Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Advice on securing sportbike in pickup
    Re: Advice on securing sportbike in pickup
    I use these cam buckle style jobbies with the integrated soft loops and spring loaded gates on the hooks on the front of the bike. I use these on the lift in the shop too.
    Two straps from anything solid on the rear subframe back. Any straps will do here, I have some cheapie cam buckles from harbor freight. Sinch the straps with your weight on the bike. Rock solid. On the dirtys I usually hook to the joint where the subframe meets the main frame. On street and track bikes from the passenger pegs or grab handles.
    Tighten down a few blocks down the road or at the first gas stop.
    Never used canyon dancer straps. They look nice.
    Oh yeah. It was tip-top. I'm just not sure about the color.
    Well that transit van sure was nice... buy out the glamper? Leverage credit, I'll make you a deal!
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    I usually do two ratchets up on the bars or forks, leave some slack in compression, and one strap over the bike with just a little pressure. Single ramp with a MX stand. My rear is lifted a bit too so it’s inevitably sketchy and perilous but ultimately works.
    Anyone use a winch? Thinking about mounting a winch behind the cab.
    05GSXR75005SV65090DR350
    Quote Originally Posted by Tekime View Post
    Loading with the method you mentioned is too easy to think about a winch imo.
    I prefer the wench method. Have to use completely ratchet wenches though.
    Member dompel's Avatar
    May 2010
    Maynard
    Thank you for the advice guys! I picked up a readyramp some ratchet straps and some canyon dancers.
    Mar 2016
    Falmouth, ME
    Just for dead bikes or other things I can’t drive up
    Fair enough!!
    Next thing you know, you'll be suggesting he buys a caravan without any wheels.
    I'm awful partial to the periwinkle blue.
    Lifer LuvDog's Avatar
    Ashland, MA
    Maybe it is because my truck is lifted a little bit, but the 2 ramp method never worked for me.
    Ramp for the bike and a vp race gas pail with some water in it to keep it stable. Just the one step up onto the pail and then onto the tail gate. Super easy.
    Well, I’m fucking short, so I need the second ramp.
    2003 ZX7R
    1995 916
    I also require 2 ramps. I cannot step high enough to step into the back of my Silverado. It seems I'm better at shuffling up a ramp than I am at stepping, even with a stand or something to gimmie a boost.
    I remain convinced that this man is 7' 2" tall and has a 50" inseam..
    Haverhill, MA
    That guy is definitely very tall
    Meriden, Ct
    Rachet straps are for rookies...
    And prone to failure
    Cat herder
    Dec 2014
    Low Earth orbit
    Hasn't been mentioned so I will:
    Don't crank the front end down so hard that it bottoms. That way lies blown fork seals. Leave enough play so the bike's suspension can do its thing. Don't worry, you can get the straps good and tight with the suspension partially loaded.
    FWIW I use these, run through the lower triple so the straps don't rub the bodywork. I prefer the latching hooks to the plain S-hooks most straps have. I also tie down the rear with a strap through the rim, but that's really only because I also have to strap down the ramp, my EZ-up and paddock stands anyway, so the strap is there and handy. It's really not needed.
    Loading is done by power-walking (i.e. engine on, in gear, clutch slipping) the bike up the ramp, which is wide enough so that I can walk beside the bike. I'm short, so trying to balance a 400-lb bike with my arms up above my shoulders is NOT happening.
    I think someone mentioned it, but DEFINITELY use the safety straps on the ramp to secure it to your truck so that it can't move. I saw a bike fall off a jacked-up pickup at NYST once because the guy was too lazy to do that.
    Haverhill, MA
    Likelihood of blowing a fork seal directly caused by tying a motorcycle down tightly is almost non-existent. The more likely scenario is that the seal is damaged prior to the bike being strapped down to the point where there is fork oil continuously sitting on the top of the previously damaged seal and therefore leaking. Another more likely scenario is the motorcycle has a dirty fork leg, due to the forks not being compressed to that point for a long period of time or just poorly cleaning the fork legs when washing the bike, and some crud has built up on the slider, even a dead bug carcass can rip a fork seal, so that when it gets tied down the seal passes over the crud and damages the seal causing the leak.
    If you have clean fork sliders and seals that are not already damaged in some way, strapping a bike down tightly won't hurt a thing.
    Quote Originally Posted by adouglas View Post
    My exact favorite ratchet straps
    Yup...still working out the kinks tho...the steel cable binds up and frays and involves 20 mins of unbinding
    There are many examples on YouTube and spends commercial products...I am trying to do it with a $130ish super winch
    So I got a rope (?) instead and a roller fairlane...still haven’t tried it. Most of my loading is the dirty in a 2wd truck on stock tires so it’s not necessary to winch. I am prepping it for the 480lb vstrom and possibly a year of track days next year
    Member martia's Avatar
    Grafton, MA
    I have a ready ramp very heavy duty and works as a bed extender. I dont like cannon dancers as they pull on the trothle. I use cycle cynch they are better as they pull straight down. Cycle Cynch
    Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
  1. Securing heated grips
    By Garandman in forum Bike Maintenance
    Last Post: 03-20-18, 05:44 PM
  2. securing a trailer
    By pontifex in forum General Bike Related
    Last Post: 09-12-12, 10:15 PM
  3. Woodcraft Hand Guards and Securing
    By csmutty in forum General Bike Related
    Last Post: 11-26-11, 05:06 PM
  4. Sportbike Camera advice for Motorcyle / Helmet mounted action cam?
    By motomasher in forum General Bike Related
    Last Post: 07-24-08, 09:22 PM
  5. Securing Expensive Helmets?
    By Billy in forum General Bike Related
    Last Post: 04-26-06, 01:53 PM
