Results 1 to 25 of 34
brake reservoir tubing
    Lifer NPDCPA's Avatar
    Mar 2011
    Is there anyplace local to Woburn, MA where I can source some of this stuff? I need to reroute my GSXR reservoir to work with the Woodcraft clip-ons. The OEM S tube is way too short.
    Is this as easy as hitting Home depot's plumbing section for some clear tubing? That works fine on the brake bleeds I made, not so sure about the real world application though. I don't want to send $25 for 3" of the stuff through Yoyodyne, either.
    Wirelessly posted (iPhone 4s)
    Tygon. Forget what number. Do a forum search for Tygon though.
    Jan 2009
    Middletown, Ct.
    Re: brake reservoir tubing
    I always get it from Motomummy, three days and it's in your hands. Might as well order enough to do the rear reservoir delete while you're at it. Bonus points, they have the honda caps as well.
    https://www.motomummy.com/store/prod...cat=252&page=1
    Wirelessly posted
    Tygon. You can buy it from mcmaster Carr and have it next day ups ground.
    martyk martyk's Avatar
    canton ma
    wouldnt a fuel line work from home depot or local autoparts store? it is pressure tested and wouldnt break down easily. thats if you need something right away, if you can wait i guess might as well order something more part specific as listed above
    Wirelessly posted
    You don't want condensation in there. Tygon is the stuff. I wouldn't use anything else in a brake system.
    Mar 2011
    Thanks!
    8mm tubing?
    ...inside the van. loudog's Avatar
    Central, MA
    Quote Originally Posted by NPDCPA View Post
    Thanks!
    8mm tubing?
    Yup.
    Retired LRRS/CCS EX #212 | Woodcraft | Armour Bodies | Dainese USA |
    street and comp sells it too
    Posting Freak
    Jan 2003
    Tygon-Kurveygirl-next day air!!
    Posting Freak
    Jan 2003
    Just had an "Ahha" moment that might help out- go here- http://www.autozone.com/autozone/acc...entifier=46839
    pull the hoses off and use them until you get the right stuff, then save the bleeder to bleed the brakes later!!
    As Inspector Clouseau would say..."Case solvead"
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by Tricklidz View Post
    if that stuff is anything like what comes with a Mityvac you don't want to use it. I tried it just to get by and it wept through after a day or two.
    Mar 2011
    Motomummy was the hook up. Methinks we need a local source for this stuff.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Nice, I just ordered some for myself from motomummy.
    I got 2 feet from McMaster-Carr for 3.50 plus another 4.39 for shipping (7.89 shipped)
    http://www.mcmaster.com/nav/enter.asp?partnum=5103K34
    Tygon 2375 - Part number 5103K34 -Chemical-Resistant Clear Tygon Tubing 1/4" ID, 3/8" OD, 1/16" Wall Thk
    NoChelmsford, Ma.
    I picked up 3 feet, mines bigger pete, and a magnetic oil drain plug for about 20 bucks shipped. They have free shipping on everything but require you to buy something else with the brake line, kinda dumb but thankfully I needed the oil plug anyways.
    I picked some RS125 brake tubing (the clear green stuff) and it now has outer condensation. Nothing inside the tube (yet).
    Should I be concerned?
    Bridgewater, MA
    I would be. the only time it should be wet is if you spilled fluid on it or its raining.
    It's just weeping cuz it's emo.
    Well, just in case, I snagged some tygon from the same place Pete got it from. It's easy enough to replace/bleed.
    Jan 2009
    Middletown, Ct.
    Quote Originally Posted by DaveZX6r View Post
    I always get some motomummy stickers or a resivoir sock to get the free shipping.
    not sure if i had the same stuff, but i had some green tubing that looked like the fluid was sweating out.
    i just picked up some clear stuff from Street & Comp the next time i was at the track & swapped it out.
    NoChelmsford, Ma.
    So I realized the other day that this stuff is clear. Isnt UV supposed to be bad for brake fluid? I thought that was why the OEM tubing is always black.
    Mar 2011
    Then why is the reservoir clear?
  1. Wanted - Parts & Tools | wtb brake reservoir bracket
    By tsorfas in forum Wanted
    Last Post: 05-11-16, 08:28 AM
  2. WTB: 2nd gen SV front brake fluid reservoir
    By maxim_X in forum Wanted
    Last Post: 03-13-13, 10:20 AM
  3. WTB-Front brake reservoir
    By lopycam in forum Wanted
    Last Post: 09-09-11, 11:11 PM
  4. WTB Brake Reservoir and Perch/Bracket
    By jcbell1007 in forum For Sale
    Last Post: 03-24-10, 06:05 PM
  5. Brake Reservoir sock?
    By wingerdor in forum General Bike Related
    Last Post: 06-24-08, 04:27 PM
