post: 06-25-09, 09:13 AM
  4. Coppah went to Rolling Thunder…
    By dontpanic in forum Rides & Events
    Last Post: 05-28-09, 08:28 PM
  5. Sun Oct 2nd (I'm BAAACK!!)
    By chr|s sedition in forum Rides & Events
    Last Post: 09-29-05, 07:21 AM
