Results 1 to 11 of 11
Battery Tender?
    Braap Baggey22's Avatar
    Westford, VT
    Battery Tender?
    So this past winter I had both batteries for my KLR and my ZZR die and need replacing. I'd rather not have that happen again, especially since I have a race bike now.
    Can anyone recommend (from personal experience) a good tender that can take care of a few (minimum of 3) batteries all winter? Something I can just plug in and let it sit until it's time to ride?
    Thanks!
    2015 Yamaha FJ-09 - Street, 2007 Yamaha R6s - track, 2018 Husqvarna FE350 - Woods
    Seacoast NH
    Re: Battery Tender?
    Member close2reality's Avatar
    Jun 2012
    Southern NH ('12 R1)
    Re: Battery Tender?
    Feb 2009
    Burlington
    Re: Battery Tender?
    What they said. I've used the Battery Tender brand for about 10 yrs with no issues whatsoever. I'd buy one tender and alternate batteries every so often.
    Panigale 1199S
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Re: Battery Tender?
    http://www.ebay.com/itm/Brand-New-Ba...9ece7c&vxp=mtr
    you could buy 3 JR's for under $100.00 free shipping and your all set. Cheaper than one new battery.
    Westford, VT
    Re: Battery Tender?
    Quote Originally Posted by #1 masshole View Post
    Every so often....like Weekly? Bi weekly?
    Newbie Linteau's Avatar
    May 2012
    Somersworth, NH
    Re: Battery Tender?
    Not sure of the brand, but I bought mine from my local walmart, haven't had any issues thus far, so it was a good 20$ investment.
    Jumper mod, kleen air mod,
    Gold ZXR Bar ends, Akra slipon
    Zero G. DB windscreen, Skidmarx tire hugger
    Integrated Tail light, Driven Axle Blocks, Speedo Healer
    K&N Air & Oil Filter, -1/+2 SuperLite Sprockets
    PC3, Galfer SS Front & Rear lines, Shorty levers
    Powder Coating done by, Myself
    Feb 2009
    Burlington
    Re: Battery Tender?
    Quote Originally Posted by Baggey22 View Post
    Others can correct me if I'm wrong but...I know guys that leave one battery on a tender during the entire off season. I know others that alternate a few batteries just every few weeks(leave the same battery hooked up for a wk or two, then swap to another). You're not going to do much damage to a battery if it's off charge for a few wks. Unless it's still hooked up to the bike still and the bike is sucking down tons of juice even while the bike is off like a Duc.
    If you do a search around here you'll find more info I'm sure. I think I've read that some people hate them and have had them destroy their batteries(Stoneman?). I've heard of a lot more satisfied people than upset people though.
    I had my '05 gixxer 1K oem battery for 6 yrs with not a single issue. Just hooked it up to the tender each winter.
    Panigale 1199S
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Re: Battery Tender?
    I've been using the Deltran tenders for winter maintenance for many years with no problems. I'll put a bike on a charger for a week or two then move it to a different bike. The batteries almost always last 5-6 years, sometimes more. Even if you have a clock and other low current loads on the bike, letting it sit for a week or three without a charger is unlikely to cause any harm to the battery. And if it did, then the battery was probably nearing it's end of life anyway.
    I connect a pigtail with an SAE plug to the battery so switching from bike to bike takes about 1 minute, plus I can use the SAE connector for electric gear if I'm riding in cold weather.
    If I was buying one now, I'd buy the Jr. model. It's max charge is only 0.75A Vs. 1.25A for the standard model, but for maintenance 0.75A is enough. It has the 4-mode charging logic like it's bigger brothers, so you don't need to worry about boiling the battery. Plus it's small, so you can throw it in your toolbox for the track, just in case you (or someone else) needs an overnight charge there.
    DanG
    - Blaise Pascal
    Westford, VT
    Re: Battery Tender?
    If I get the Battery Tender Jr. model and swap it around on my three batteries is it going to skyrocket my electric bill?
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Re: Battery Tender?
    The Battery Tender Jr is rated at 12W. If you kept it plugged in constantly for 6 months, it'll cost about $6.50.
    DanG
    - Blaise Pascal
  1. Battery Tender
    By tsorfas in forum Bike Maintenance
    Last Post: 02-08-12, 10:12 PM
  2. Battery Tender?
    By Hauptman in forum General Bike Related
    Last Post: 10-22-08, 11:09 AM
  3. Battery Tender?
    By Ericthejet in forum Bike Maintenance
    Last Post: 02-24-08, 09:16 PM
  4. Battery Tender ?
    By Punjistick in forum General Bike Related
    Last Post: 01-20-07, 04:55 PM
  5. BAttery Tender
    By snaggle in forum Off-Topic
    Last Post: 01-31-05, 11:37 AM
