So, on the side of the road. Bike sounds like it may be flooded. Was riding fine, engine started bogging down, stalled out. Was turning over with choke but stalling when I put it back down. Now won't start.
Have to go to work in 2 hours. Thoughts?
A
You do have gas right?
Vapor lock?
clogged fuel filter maybe?
May just be flooded,,,,
I know you had to ask itYes, gas was on
If flooded, how long should I give it? Glad it's a nice day!
Sounds like you are out of gas or lost a battery connection.
Hyosung gv250. Not out of gas, not battery. The bike still cranks, just won't turn over.
I would look at the fuel pump if it has one, make sure it is pumping gas. Then check for a clogged fuel filter. The symptoms you are describing are almost definitely a lack of fuel to the carb/s.
open gas cap might be vapor lock
Does your bike have a reserve fuel switch? Look around the bottom edge of the tank. Tank can sound like there is gas in it, but you can't access it until you flip the switch.
Tried gas cap. Inspected fuel lines, pump, etc. nothing. Also, stupid biker passed me on the side of the road, bike in pieces. Nice.
No spark to the plugs....... Fouled plugs?
dirt in the carb/ needles? I'm just guessing as I am not even there.
I'm heading in the city heading down 93S in a few minutes.
Call 617 304 2157 if you are still having problems, I can stop.
Q
Got it working. Will post how when I get home![]()
QFactor, thanks a bunch for the offer. You rock, and my mom will be in your top 8 any time
So, I managed to hail a biker. After about 5 minutes of asking me some of the same questions I got here, he got it started. He turned the fuel valve over to the reserve tank and it started right up. Because the fuel filter isn't clogged and there is plenty of gas in the tank, he thought maybe something was blocking the petcock at the actual valve. He turned the thing all the way around and back to reserve, ran fine. Turned it back to the regular tank, ran fine... Totally odd. Thank you all for all of the help and offers, I really appreciate it! Gives me warm fuzzies to know that I can get help should I need it!
Now, off to job #2.....
I was gonna offer ya ride to work too..
