Have I mentioned lately that I really suck at working on motorcycles?![]()
I bought my R1 with 1 stock bar end and one anti-vibration one. I am trying to install the anti-vibration one on the other side to make a matched set, but I can figure out how to remove in innards of the clip-on so I can install it. Here's some pics:
Anybody?![]()
TORCH IT!
Brent LRRS #772
2006 KTM 560 SMR
Lefty Loosy??
Chris J.
Does that alan head actually turn, or is it siezed (sp?)?
No, Donny, these men are nihilists. There's nothing to be afraid of.
- Mike
CBR 1000 RR
CBR 600 F4
Did you seriously just ask that?Originally posted by cyberxen
Does that alan head actually turn, or is it siezed (sp?)?![]()
Man oh Man.. If anyones that dumb they need to be taken outside and shot !
www.tailofthedragon.com
seriously... torch it!!!
with the aid of an impact wrench and heat that thing will come right out@@@
Brent LRRS #772
2006 KTM 560 SMR
is the only way bro
www.bostonmoto.com
Forum Rules
Ride your bike to my house and I will do the install for you .
TIMMYDUCK
Thanks homie, I appreciate itOriginally posted by TIMMYDUCK
Ride your bike to my house and I will do the install for you .If I get stuck, I might take you up on that.....
I'll probably go out and buy two new bar ends, since the rubber stopper on the one that was already installed was pretty violated, and I dont like how it seated.
I'm thinking I might hit it with some penetrating oil, and drill out some of the rubber.![]()
If thats not weld try tapping it IN first a little by hitting the end of the cap screw
If its a taper like deal this should break it free
Glen Beck is John the Baptist
The outer sleeve looks to be a press fit into the bar end. Soak it with penetrating oil, find a socket or short piece of tubing with good square cuts on the end that has an ID a little bigger than the ID of the bar, a fender washer, and a bolt long enough to reach through the washer, socket, and engage a good number of threads into the bar end. You are putting together a crude puller. As you tighten the bolt, it should draw the old bushing out. If this doesn't work, it will need to come out in pieces.
Drill as many holes in the rubber as you can, rip the center out, and then use a hacksaw blade to cut slots into the outer sleeve.
Good Luck...
SSearchVT
Did you seriously just ask that? Man oh Man.. If anyones that dumb they need to be taken outside and shot !F-you Grandpa!!!!!!
- Mike
CBR 1000 RR
CBR 600 F4
I ended up drilling aout 8 holes all the way around the steel inset the bolt threaded into, and ripping the whole mess out. It was a pain in the ass.![]()
with the aid of an impact wrench and heat that thing will come right out@@@wtf cookie they dont listen
www.bostonmoto.com
Forum Rules
Personally i would have bought one new OE yamaha bar end insert and 2 new OE yamaha bar ends and done away with those squidlookdonothingposerbarends![]()
or make your own custom stainless onesOriginally posted by R7
jim
"Molon labe"
They may indeed be squidly, but they do a wonderful job of dampning some of the vibration - which I found out after riding the bike with one stock one, and one "squidly" one.Originally posted by R7
Dude PIPE wrench or these easy out gizmos:
Remember if its an insane torque and its not budging........................maybe left hand threads?
-Suf Daddy
Suf Daddy.
-Suf Daddy
Suf Daddy.
Holy fucking leverage bar!!
oh man, those nut/bolt extractors are the fucking TITS, aren't they?![]()
So I'm not the only one who brings tools back to Sears in pieces. I usually just shrug my shoulders and smile when they ask me how it happened...
SSearchVT
ok i have to ask. What bolt need that much torque to undo? Perhaps some heat would be in order.Originally posted by Suf Daddy
-Suf Daddy
www.bostonmoto.com
Forum Rules
Its sort of a staged photo.
They are round head Hex / Allen socket 8mm caliper carrier bolts needed to be removed to get the rotor out.
The center allen part: rusted and stripped, so the bolt extractors were used and the bar is an extension to make undoing a simple thing.![]()
-Suf Daddy
Suf Daddy.
