Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Brrr!
    Lifer PhilB's Avatar
    Jan 2012
    Pittsfield, NH
    Brrr!
    OK, so that was cold -- 5*F (-15*C) riding in to work.
    A personal record that is likely to stand a while.
    The Monster was very reluctant to start at that temperature.
    Carburetors. Harumph. Lots of choke.
    My fingers got cold even with the heated gloves set on high.
    And I got an "ice-cream headache" from breathing.
    Nothing dangerous, but definitely uncomfortable.
    PhilB
    5 Not allowed! Not allowed!
    Re: Brrr!
    What tires do you run? Every bike tire I see turns to plastic at those temps, giving authentic "big wheel" traction.
    Rochester, NH
    Re: Brrr!
    That's hard core! How long is your commute?
    Roland Arsenault
    LRRS and USCRA #763
    Jan 2012
    Pittsfield, NH
    Re: Brrr!
    I've got sport-touring Pirellis on it.
    The commute is about 25 minutes.
    PhilB
    Re: Brrr!
    a record for sure, but too cold for my blood/tires!!!
    Re: Brrr!
    Done it in high school. No thanks!
    2016 BMW S1000XR
    Re: Brrr!
    When was it -5° in Pittsfield at all this week?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Brrr!
    I *think* Phil is out of town. Somewhere in the middle states (Kansas maybe) if I'm using my faceyspace to NESR decoder ring correctly.
    Senior Member AEG's Avatar
    Aug 2012
    Simsbury, CT
    Re: Brrr!
    5*F(-15*C), not -5*F: from OP
    Re: Brrr!
    Quote Originally Posted by AEG View Post
    Good call.
    Re: Brrr!
    ° not *
    Mar 2012
    Chichester, NH
    Re: Brrr!
    Not everyone knows how to type the ° symbol, especially if on a mobile device.
    Jan 2012
    Pittsfield, NH
    Re: Brrr!
    Yes. I'm out of town. Working in St. Louis, MO, this winter.
    Randy, I do know the standard shortcuts for many of the symbols, but they don't work on all devices.
    PhilB
    Lifer Falko's Avatar
    MoonTown
    Re: Brrr!
    Some people need a better hobby, and I am not referring to Phil.
    That's some cold riding, I lose the ambition around 30F. I rode to a few hours up into ME once in the mid 20's. That was just not at all enjoyable, but it was before I installed the heated grips on the bike.
    Meriden, Ct
    Re: Brrr!
    Hell, I have no idea how to do it on a traditional keyboard.
    Re: Brrr!
    Alt 0176
    Re: Brrr!
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Brrr!
    Alt 0176
    You mean Alt + F4.
    Mar 2012
    Chichester, NH
    Re: Brrr!
    Lol. That's just mean. I approve.
    Re: Brrr!
    I used to run Pirelli MTR60-Corsas on my SV650 in winter, @ about 28-30 psi instead of the 36-40 psi I would run in the summer. even in sub zero weather, they would get warm enuf to roll steam of the tires if I rolled over a covering of unpacked snow
    Nov 2009
    Bristol County
    Re: Brrr!
    The degree symbol technically does not appear in that chart. ALT+176 is not the same as ALT+0176. You need the preceding zero. And while ALT-167 in that chart looks almost identical, it technically is a masculine ordinal indicator. But when they're that small, it's pretty much impossible to tell the difference.
    iOS, press and hold the 0 to get the degree symbol. I'm betting it's the same on Android?
    Re: Topic, that's impressive for a half hour. Lowest I think I've been able to go was ~25F in the dark for 35-40 minutes. No heated gear, but I was covered in many layers, and did my best to expose almost no skin. Wasn't worth it. Wouldn't volunteer for it again unless I pick up some heated gear.
    nedirtriders.com
    Re: Brrr!
    Randy, subzero C° or F° or Kelvin°? Interesting that you could get your tires above boiling in that weather to make steam. You must ride like Satan himself. This is great, I can use my tire warmers to get ready for my ˝ mile commute!
    For those interested, to display the degree symbol (248) or any of those commands in the table Randy listed, on a keyboard the NUM lock needs to be on, and use the numbers on the right side keypad, NOT the ones above the letter keys.
    Re: Brrr!
    yes it does, I was not the one that posted 176, the [alt] number for the ° symbol is 248
    ░ = [alt]176
    New Haven-ish, CT
    Re: Brrr!
    I think this was my coldest ride to work, last February
    Re: Brrr!
    key is lowering the tire pressure, as I said, I lower the pressure to 28-30 but I weigh 300 geared up, a lighter person would probably need to lower the pressure even more, but not really any different than some riders do when they ride gravel, and you don't need to get the tire to boiling to see steam, all ya need to do is turn it to water vapor, like seeing your breath when you breathe
