Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
brake reservoir tubing
    Re: brake reservoir tubing
    Quote Originally Posted by DaveZX6r View Post
    So I realized the other day that this stuff is clear. Isnt UV supposed to be bad for brake fluid? I thought that was why the OEM tubing is always black.
    the temperature in the clear tube will be much lower from direct sunlight, than the temperature of the fluid in the calipers while under heavy braking.
    if you're really that concerned, you can get a btrake fluid with a higher boiling point.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Yeah I wasn't talking about temperature Jim. I realize how much heat gets generated in the calipers. I meant the actuall sunlight itself. I had heard in the past that sunlight actually breaks down brake fluid over time. I doubt it would be an issue as long as you flush your system when your suposed to anyways, but was curious if there was any truth to that.
    Quote Originally Posted by NPDCPA View Post
    Then why is the reservoir clear?
    They aren't, stock ones i've seen are usually opaque.
    My glasses block UV yet appear clear... UV is in a range you can't see, kinda like to infrared light many 'opaque' plastics are transparent, etc.
    NoChelmsford, Ma.
    ... ok so is uv harmfull to brakefluid or not? lol that was all I was asking.
    if it is, it's negligble.
    NoChelmsford, Ma.
    Thanks pete.
    Humidity will corrupt it before the UV gets a chance to break it down.
    UV light is more valuable with marchesinis.
    NoChelmsford, Ma.
    Life is more valuable with marchesinis!
    Your a bad influence jim...
  1. Wanted - Parts & Tools | wtb brake reservoir bracket
    By tsorfas in forum Wanted
    Last Post: 05-11-16, 08:28 AM
  2. WTB: 2nd gen SV front brake fluid reservoir
    By maxim_X in forum Wanted
    Last Post: 03-13-13, 10:20 AM
  3. WTB-Front brake reservoir
    By lopycam in forum Wanted
    Last Post: 09-09-11, 11:11 PM
  4. WTB Brake Reservoir and Perch/Bracket
    By jcbell1007 in forum For Sale
    Last Post: 03-24-10, 06:05 PM
  5. Brake Reservoir sock?
    By wingerdor in forum General Bike Related
    Last Post: 06-24-08, 04:27 PM
