Results 1 to 10 of 10
Interesting battery
    Lifer Stromper's Avatar
    Eastern Ct
    Interesting battery
    BatteryTender.com
    Seem to be available at only a 30% upcharge
    I think Battery Tender is a responsible company
    The calculus of hate
    Re: Interesting battery
    TWINS! xrocket21's Avatar
    Central Maine
    I use Lifep04 in my rc transmitters and they are great!
    Dec 2011
    Marlboro
    I put a lithium in my Street Triple. I think it's an Earth X.
    Great in the summer. I hate starting the bike in the cold (<50F). Takes forever.
    I don't ride that bike in the winter, so I'm happy with my purchase.
    But seriously, cold starting is a pain in the ass.
    It will start my Tiger 1050 in 32-40 degrees, something the stock battery couldn't do with the famously slow-cranking 1050.
    Eastern Ct
    I thought the Lithium trick was to leave the headlights on for a couple of minutes which heats the battery then it cranks
    I do use my streetbike rarely down to 30 but I do I think I am in for a battery for my DRZ250 which has a
    battery and a kick. I might do this for that.
    Arlington MA 02474
    When I was considering a 1050, I found 1050 forum threads about upgrading the starter cables ... maybe you know about it, someone makes a kit ... fyi ...
    OK, here it is: 07-12 Tiger 1050 Starter Cable Kit | StoltecMoto
    As to batteries, I use a Shorai LI in one of my kickstart Triumphs, for compact size, light weight, no acid, no maintenance, doesn't loose charge while sitting.
    For my KLR 650, I've had excellent service from a "Big Crank" AGM from batterymart.com -- three years of use, running full heated gear through three winters. I started the bike in 20* last week, it cranks fast, and the bike started after 2 seconds of cranking. (I use a Battery Tender when bike sits.)
    Just to clarify, these are LiFeP04 batteries we are talking about. It's not minutes, it's more like 30 seconds, usually.
    I bought the kit. But the voltage on the LiFeP04 batteries is higher so it cranks fine. I'll probably install them next season anyway.
    Unless you are a "weight wienie" you have to keep the LiFe batteries a long time to justify the high initial cost. We have a 48V Life battery pack on my eBike and it weighs less than half what the SLA batteries did, has double the range, and has a charge-cycle life 5X greater. I've been using them for three years.
    To my mind the AGM technology is tough to beat for cold weather price/performance. We have an Odyssey [Sears platinum] AGM in our minivan, and Optimas in my WRX and Outback. The Red Top is a great choice for the WRX because you take 15 lbs out of the front of the car (weight is 35 lbs). The Odyssey weighs a lot but has huge reserve capacity. That's important for the minivan because of all the power accessories.
    Lifer SwiftTone's Avatar
    Norwood, MA
    I was planning on picking up a Battery Tender 240cca lithium battery. Are there other brands that are better at same or lower cost of $100?
    Meriden, Ct
    Quote Originally Posted by reks95 View Post
    This is correct. Lithium batteries need to be up to temp before firing and engine. Turn on the key and run the headlight for 30 seconds before hitting the starter button. That will cure the cold start issues.
  1. Which battery charger do I need for my marine battery in trailer?
    By xxaarraa in forum General Bike Related
    Last Post: 11-25-22, 08:50 AM
  2. Replies: 20
    Last Post: 05-22-19, 07:28 PM
  3. Battery Tender / Deltran lithium iron battery
    Last Post: 03-16-15, 06:00 AM
  4. Replies: 7
    Last Post: 07-08-12, 08:14 PM
